Ariston Technologies AW 149 NA Washer With 1400 rpm max and 16 lbs/7.5 kg. Load Capacity (AW149NA, AW149 NA, AW-1...
Problem for Ariston Technologies AW 149 NA Washer With 1400 rpm max...
Flashing Lights on Ariston A1636 & Won't progress to rinse either
By Hawks1980 on Jul 29, 2007
I have a couple of problems with my Ariston A1636 washing machine.
When I put it on Program 1 (Pre-wash), the machine fills for about 30 seconds, then starts pumping the water out and the door lock light flashes and also the 'Super Wash', 'Easy Iron' and 'Rapid' lights flash. The pump goes on for several minutes.
The other problem is that when I put it on Program 4, the cycle begins but never progresses on to rinse. The other day I put it on at 10pm expecting it to be complete by the following morning. When I came down at 7am the program was still running and hadn't moved off of the 'Wash' cycle.
Thanks
Tom.
Same Problem
Jan 08, 2008
-   I have the same problem superwash and rapid lights start flashing on the last rinse then machine stops ariston A1636 wonder if this is a common fault in them if so i reckon they should recall them hvent had mine 2 years yet but got no extra cover : (-   claraclogs
Solution #1
posted on Jul 29, 2007
Not Rated)
advisor
Rank: Guru
Rating: 86%, 212 votes
Suggest checking for a faulty heater.
Regards
Engineer
Was this helpful?
Yes
No
Popular Solutions for Ariston Technologies AW 149 NA
Questions and Unsolved Problems for Ariston Technologies AW 149 NA
Do you recommend Ariston Technologies AW 149 NA Washer With 1400 rpm max and 16 lbs/7.5 kg. Load Capacity (AW149NA, AW149 NA, AW-1...?
Answer
Answer
Hi experts, Our machine door won't lock.I have tried to adjust the door but there isn't any... (More)
Answer
Ariston A1635 Programme switch keeps clicking round. Cleaned filter, still not working. Does not... (More)
Answer
Hi, really appreciate if anyone could help me out. The machine works fine excepting spin dry only. I... (More)
Answer
Can you please tell me how to solve this problem? We have Ariston A1400WD and the draw where you put... (More)
Answer
i need an instruction manual for a6137 ariston washing machine
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ariston Technologies AW 149 NA...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14877
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
