Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet squeaks
Everytime I run a load of clothes in the front load duet washer it squeaks. I bought it last year at the end of february. Is it still under manufacturers warantee? I live in polson montana and bought it from a place in missoula which is at least 80 miles away. Is there a service I can call to come fix it?
  • Thomas Malailua
    Thomas Malailua May 11, 2010
    they will find some one to come out.i have serviced that prob before and the solution was to spray wd-40 on the springs,so wont squeak
  • 318 Answers
You can call whirlpool at 800-253-1301 and they will set up and recommend a service company that is authorized to repair your unit. just let them know its less then a year old and they will get you taken care of.
squeaks are hard to find, but you need to get it set up before your warranty runs out.
Posted on Jan 31, 2009
My whirlpool duet front load washer is giving a F21 error code. It will not drain. When I blow into the drain hose on the back of the washer it will start draining. But everytime I run a new cycle it will...
whirlpool duet front load washer this video is on a bosch but it will help you Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
When I have only one item or a very small amount of clothes in washer no matter whether it is set to normal or quick wash, it doesn't spin the clothes dry. I have to try to put it with a bigger load to...
If you just got it I would call the manufacture it comes with a 1 year warranty might be a board or sensor issue there are sensor's that tell how much weight is in there so it knows how fast to spin the drum thats where the power saving features come in.
Jan 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
It leaves a terrible mildew smell on all of our clothes
This is a common problem for front loaders. I have been told to do the following to minimize the problem with my front loader. Some of them seemed crazy to me - but they seem to work.
1) Wipe the drum dry when done with the last load.
2) Leave the door open between washes.
3) Run a small load of hot water & bleach only (no detergent or clothes) as the last load.
4) Use only "HE" detergent. I know, it's more expensive but the "non-HE" types create excessive suds - and will not pump out at the end of the cycle very well.
5) Use a cleaner designed to help rid the washer of the smell.
Additionally, check this site for additional tips, etc.
I hope you find and rate this "Very Helpful"
Dec 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Can you tell me the size of my Durt washher, and how long is the rear basket bearing under warrenty? Model# GHW9100LWZ Serial# CSR1819478
Your duet washer size is 3.7 Cu Ft. Bearing last long or short depend on how ofter you use and how much clothes and whether you use heavy or light cycle.
Normal use will last sometime 8 or 10 years.
Heavy use between 5 - 8 years.
Warranty on bearing ??? Not sure
Nov 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Electrolux washer is only 6 months old and the drum has started squeaking. What could the problem be?
NOT Solution - I just bought one last week and it squeaked for me today. Sounded like a belt. As the washer added more water to the drum to soak the clothes, the squeak went away. So not sure if belt slightly out of alignment - hence it rubs or perhaps a roller knob needs adjustment is what I am thinking.
Sep 23, 2009 | Electrolux AWF 1435 Front Load Washer
Brown streaks on white clothing in front loading washing machine
more than likly it is coming from the dryer. get a paper towel or a towel and run it between the inside of the drum and the front where they come together. stick it through the slot and run around the drum. do the front then do the back see if you see the same streaks. and let me know thanks
Jun 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washer doesn't get clothes clean.
A FEW THINGS TO TRY FIRST RUN YOUR WASHER EMPTY ON THE HOT WATER SETTING UNLESS YOU HAVE A CLEANING CYCLE THEN USE THAT THERES ALSO SOME NEW PRODUCTS OUT THAT YOU CAN USE TO CLEAN YOUR WASHER OUT BUT FIRST TRY THIS ITS FREE , ALSO CHECK YOUR DRAIN PUMP AND THE DRAIN PUMP FILTER TO MAKE SURE YOU DONT HAVE ANYTHING CLOGGED IN IT LIKE A SOCK AND LASTLY CHECK THE AGITATOR BELT TO MAKE SURE ITS NOT WORN SEND ME A UPDATE WE'LL GET IT FIXED DONT WORRY
Apr 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet ht...does not spin out?
run it with no clothes, wait the entire cycle because it only spins fast at the end, dont overload the machine.
Feb 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,389 people viewed this question
Dan Webster
Dan Webster
Sal De
