Question about Nikon COOLPIX L18 Digital Camera
Communications error Whenever I plug my Nikon coolpix L18 into the computer, it always says "Communications error" I've tried unplugging and replugging the USB in but it is not working. Please help...
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Posted on Feb 07, 2012
SOURCE: lens error message on nikon
You have to push the lens back in.
Posted on Nov 07, 2008
robmcd27
  • 423 Answers
SOURCE: Nikon Coolpix L18 Driver
Try this, it may work without the software.  Turn off the camera. Plug the usb cable between the camera and the computer. Turn on the camera. If a box pops up on the computer asking what you want to do, scroll down and see if there is an option to view pictures. If a window opens up with all your pictures on it, great. Now open up a folder where you want to put your pictures. Bring up the other window with the pictures in it and hit the control key and the d key at the same time on your keyboard. Then drag your pictures to the window where you want them and let go of the mouse key.  They should all move over. Then you can use Windows image viewer to see them. Let me know if that works.
Posted on Feb 18, 2009
  • 20 Answers
SOURCE: Out of memory on Nikon Coolpix L18 camera
There are two ways
1. Upload ALL of your photos to your computer (best if you do this)
2. Buy a new memory card if you don't want to upload the pics to your computer. But keep the memory card safe
Posted on Aug 14, 2009
You can download the software here.
http://support.nikontech.com/app/answers/detail/a_id/16692
Posted on Mar 25, 2010
  • 11967 Answers
SOURCE: how to solve NIKON coolpix L18 lens error? The
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 13, 2010
Hi, I have had my camera for two years however for some reason it is not uploading to my computer.
Hi, I've found the L18 was always finicky with transferring photos, your best bet would be to get a usb card reader and put the SD card into that to transfer the photos.
Aug 29, 2011 | Nikon COOLPIX L18 Digital Camera
My Computer doesnt detect my camera
it wont show on window2000 it will show only in windowXP for window 2000 u need drivers cd of nikon coolpix install that 1st
Jun 17, 2009 | Nikon COOLPIX L18 Digital Camera
Connections error
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jan 30, 2009 | Nikon COOLPIX L18 Digital Camera
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Nikon Transfer or Picasa.
Jan 28, 2009 | Nikon COOLPIX L18 Digital Camera
Nikon transfer is not showing that my camera is connected
There is an alternate way of downloading images from the memory card from the camera.
Get a USB memory card reader, remove the memory card from the camera, insert it into the card reader, then plug the card reader into the USB port of your computer. You will now see card reader as an external memory device, open the folder and copy your photos onto your hard drive.
Jan 05, 2009 | Nikon COOLPIX L18 Digital Camera
You don't need the disk to transfer your pictures from your camera to your computer. Just take your sd card out of your camera and plug it into your computer. A folder with your pictures will appear on your computer. Copy them to a different folder on your computer, so you can take your sd card out and still have them on there.
If that doesn't work, plug the cable in that came with your camera, and hopefully that will work. I hope this helps. Please rate my solution.
Dec 26, 2008 | Nikon COOLPIX L18 Digital Camera
Nikon coolpi l18 is not being recognized by my computer
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Nov 20, 2008 | Nikon COOLPIX S5 Digital Camera
Transferring..........
hi
this might help try here for the manual http://support.nikontech.com/cgi-bin/nikonusa.cfg/php/enduser/std_alp.php?p_sid=wPB6U3Ri&p_lva=61&p_li=&p_accessibility=0&p_redirect=&p_page=1&p_cv=1.187&p_pv=&p_prods=0&p_cats=187&p_hidden_prods=&prod_lvl1=0&cat_lvl1=187&p_search_text=Nikon+COOLPIX+L3&srch_btn_submit=%C2%A0%C2%A0%C2%A0Search%C2%A0%C2%A0%C2%A0&p_new_search=1&p_search_type=answers.search_nl
riz.
Nov 18, 2007 | Nikon COOLPIX L3 Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
272 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
