Back to:
Tags:
Gateway FPD 1730  17 in. Flat Panel LCD Monitor
Green Light, no Display - Gateway FPD1730 (by 3 users)
posted by jmelissab on Jul 29, 2007
My Gateway system is about 5 years old. The 17" monitor FPD1730 monitor has produced a perfect display for all of this time. No dead pixels. No fading of colors or light. Crisp and clearimage. No issues at all.
Yesterday morning the display quietly and quickly shut off. The screen went to solid black. The green light stayed on, steady. No noise, smoke or other disturbances accompanied the stoppage of the display.
I hooked up an old monitor to my computer. Even used the same, undisturbed cables. Came on fine. No problems.
I tried moving the "bad" monitor to another computer. Green light, no display.
I contacted Gateway technical support, but all they said was "sounds like a bad monitor." Really!? Wow, I was so underwhelmed with their technical knowledge. As if I didn't know the monitor was "bad." What I wanted to know was, what causes a problem like THIS one!
I've done some reading about repairing monitors, but before I attempt anything, I'd like to know more.
Any ideas on what has beset this poor beast?
Comment by jmelissab, posted on Jul 30, 2007
I will try this. I have looked at DIY guides to replacing the backlight (don't know of anyone nearby that does this kind of work), and parts of the replacement seem rather daunting. For example, the DIY guide talked about using a Dremel tool to cut the plastic housing away from the replacement backlight. I'm not prepared to do this kind of work myself.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by arbyhayes, posted on Jun 19, 2008
My problem is exactly described in first two paragraphs except the monitor will come back on when I push the green LED - only to go to black again at its whim.
Comment by Guest, posted on Dec 13, 2007
I have the same problem. I tried the flashligh technique and could see text on the screen. Now I have to decide if it's worth getting it fixed.
Best Solution
posted on Jul 29, 2007
FixYa! (100)
tomj23
Rank:Guru Guru
Rating: 86%, 1560 votes
It could be your LCD backlight giving you problems. With the computer on and the monitor power LED green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. Depending on the monitor this is usually and economically repairable problem. Let us know if you have any other questions and please don?t forget to rate this posting.
Comment by tomj23, posted on Jul 30, 2007
Cutting plastic usually isn?t necessary; however it is not a repair I would recommend to the typical user. If you have excellent attention to detail, patience, experience with the disassembly and handling of electronics and the tools then give it a try. It is also important to also realize that by doing it yourself you risk the real possibility of damaging your monitor beyond economic repair. If you are OK with all of that then it may be worth a try.
Rating Locked! (?) jmelissab has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Green Light, no Display - Gateway FPD1730:
I don't want to Accept this solution
Solution #2
posted on Mar 09, 2008
Helpful (85)
cgn-KAZ
Rank:Apprentice Apprentice
Rating: 90%, 3 votes
I picked up a FPD1730 monitor for free which was just sitting out in my apartment hallway. I suspected something was wrong and sure e**ugh there was ** backlight, but I could see faint video when I shined a flashlight on it.
A quick Google search of the inverter model # led me to a German forum which suggested replacing the fuse labeled "F1" on the inverter board. I don't have a matching fuse on hand but I bridged the connection with a wire and sure e**ugh the backlight came back on. Short-circuiting like this is definitely **t 100% safe but if you can find a 4A fuse then it's a really cheap and quick fix.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Solution #3
posted on Feb 22, 2008
Helpful (85)
broomer01
Rating: 89%, 4 votes
Inverter Board
Rating Locked! (?) jmelissab has rated this solution as Helpful
Thank You!
Can you Help with these Monitors problems?
Monitors
I am trying follow the steps below, I can't turn the...
Monitors
I took my car in for an oil change about five weeks ago...
Gateway FPD 1730 (Platinum) 17 in. Flat...
on the right side of my computer from top to bottom is...
i could use the inverter but if your trashing the whole...
If you are trashing your monitor before doing so toss me...
Loading problems.
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
