Question about Maxtor Hard Drive
Hi,I have a 20gb maxtor harddrive model 52049h3 it's a master i would like to make it a slave how do i set the jumpers? thank you much
  • 916 Answers
Here is a link to the maxtor jumpers chart: Click Here
Posted on Jan 30, 2009
Maxtor 8175002 jumper settings
If you use one id cable with tow devices at that time you need hdd jumper master & second device slave mode of jumper.
http://itexpertinbd.blogspot.com/
May 10, 2012 | Maxtor Hard Drive
Maxtor hard drive jumper settings for model 7245At maxtor hard drive jumper settings for model 52049h3
1. Jumper settings for model 7245At refer to LINK
2. jumper settings for model 52049h3 refer to LINK
Hope it helps.
Jun 22, 2011 | Maxtor Hard Drive
Slave Harddrive I have an extra harddrive that I wish to install as a slave, unfortunately I cannot at the moment, due to some problems. First, the current harddrive I have is a Maxtor I believe, and it...
Dear soviet guy
these are the jumper settting for both the drives
please check that they are on the right place before if you want to use seagate as a slave try placing the jumpers as mentioned.
Maxtor Jumper Settings
Seagate Jumper Settings
Thanks
GAGAN GUPTA
Mar 17, 2011 | Microsoft Windows XP Professional SP3 Full...
Jumpers guide Maxtor 2B020H1 20Gb Slim IDE 3.5'' Hard Drive
Maxtor jumper as follow:
looking at the connector top row 5 pins, buttom row 4 pins.
the single pin on the top row is index pin.
master jumper is located between top 2nd pin and 1st buttom, counting from the left.
slave has no jumper on any of the pins.
cable select jumper is located between top 4th and buttom 3rd pin. counting from the left.
Apr 24, 2009 | Computers & Internet
Slave jumper setting
SATA drives don't have jumper settings.
You can set master/slave in BIOS.
Mar 29, 2009 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Change master to slave
if your hdd still have sticker from factory ( on top the silver side you can see MAXTOR brand) there is small information you can change "jumper" small plastic.
you can find instruction MS(master),SL(slave) or CL(Cable Select) so look at the back oh hard drive you'll find a small plastic (one)..take it out and change like the instruction sticker
Jan 30, 2009 | Maxtor Hard Drive
Maxtor slave jumper settings
Find the jumper settings for the maxtor harddrive on the following link. As per the model number you gave ,it seems like you have the maxtor diamond max drive.
http://www.tacktech.com/display.cfm?ttid=379
Thanks
proton
Nov 29, 2008 | Maxtor Hard Drive
Slave harddrive jumper settings
usualy its just one jumper if no jumper on maxtors becomes slave. jumper on 50 is master. if u use cable select.. on same ide another device must also be cable select.
if one is master other is slave on same ide.
Jul 15, 2008 | Maxtor Hard Drive
Maxtor 31536H2 Jumper Settings
Here is a picture of the jumper settings for most Maxtor hard drives:
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
May 15, 2008 | Maxtor Hard Drive
Maxtor 52049U4 20GB hard drive jumper settings
There should be a diagram showing how you should set the jumper. Set it according to what you want it to be and it should begin to should up. You can set it as Master, Slave, or Cable Select.
Nov 12, 2007 | Maxtor DiamondMax Plus D740X (6L020J1) 20...
Maxtor Hard Drive Logo
187 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
