Question about HP Compaq nx9030 Notebook
Forgot BIOS password.
How to reset BIOS password?How do I reset the BIOS? Where is the RTC battery located in the nx9030 notbook? How do get to this battery?
  • 1 more comment
  • dmckee Jan 30, 2009
    I am looking for an RTC battery on this HP Compaq nx9030 notebook. But, I cannot find it. Also, the HP parts document does not list this battery. Where is the RTC battery located on this notebook?
    I am looking for the RTC battery on an HP Compaq nx9030 notebook to reset the BIOS. Where is this RTC battery located in this notebook?
    Thank You for confirming that the RTC battery is on the motherboard. Now, I have to start the notebook disassembly process to locate the RTC battery.
  • 64 Answers
There are several software apps that may help you change the password without tearing the comp apart.
try CmosPwd    at this link: http://www.cgsecurity.org/wiki/CmosPwd
  or IBios located at this site>  http://www.11a.nu/software/bios-pc-bios-security-and-maintanance-toolkit/  download the DOS version .
Good luck and please rate this answer.
Posted on Jan 30, 2009
  • HP Master
  • 19,396 Answers
The Cmos battery on Compaq NX series is at the back side of the motherboard, so that you have to disassemble the laptop completely to lift the motherboard and remove the battery.
Youy find disassembly instructions below:
HP Pavilion ze4900 Notebook PC, HP Compaq nx9040, nx9030, nx9020 Notebook PC, Compaq Presario 2200 Notebook PC - Maintenance and Service Guide
    Sergeant:
  • 250 Answers
you have to remove the RTC battery, wich is located under the systemboard! So it is not an easy task to do...you colud have a look here: http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentTyp
e=SupportManual&lang=en&cc=us&docIndexId=179111&taskId=101&prodTypeId=3
21957&prodSeriesId=424677
    Sergeant:
  • 378 Answers
the rtc battery is on the motherboard.i doubt its the problem. If you have a voltmeter check your charger to make sure it is working. then make sure battery is charged with the voltmeter. try and run the system without the battery in, just using the ac adapter. if it works with the ac adapter and not the battery your battery probably needs to replaced as its been charged and discharged too many times. you might want to just reload the os. the link i gave gives disassembly to all toshiba laptops. the rtc battery on the motherboard looks like a watch battery. it should be good for 5 years or more. your laptop battery will go long before the rtc battery.
well, if the clock is still losing time, i would go ahead and replace the rtc battery as it is cheap, if you can do the repair yourself. typically when the clock loses time it is the rtc battery, but might be the clock chip, both are cheap and cheap to replace.
I would not replace the motherboard, not that , that is that difficult, but new lap tops are so cheap these days. i would go through the laptop manual, it should have where the rtc is located on the motherboard. the manuals are typically on line at toshiba. if you cant find the location, i would contact toshiba or post that question on their board. alternatively you could take it into a best buy or circuit city and they might charge you $50 to $80 to look at the computer, then you can determine if you want to have it repaired as they will diagnose the problem. if it is the rtc clock battery they can tell quickly from a voltmeter and the mother board schematic and manual. so you might get your lap topped fixed for under 100.00. toshiba should have a list of authorized repairers so you can call and find who can give you the best deal. the rtc will be near the processor and the batter will look like a round, flat watch battery. so you can pull it out, and in general just find the same voltage and size and replace the battery. i dont have anymore time to help you.
good luck
    Genius:
  • 3,422 Answers
HI,
Unfortunately it is not easy to replace the RTC (CMOS) battery in a Toshiba Tecra 9100 laptop. In order to replace the battery you will have to take it apart and remove the top cover assembly. The RTC battery is connected to the power board. It’s really hard to see the battery on this photo, but it’s there. You can find a new RTC battery for this model if you search on the Internet by the following part number:
  • 679 Answers
There is no such easy way to reset the BIOS password for laptops. if u want to reset it follow the below link.....
http://www.tech-faq.com/reset-bios-password.shtml
Thanks for using FixYa.
  • rockfixya
    rockfixya Jan 30, 2009
    by removing the battery BIOS password is not reset for laptops, but it is helpful in cases of Desktop PC as default BIOS is restored.
    Brigadier General:
  • 5,158 Answers
    President:
  • 2,110 Answers
The Battery is located on the motherboard..
  • Sibananda Jena
    Sibananda Jena Jan 30, 2009
    You have to open your notebook and change the
    battery on the mainboard. I think it's a normal battery like on a
    desktop PC's mainboard.
    Genius:
  • 1,665 Answers
Hi! Try remove its baterry and replace.
My wipro notbook MODEL WIVNB7710 I can't boot they asking bios password so plz give me solution
insert bios password that you insert in your bios
if you forgot it, plug off bios battery and then plug on again it will reset bios password, but be carefull usulally bios password is in mainbard be carefull if you dindt wish to have more damage
i hope this helpfull, please rate very helpfull if you think this helpfull
thanks for using fixya
Jan 20, 2011 | Computers & Internet
How do you reset the power on password on a Compaq 6720s laptop
Hi There,
If you're trying to describe the BIOS password, then this link is the best information website on the subject I've ever run across. Best of luck....
http://www.tech-faq.com/reset-bios-password.html
Aug 04, 2010 | Compaq Presario Notebook
Forgot my power on password
Remove the battery and to the power cord.
Remove the two screws that secure the keyboard. After removing the keyboard, remove the battery “RTC” to stop providing energy to epprom BIOS. After the upgrade or downgrade, or any repair, leave the Laptop for 5 minutes, without any source of energy.
Then connect only the power cord without battery and without the battery “RTC” of the Bios.
then turn on the pc without the battery and press f10 change the admin password put the battery of the laptop again not the rtc battery then save changes and exit, reeboot with the win xp disk inside , change boot order and done i garantied it work install xp and then connect the rtc battery done. jajaja easy
Aug 11, 2009 | HP Compaq nx6110 Notebook
I Forget the BIOS setup password
When you start your computer, tap F2 key to enter the BIOS setup. In the security menu is the area for removing/resetting BIOS password.
Feb 18, 2009 | HP Compaq nx8220 Notebook
Power On password has been enabled on the notebook
The power on password is configured from the BIOS and removing the BIOS battery will not reset the BIOS and remove the password as it is stored on an EEPROM chip.
This password is to protect unauthorized access to data on the laptop and the hard drive. There are no backdoor passwords available.
Ask the person who set the password, then you will be able to remove it by going into the BIOS setup.
Jan 30, 2009 | Computers & Internet
Location of RTC battery
The CMOS battery is on the back-side of the motherboard on the nx9030. You'll have to lift the motherboard up to gain access to it.
Aug 25, 2008 | HP Compaq nx9030 Notebook
Reset ecs notebook bios password
send me ur email and I'll post u software to reset bios and passwords then u can enter bios easy.or you can remove rtc battery for 5min then replace thus resetting bios.
Apr 09, 2008 | Computers & Internet
1.) Unplug AC, take out the main battery.
2.) Take out /disconnect the RTC (real time clock) battery for app. half an hour (the period of 5 min as specified in the MSG normally is not long enough).
3.) Plug in the AC adapter (batteries still removed); computer should boot automatically, if not use the power button.
4.) The machine will boot and show the 162-error-msg "system options not set". Use F1 to save the settings.
5.) Shut down the computer and disconnect AC power again.
6.) Re-connect the RTC-battery.
7.) Install the battery pack(s).
8.) Restart the computer.
Caveat: All settings are set back to factory standard.
You'll have to enter a correct date/time and change the settings to your needs.
Note: pls strictly keep to the sequence.
Re-starting with the main battery and or RTC-battery inserted will spoil the job.
Feb 19, 2008 | HP Compaq nx9030 Notebook
Don't know the Power on Password
Is the bios protected by the same password, usually it isnt. If you can get on the bios you can disable that HDD password. Other than that I dont know much about HP's and their set ups, sorry.
Jan 26, 2008 | HP Compaq nc6320 Notebook
Bios/startup password
yes, it will still be charged, to reset the bios password you need to locate the cmos battery on the motherboard and remove it for 10 mins or so, but where exactly the battery is situated, i'm not sure.
Apr 17, 2007 | Toshiba Satellite M45-S265 Notebook
HP Compaq nx9030 Notebook Logo
163 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
