Question about RCA D52W19 52" Rear Projection Television
Convergance adjustment I can't find the convergance adjustment on my rca tv with a universal remote . how do you get the crosshairs to come up?
  • RCA Master
  • 8,617 Answers
If the convergence option is missing from the on screen menu you will need to replace DL231, CL230, and FL231 to restore the option. You can get the parts and instructions at the following link for less than 20.00. They also most likely have the original remote for your set also. Leave them a email to inquire.
http://servicemanuals.vstore.ca/
Posted on Jan 31, 2009
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    Tip
    How to set convergence on Projection TV ' s
    I have given an general explanation on most projection TV ' s
    1. Enter the menu on your TV. Use the remote control and bring up the menu.
    2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
    3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
    4. Press "Enter." A crosshair pattern will appear on your screen.
    5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
    6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
    7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
    8. Repeat these steps for all colors.
    on Mar 18, 2010 | Televison & Video
    It has tripple vision and looks like a bow tie.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
    To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
    To process and save the adjustment made, follow the steps below;
    1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
    2. Enter the menu on your TV. Use the remote control and bring up the menu.
    3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
    4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
    5. Press "Enter." A crosshair pattern will appear on your screen.
    6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
    7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
    8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
    9. Repeat these steps for all colors.
    Take care
    Jul 06, 2010 | Televison & Video
    I have a Philips 51PW9303 Rear Projection TV that had blue shadows around the sides of the screen and now has a green and red bowed line at bottom. Does I need a convergence board to solve this?
    If the following doesn't work the tubes could be at the end of life:
    Adjusting convergence:
    Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
    To adjust the convergence of the picture tubes:
    1. Press the 'MENU/SELECT' button on the remote.
    2. Press CURSOR RIGHT to enter the PICTURE menu.
    3. Use CURSOR DOWN and RIGHT to select and enter MANUAL CONVERGE.
    4. Press CURSOR RIGHT to select CONVERGE RED or press CURSOR RIGHT and DOWN to select CONVERGE BLUE.
    5. A crosshair will be shown on the screen. If there is any red or blue fringe around the crosshair, use CURSOR RIGHT, LEFT, UP, DOWN to try and merge the fringe colors with the crosshair.
    6. Press the 'MENU/SELECT' button to return to MANUAL CONVERGE menu.
    7. Press the 'EXIT' button to exit the menu.
    If you are satisfied with the convergence you may stop now. Otherwise, you can continue and adjust the convergence more using mult ipoint convergence.
    To Adjust multipoint convergence:
    2. Use CURSOR RIGHT to enter the PICTURE menu.
    3. Use CURSOR DOWN and RIGHT on the cursor ring to select and enter MANUAL CONVERGE.
    4. Press CURSOR RIGHT and DOWN on the cursor ring to select MULTIPOINT RED or MULTIPOINT BLUE.
    5. A grid of crosshairs will appear on the screen. If there is any red or blue fringe around any of them, press CURSOR RIGHT to enter NAVIGATE mode.
    6. Use CURSOR RIGHT, LEFT, UP, and DOWN to move to a crosshair that has a color outline.
    7. Press the 'EXIT' button to enter ADJUST mode.
    8. Use CURSOR RIGHT, LEFT, UP, and DOWN to merge the color with the crosshair.
    9. Press the 'STATUS/EXIT' button to return to NAVIGATE mode. Repeat as necessary.
    10. Press the 'MENU' button to return to the MANUAL CONVERGE menu.
    11. Press CURSOR DOWN until SAVE MULTIPOINT is selected.
    12. Press CURSOR RIGHT to save the multipoint settings.
    13. Press the 'EXIT' button to exit the menu.
    Apr 03, 2010 | Philips 51PW9303 51" Rear Projection...
    How do you set convergence
    What is your Make and Model number?
    I have a Philips 46PP9302 and can't find the Quick Setup guide. I'm wondering if it is located on-line. We moved our tv and want to recalibrate it.
    http://www.retrevo.com/support/Philips-46PP9302H-TVs-manual/id/278ci462/t/2/
    The above link should take you to the location where you can view all the parts of your models manual. Select the area of interest and rad onlinje
    Please rate my help++++Thanks for using FIXYA
    Nov 24, 2009 | Philips 46PP9302 46" Rear Projection...
    Convergence
    If the convergence can't be adjusted with the remote are if a tech comes out and he can't adjust it from the back of the set or the SAM replace the SSM part number 313503710091 that's where the convergence adjustments are done.
    Aug 19, 2008 | Philips 60PP9202 60" Rear Projection...
    Fine tuning grid on my Samsung HDTV with remote.(BP59-00048)
    To adjust manual convergence on your projection TV, follow theses steps:
    1. Turn your TV on.
    2. Let it warm up for 30 minutes.
    3. Press the Menu button on your remote. The Main menu appears.
    4. Use your remote to select Function, and then press the joystick.
    5. Select Convergence, and then press the joystick. The Manual Convergence screen appears.
    6. Select Red, and then press the joystick. A series of crosshairs appears on the screen.
    7. Select one of the outside crosshairs by moving the joystick up/down/right/left or by pressing the 2 (up), 4 (left), 6 (right), or 8 (down) buttons on your remote. The method you use depends on the model of remote you have. Note: You must do the outside crosshairs first.
    1. In the crosshair you selected, if you can see a horizontal red line, use the CH up or CH down buttons to move the line so that it is superimposed on the horizontal center line of the crosshair. Note: Make the single horizontal line as white as possible.
    1. In the crosshair you selected, if you can see a vertical red line, use the Vol + or Vol - buttons to move the line so that it is superimposed on the vertical center line of the crosshair. Note: Make the single vertical line as white as possible.
    1. Repeat for all outside crosshairs, and then for the inside crosshair.
    2. Return to the Manual Convergence Screen, and select Blue, and then press the joystick.
    3. Repeat Steps 7 through 10 for Blue.
    4. Press the Menu button on your remote to exit.
    Important: The directions above work for most Samsung Rear Projection TVs. Yours may be different. For exact directions to perform manual convergence, see your user's manual. If you don't have your user's manual on hand, click HERE to view your manual on line.
    If you cannot get your Projection TV to converge, it may need to be serviced. To arrange a service appointment, call Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your TV's model number and serial number on hand when you call.
    Jan 05, 2008 | Samsung BP59-00016A Remote Control
    Convergence/convex problem
    concergence ics are probly bad mitsubishi had different codes for each module to go into service mode.
    Apr 02, 2007 | Mitsubishi VS-50501 50" Rear Projection...
    RCA D52W19 52" Rear Projection Television Logo
    Top RCA Televison & Video Experts
    jason
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
