Question about Ricoh 4506 Copier
Our 4506 message says load SEF letter
It doesn't seem to be out of paper but I know I tried to print a color poster in 8.5 x 11 format and it didn't print
    Sniper:
  • 86 Answers
Check if the orientation of the printing document matches to the paper available in the copier's trays.
Load SEF letter: means Load Short Edge Feed letter (landscape).
Good luck and please rate me, thanks.
Posted on Jan 30, 2009
  • david
    david Jan 18, 2014
    I have a Gestetner 2640e copy it has a functional problel. it displayed functional probem sc 322 how can i soive this prolem
My machine is displaying error sc980
Posted on Oct 14, 2009
  • 541 Answers
Reset job and put paper in bypass and tell your driver to pull from bypass. it should work fine
Posted on Oct 11, 2009
Error Message on Dell 5100cn
check the page setting in the printer as well as in the print dialog box in the, if the problem persists then you have to send it for servicing
Apr 29, 2008 | Dell 5100cn Laser Printer
What is the difference between a display board and a poster board?
A poster board is just a type of display board. It is "used for displaying posters and other flat printed matter. It comes in large sheets in a variety of colors and is significantly larger than A2. In the US, the standard size for poster board is 22" x 28" x .05". It can be particularly light and flimsy, as it is primarily expected to support sheets of paper, photos, glitter, lettering and other small, light items that are glued onto it." (Wikipedia)
Oct 07, 2013 | Office Equipment & Supplies
Konica Minolta 1690MF causing Fuser Paper Jam error when printing color. Does NOT happen when printing black and white. (Paper is genuinely stuck entering the fuser). Why is the problem happening for...
I was wondering if the original poster of this problem found a solution. My printer does the EXACT same thing. B & W printing is perfect. Any color print jams in the fuser. The printer feeds the paper too far (from thin copy paper to cardstock) so that the top of the page is cut off. Konica sent me a new fuser but that did not solve the problem. Again, this only happens when printing any page that has color on it (even a document with only one letter in color). B&W printing is unaffected.
Aug 27, 2013 | Konica Minolta magicolor 1690MF All-In-One...
Message window shows "load mp
The printer tells you to insert a letter format paper in the mp (multi purpose) feeder (the manual tray).
If you press the GO key the print probably proceeds with print job (if has the paper loaded in mp feeder)
Jun 15, 2011 | Lexmark T634 Laser Printer
My lexmark t430 says load mp feeder letter. what does this mean?
You have send a print job from your application (ex. word), and the paper format in this appl. is letter. The printer tells you to insert a letter format paper in the mp (multi purpose) feeder (upper the tray).
If you press the GO key the print probably proceeds with print job (if has the paper load in mp feeder)
Feb 23, 2011 | Lexmark T430 Laser Printer
Dell 3110cn - Load MPF 024-969 letter plain error msg
dell mfp laser 3115cn giving me 024-969 no paper detected
Oct 26, 2009 | Dell 3110cn Laser Printer
I HAVE LASERJET 4 PLUS. WHEN I GIVE JOB FOR PRINTING THE PRINTER DISPLAYS A MESSAGE AS PC LOAD LEGAL. PLS HELP ME IN SOLVING THE PROBLEM
The document you're trying to print is formatted for legal size paper, and the tray contains only letter size. if it's a legal size, put legal paper into the MP tray, or override the setting and manually select "letter size" in the printer dialog box.
Apr 04, 2009 | HP LaserJet 4 plus Printer
Cannot print to legal size paper format
There could be a few issues causing this problem.
1. Your document size on the actual document you are attempting to print believes it is letter (which is the default).
To change this setting, you must tell the computer you wish to print on legal paper.
To do this in MS. OUTLOOK:
Put the curser at the top of the page
then...under 'File-Print-Preferences-Layout-Advanced-Paper size-change to legal (from Letter'
-slightly tedious...but follow along and this should help
2. The printer needs to be adjusted to hold the legal paper.
Open up the legal tray to adjust the paper holder to hold the paper snuggly...it slides roughly.
Hope this helps..if you need more assistance please ask...also please rate my solution.
PLEASE note that anything other than a FIX-YA is actually a negative rank...and will lower my success...I didn't make the system...but that is the way it is in FIX-YA.
thanks
bearb
Nov 10, 2008 | HP LaserJet 2605DTN Color Printer
you select the cassete of your printer it is saying to put paper by manual feed
Sep 11, 2007 | Dell 5100cn Laser Printer
Ricoh 4506 Copier Logo
1,371 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
