Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
I need to find a diagram and instuctions to replace a pump on washer Fusher and Pikal gwl 10 paert # 420324 pd
To replace a pump on the gw10 do this:
Unplug the washing machine
Tilt the unit back.
The pump sit right in front - disconnect the two wire connecters.
Lift the white locking arm at the top of the pump while turning the pump counter-clockwise.
The pump should pop right off.
Where did you buy a pump?
Posted on Feb 03, 2009
  • 145 Answers
Hi...
Pump replacement on a model 10 takes about 5 minutes and no tools. Just make sure the washer is empty first. Then tip the machine back, look in the front right corner underneath, you will see the pump. All you need do is unplug the power connector and the ground, Then press a little locking tab, and twist the pump to un-lock it from the mount. The new one goes in the reverse order. There are no hose connections, it just twists out and twists in. Very easy job.
If you feel you still need instructions, you can get a service manual from here:
http://www.fisherpaykelparts.net/ecart/category.php?category_id=53
Posted on Feb 01, 2009
Replace fisher paykel iwl 16 mother board with gwl 11 motherboard
I cannot find your mothers IWL16 model, but I have found various similar machines that are the same phase as your GWL11 machine, the electronics in there although different are compatible, you can swap the drain pumps, there almost universal, avoid the drive shaft machine, fix the other one If you want further help, post a photo of both pcb's (the electronics) After swapping your machine will stil require programming which is simple enough
Sep 14, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer won't drain
Could be something in the pump. The pump is on the bottom of the tub.
It has a locking tab which you release and then twist the pump a hair and it will fall out. Warning: Have rags ready! I have the original GWL service manual and the GWL 11 supplimental manual. Let me know if you want them.
Apr 28, 2010 | Fisher and Paykel GWL11 Top Load Washer
During the rinse cycle, our GWL 11 Fisher & Paykel
The problem is in the pump, so it will not pump out, you will need to find another way to empty it, removing the agitator will make the job easier.
When you get the water out the pump can be accessed from underneath, it turns anticlockwise to remove it,.
I would buy a new pump as it is most likely that is all that is wrong with it.
Apr 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Have an eco washer gwl 10. worked fine for years today stopped wokring. tried all trouble shooting and diagnostics. always coming up error code 43. replaced switch and no different. any idea?
Hi there
Try bridging the switch out(join the wires together) and if that doesnt work you may have to replace your motor controller module.
I hope this helps.
Nick
Aug 02, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
My GWL 15 pumps so hard water comes out of the
A washer cannot pump the water out too fast, regardless of what you have done or have been told, the problem is too do do with the drain outlet, I suggest you completely take apart the stand pipe and any other pipes connected, and thouroughly clean them .
Please rate my solution.
Thanks.
Jun 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
Gwl 10 washer
Check that the pump isnt blocked.
Mar 01, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Water leaks
sounds as if the outlet pump or hose may be blocked or part blocked
Oct 21, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
156 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
