Question about Gateway E-2000 Deluxe PC Desktop
How to open this box gateway e-2000
Tell me how??????
  • 2,229 Answers
Here is the link to the Gateway document that will tell you how to do it.
http://support.gateway.com/s/Manuals/Desktops/8508813/8508813.pdf
BG
Posted on Jan 30, 2009
Where is heater blower fan fuse on a 2000 olds alero? how do you tell if fuse is bad?
Pull it out an see if it's burnt . The fuse is located in the right hand instrument panel fuse box . HVAC BLOWER fuse 20amp . There is also a blower motor relay in the under hood fuse box .
RH IP Junction Block (fuse box)
In the right side of the passenger compartment , open the right door ,at the end of the I/P pull the plastic cover to see fuse box
Jan 29, 2017 | 2000 Oldsmobile Alero
Whats my gateway number
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for a line of output like: Default Gateway ..... 192.168.123.456
Whatever IP-address is shown is that of the gateway.
Jan 30, 2011 | Gateway Computers & Internet
I can,t connect to 192.168.1.1
Setup Steps
Windows 2000 and XP
  1. Click Start and go to Run
  2. In the Run box type CMD and click OK
  3. In the DOS window that opens up, type ipconfig and then press Enter
  4. Your IP address will be listed
Windows Vista
  1. Click on Start and in the Start Search box type cmd. You can either press Enter on your keyboard or click on cmd.exe when in appears in your search list.
  2. In the DOS window that opens up, type ipconfig and then press enter
  3. The IPv4 address will be a series of numbers following the pattern xxx.xxx.xxx.xxx, for example, 192.168.2.4.
Mac OS X
  1. Click on System Preferences on your dock
  2. Select Network
  3. Click on Built in Ethernet
  4. Your IP address will be listed on the right side of the box.
Open the browser now, and type whatever you see in the default gateway or router. For belkin, by default it is 192.168.2.1
But for the model you have selected, it will not prompt you for any password. The login password is also blank by default. You may encounter a login password while making any changes. If unable to open it, check the physical connections, and/or power cycle the modem-router, and/or check the browser settings.
For any further queries, get back.
Thanks for asking,
Arvind S Iyer
Sep 26, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Need password for my computer it's a gateway 2000 With windows NT workstation 4.0
Look for manual on how to reset CMOS and Possibly Password. It will take opening the case and moving some jumpers.
Nov 06, 2009 | Gateway E-2000 PC Desktop
I cant connect internet through hardwire(ethernet) but i can connect to internet by wireless... and it keeps on telling me Unidentified network.
Not really ...
1 thing that should not be in common between your wireless and modem is GATEWAY...
Your default modem gateway will be 192.168.1.1
change your router gateway to 192.168.2.1 or 192.168.3.1
to do this ...
1. click on start menu , type cmd , enter
2. COMMAND PROMPT dialogue box opens .
3. type . IPCONFIG
3. note your Default gateway.
4. open internet explorer
5. type your default gateway in browser address
6. it will prompt you to give user ID and password .
7 Your USER ID and password is ADMIN .
8. your router setup page opens .
9 change your local IP address to 192.168.3.1 .
10. Check mark on BRIDGING MODE .
11. Disable and enable your ethernet .
12 . now try connecting to INTERNET .
It should work . .
May 22, 2009 | D-Link Vonage-enabled Wireless Router...
Drivers for an E2500
Go here to gateway's driver site...enter your serial number in the box and gateway will provide you with the drivers you are seeking :
http://support.gateway.com/support/drivers/dlcenter.asp?Tab=My
Regards..
Mar 17, 2009 | Gateway Computers & Internet
How to open this box for gateway e-2000
The front cover for that Gateway in my picture is hinged at the top front corners; the inside surface of it is showing face-up (black) on the top of the case. Flip it upward, around and down to cover the front panel; on the top of the left side cover there's a press-in latch button (kinda rectangular, in the recess that the front cover was hiding). Push that latch button in (toward the outside surface of the side panel) then pull the top of the panel outward and down, away from the case as if the panel was hinged at the bottom. Once the panel's at a 45º angle, you can lift it up and away from the case.
Your case is similar, I'm sure. Look for a semi-hidden latch button hiding in the recesses.
also check ou this link
click here
plz rate this post as good as u can, so we can help others.
Jan 30, 2009 | Gateway E-2000 Deluxe PC Desktop
Connection problems with secondary computer
hi
the key code is the security code or the password that is enabled in the router,are you trying to connect to you own comcast network or to someone elses??
if you are conecting to your own comcast network then you need to log into the computer which can go online using you comcast box,once you are in that computer you need to go ahead and click on start,run in the box type in cmd and hit enter,it shud open a black box for you in this black box go ahead and check the default gateway an example of default gateway wud be like this no 192.168.1.1,make a note of the default gateway and open an internet explorer page now type the default gateway in the address box without http,it shud open the router page for you from comcast,it will tell you to put in the user name and password,the default for comcast is username is comcast and password is 1234 incase you cannot login you can contact comcast so that they can reset the password for you,once you are in this page you will see the wireless setting click on it and there you will see something wghich says wireless security or wep key or authentication key that is the key code..u can now use this key code to connect to the network....
if you are trying to conect to someone elses network thent he person who has setup the wireles comcast network will be able to give you the network key...
vedhick
Jan 21, 2009 | Dynex Wireless-G USB 2.0 Network Adapter
My router has high security settings and i would like to change them to actually play with no problems on my xbox 360 and be able to go around the internet freely my router's model is CT-5361T help would...
hi...
here is a link where you can go ahead and download the manual of the router and check what are the different tabs in you router and how you can go ahead and change the security settings..
here is the link it is a pdf file...http://www.comtrend.com/dbase/download/CT5361T_A3.3.pdf
this has all the settings for the router and how to make a change..
before reading this find the default gateway from you computer,click on start,then run,type in cmd and hit enter,
once you hit enter click on ok,you will get a black box,in that box type in ipconfig,check the default gateway..
now open a web browser,the place where you type in the address,empty that box and without http or www,type in the default gateway once you put the default gateway and hit enter,it will tell you to put the user name and password
the default user name is root and password is 12345,it will now open the router page now you can go ahead and check the manual and see how you can choose different type of security settings...
vedhick...
Jan 15, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Hi, i need the gateway number for the d-link DES1008D can sombody tell me please how to find out the gateway number.
The D-Link DES1008D is an unmanaged switch. Hence it does not have any gateway address and none can be set on it.
If you are looking for the gateway address of your computer, here's how to find it.
In Windows 2000 / XP / Vista / 7, Open command prompt and type in ipconfig
Look for the IP address of the default gateway.
eg:
C:\>ipconfig
Windows IP Configuration
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
IPv4 Address. . . . . . . . . . . : 192.168.1.100
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
Hope this helps.
Regards.
Jan 09, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Gateway E-2000 Deluxe PC Desktop Logo
340 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
