Question about Xerox Phaser 8560MFP Laser Printer
Our xerox 8560 mdf printer shutdown when i was doing firmware update now it show only testing everything on printer and shutdown itself all the time
  • Anonymous Jan 31, 2009
    could you please tell me where is the nvram stick
    thank you
  • Anonymous Apr 19, 2009
    I have the same issue, tried to flash and a brownout occured :(
    I have tried your steps with no success, the printer goes through a successful post test and then restarts.
    I ordered an NVRAM chip. After it is replaced is another firware load in order? Is there anything short of putting the chip in correctly I should be aware of? It can be taken to a service dealership but is on the second floor of my apartment and almost killed me carrying it up there.
    enternamehere@earthlink.net
    President:
  • 2,072 Answers
Most likely you will have to replace the NVRAM.
If it doesn't fully load, it most likely ruined the memory.
If you want to know how I know this, it's not from the successful upgrades I have done, I never do an upgrade without a spare NVRAM stick.
I would say its about 99 percent certain that you will have to replace the NVRAM for the machine to work properly.
Now, that being said, what you can try is removing the RAM and powering the machine up without he chips in, then reinserting them and booting it back up , Sometimes the memory will overwrite and come back up with the old version.
Posted on Jan 31, 2009
Error message on xerox 8560 09,038.46:13269
Go to the Xerox.com website and follow the troubleshooting aid to these types of faults.
Good luck.
Feb 26, 2015 | Xerox Phaser 8560/YN Printer
Master reset xerox 8560 printer
Your Administrator Guide book should have these instructions listed for you. It should be on the CD's that came with the printer.
If you have lost/misplaced them, you can download the guides from the Xerox.com website.
The steps below are what I did from my laptop as a Repair Technician:
1. Connect a crossover cable between the PC and system. To print an Event Log or Runtime Log:
2. Verify the system is Ready.
3. Use the system's control panel to enable AutoIP:
a. Select the system Setup menu.
b. Select the Connection Setup menu.
c. Select the Network Setup menu. 5. The page should now print.
d. Select the TCP/IP Setup menu.
e. Set AutoIP to On.
f. Exit the menu so the system is Ready.
4.
NOTE: To print the Connection Setup or Configuration page, select the system Setup
menu.
Reset the system to cause AutoIP to assign a new IP address (cycle power or select
Restart system from the Shutdown menu).
5. After the system's IP address is set, test communication by sending the "PING" com-
mand.
6. If the test fails, install a different cable and retest.
Sep 27, 2014 | Xerox Phaser® 8550, 8560, 8560MFP Extended...
08,030.46:45203 error code with xerox 8560 printer
Are there obstructions or spilled ink on the Wiper Blade, the Head Tilt Gear drive path, or under the Printhead?
Is the Waste Tray overfilled?
Clean the inside of the printer and retest
Mar 10, 2014 | Xerox Office Equipment & Supplies
Xerox 8560 error code 07,007.40
That error signifies a problem with the printhead tilt, you need to replace the Process motor camshaft pivot kit, part number 8560-Z2.
http://www.iteminconline.com/8560-z2_8560-z2-xerox-8560-process-motor-camshaft-kit.htm
Feb 07, 2014 | Xerox Phaser 8500/DN Printer
Printing from wrong tray
I suffered from the same problem for a long time. We got Xerox Phaser 8550 and 8560 here. I choose on computer "tray 2" but the printer just print from tray 1 which is empty.
Today i figured it out! It's some configuration at the printer. So go to "Paper tray setp" -> "Tray 1 mode" and "Tray 2 mode" -> change to "static".
I figure it's like this. Before it was "dynamic", it probably means the printer decides it's better to use tray 1 even though you choose tray 2 - and this decision is stupid. Changing it to "static" fixes this.
Let me know whether this works for you too!
Feb 12, 2010 | Xerox Phaser 8560MFP Laser Printer
WAX INK STUCK IN A XEROX 8560 MFP
If you lost power or unplugged this unit without first allowing it to perform a full shutdown, you are most likely seeing the wax ink 'dumped' internally. You'll need to contact a certified Xerox technician in order to get the unit cleaned and repaired.
Sep 03, 2009 | Xerox Office Equipment & Supplies
Xerox Phaser 8560
you could also try rebooting the machine. i've seen it happen that the new maintenance kit was recognised as new after a reboot. choose the standard shutdown method...
Jun 22, 2009 | Xerox Phaser 8560N Laser Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
Install wiper on xerox 8560 dn
The user guide is available here http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=8560&Xlang=en_US&Xcntry=USA&prodName=Phaser%208560
Also, I think there are two wiper blades on the 8560, one is on the maintance kit and the other is supposed to be removed, that was the old 860 that could remove theirs. Perhaps cleaning it will be fine. just open the top of the machine and its right there, give it a wipe and it should be fine. The other wiper blade on the maintanance kit and here is a link below to show you how to clean it!
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=355,E=0000000001343253407,K=1300,Sxi=12,Case=obj(902)
You can use this site to troubleshoot any problems with Xerox printers.
Niallbt
Feb 17, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8560MFP Laser Printer Logo
566 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
