Question about Acer Aspire 3000 Notebook
Flickering LCD I have bought an Acer Aspire 5920 13 August 2008. After few days the flickering problem started. I have sent the notebook to the Acer servicing center but they cannot provide solution. They have alredy change my processor & LCD but the problem continuing. Can anyone help me in this purpose??
  • jituprasun Jan 30, 2009
    Can you explain about the display adapter? or can you give me some a guideline so that I can direct those ******** sevicing engineer... please please help me... I have sent my notebook for servicing 6 times can you imagine that...
  • Dan rogers
    Dan rogers May 11, 2010
    It sounds like the display adaptor is having problems. I can't believe they did not fix this for you. It is definitely their responsibility to fix this for you. There is nothing you will be able to do if they replaced those parts and they should have known this
    Master:
  • 413 Answers
Yeah actually i can but if i didn't know any better i would swear you are dealing with HP. But I honestly think that the issue is your graphics card is not getting enough power. It can actually be a couple things bu i would start there. If that is not the problem start looking at the ram. If the ram starts to go bad or has a power issue it will mess up your display also. I am glad they replaced the processor. that would be the next place and from there it would almost have to be the power supply. One thing you have to make sure of however is that they can reproduce the problem when they have the laptop.
Posted on Jan 30, 2009
Acer aspire 3610 screen flickering
It sounds like your video cable or your Lcd Inverter cables might be loose. You will need to take the lcd apart to get to them. The video cable is on the back of the LCD screen at the top. Remove it, then push it back in and use a piece of tape over where it connects to hold it in place. Also remove the other end of the video cable from it's connection and plug it back in. The lcd inverter is at the bottom under the lcd screen. It has two cables going into it. Remove both cables and then plug them back in. Put everything back together and hopefully your problem of flickering will be solved.
Mar 30, 2012 | Acer Aspire 3610 Notebook
Acer 7530 screen flickers
hi
it flickers due to incorrect frequency setting.. LCD should be set to 60Hz. go to desktop, right click, graphics properties, display settings and set to 60Hz
Jan 02, 2012 | Acer Aspire 5630 Notebook
I just bought a brand new Acer Aspire 5534 laptop and the screen has been flickering on and off since I bought it. Its very annoying and I cannot get any work done. The place that I bought it from doesn't...
flickering is usually a lcd, converter or inverter hardware issue.try updating the video driver for that system if it still persist then it is a hardware issue..If you bought the system new their usually a hardware warranty that will cover it by contacting the manufacture.if not then I advise you taking it to the computer repair person to replace the hardware. hope that helps.
Feb 24, 2010 | Acer Aspire 4520-5141 Notebook
White lines on screen and flickering
I think this is the problem of LCD.if it is then u should go to nearest service center .
Sep 25, 2009 | Acer Aspire 5920-6727 Notebook
Flickering display of aspire 6930 notebook
replace your cold cathode florescent lamps in your lcd display screen
ebay sells them
May 28, 2009 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5920
There might be problem with signal cable of the LCD,Had you tried with external display .If same problem with external disaply then might your graphics card problem ,if not then certain problem in signal cable or the screen itself
Mar 14, 2009 | Acer Aspire 5920-6727 Notebook
How to solve Flickering problem of LCD
I have had the same problem,
I found it was my power supply transformer (part of power lead).
Some transformers may be faulty, or replacement transformer may not provide a voltage stable enough for the LCD.
Also check the wiring in your plug.
Safest option is, buy a genuine Acer supply transformer with plug lead from Acer.
Hope this helps (please rate my advice)
Jan 30, 2009 | Acer Aspire 5920-6727 Notebook
I have an Acer 5920G that's only 3 months old and it's screen started flickering. Updating or rolling back the graphics card driver made no difference. I then updated the Chipset driver from the Acer website. It hasn't flickered since!
The graphics info has to pass through the chipset so I assume the driver wasn't up to the job.
Flickering screen
If you bought it new in this last August, don't put up with it but get it fixed under the warranty. That is what warranties are for.
Jan 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Acer notebook aspire 5102 WLMi screen flickers
Hardware, sound like the cable that attach to LCD panel was losing...
Nov 17, 2008 | Computers & Internet
Acer Aspire 3000 Notebook Logo
106 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
