Question about Toshiba 46H84 46" Rear Projection HDTV-Ready Television
No picture, sounds fine. Fuse blown
The picture is blank on my tv and it keeps resetting itself as if the bulb was blown. I checked in the back and pulled out a unit that seems to contain the ballast and the bulb, I immediately saw a blown 2A fuse. I changed the fuse, the tv came on and worked for a minute and blew the fuse again. Ballast? Please help, thanks!
  • Anonymous Aug 01, 2007
    I"m sorry, I posted the tv in the wrong forum, it's actually a toshiba 50hm66
    President:
  • 3,130 Answers
This set, I am sorry to say has no bulb and has no ballast circuit. There are three picture tubes inside this TV set. What exactly was the part you pulled out? Can you post a picture of the Part you pulled out?
Posted on Jul 29, 2007
  • Larry  Dillon
    Larry Dillon Jul 31, 2007
    what was the part you pulled?
  • Larry  Dillon
    Larry Dillon Aug 01, 2007
    Yes this set is a DLP, I would start out by replacing the ballast assembly first. I have seen this cause the fuse to blow out countless times. part for this set is located here http://www.partstore.com/Part/Toshiba/To...
    part number is
    75002006 Good Luck
SOURCE:
LG 42PC!R Plasma TV turns on and then green led blinking with no ppicture and sound !
Your problem is most likely a fried circuit board. I always connect my good electronic to a back up battery. but your problem might have been storm or surge related, I would take it to a repair center and get an estimate.
Sep 19, 2014 | LG 42PC1R 42 in. Plasma HDTV
TV will not turn on
Hi, It could well be the power supply that is in the back of your set. Have a repairman check it out. It's not a do it yourself thing. Good luck.
Nov 21, 2012 | Panasonic PT-44LCX65 Television
TV TURNS IT SELF OFF AND ON I HAVE A LG 42'' MODEL 42PC3DV
hi,
you need to replace it.I think it is 4AH250V. You can buy it from any electronics shop near u or u can get it from ebay.com
Thanks!
Sandy
May 22, 2009 | LG 42LC2D 42 in. LCD HDTV
My RCA big screen tv shuts off and comes on by itself.
on top of the fuse it sounds like the power supplie is going bad
Dec 03, 2008 | RCA P61310 TV
No picture
Have you tried checking the fuses this is a solution i posted a little while ago!!! I was watching tv there was a popping noise and screen went blank. My husbands very practical and we took the back off the tv ,we tested the fuses with a fuse tester and one had blown we took the fuse too Maplin our nearest electrical wholesaler who found us new fuses £1.29 for a pack of 10. We replaced the blown fuse now everything works as it should. Hope this helps we saved about £275 by doing it ourselves but do make sure you feel competent enough to have a go its not that hard but do make sure you unplugg the tv from the electric before you attempt taking off the back and checking the fuses and be careful as tvs can store a electric ok
Feb 24, 2008 | LG RU-42PX10 42 in. HD-Ready Plasma...
Toshiba 43A61 Projection TV No picture, no sound
Two things to check on these when you get a black screen and only the power light, either a bad bulb or a bad fan. You can check the bulb, pull it out and get a meter and check for continuity across the two pins on the bulb, no continuity the bulb is blown. Also once you have the bulb out you will see the cooling fan in there, a vacuum and a air compressor to blow it out good is helpful. Check the bulb, clean it well, and try again. The blown fuse could also have been due to a stuck fan or blown bulb, i have seen the bulb blow and take out the fuse before on projection TV's, i have also seen cooling fans so full of dust and crud that they are stuck and drawing more amperage then they should and popping the fuse. I assume the 1.5a fuse that blew was on the mainboard inside? Some have an external fuse near the power cord input as well, but thats generally more then 1.5a.
Jan 11, 2018 | Toshiba 43A61 43" Rear Projection...
Sony trinitron 32" just powered off by itself and won't turn back on.
Sounds like you all have a bad bulb that needs replaced.
This is a common problem.
Nov 19, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture and no sound
it needs convergence ic's.This unit has a auto-blank circut if it detects a problem with the conv. ic's
Mar 04, 2007 | Hitachi 53FDX01B 53" Rear Projection...
Sony tv picture keeps flashing
You likely have bad solder connections around the tuner area. This model has a history of problems in that area or the tuner itself.
Aug 29, 2006 | Sony KV-32S35 32" TV
Toshiba 46H84 46" Rear Projection HDTV-Ready Television Logo
206 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
