I lost my pass word and cannot add a computer this is for my wireless router
    Problem Solver:
  • 16 Answers
The only solution here is to manually reset your router (usually a pushbutton on router)then go into router and reinstall settings. Make sure you write down all your known setting before doing this, and you know the default router address, ID, and PW, before doing this. This information is usually available on the router manufacturers website.
TIP- after its set up, write the SSID, user ID, PW, router IP, and security key on the router.
Posted on Jan 30, 2009
I have lost my registration/password to add computers to this wireless system at my home. What should I do?
use a pencil or pen to push the little reset button on the back of the modem, resets the user and pass
Feb 24, 2011 | Westell Wirespeed VersaLink...
I am using time warner cable high speed internet. and trying to connect my ps3 through a belkin router but it is not working. the wireless icon pops up from the router but what is a WPA Key??? HELP!!!
WPA === Wireless Protected Access
It's a level of encryption between the router and each wireless device, to add "security" to your wireless traffic.
Use an Ethernet cable to connect the network-port on a computer to one of the LAN ports on the router.
Restart the computer.
Start Internet Explorer, and connect to the web-server "inside" the router.
From this web-interface, you can set an SSID and set the encryption-level (e.g., WPA) and you can set a password/pass-phrase/pass-key for your wireless network.
Use the same SSID and password on your PS3.
Aug 29, 2010 | Computers & Internet
Lost my pass word wireless router linksys by cisco
Are you looking for the wireless password or the password of the router?
If you want the password of the router, then try the default password of the router. If the default password doesn't work then you will need to reset the router and reconfigure the router.
If you are looking for the wireless network password, then you will need to open the set up page of the router. Is there any computer connected to the router ? If not then you will need to connect the computer to the router. Or any other computer which is able to go online using the router. Check the IP address on that computer. open the set up page of the router. Set up page of the router is the page where you will find all the settings of the router. under the wireless section you will find the wireless network password
Click here for more information about the routers and wireless network.
Apr 23, 2010 | Linksys Wireless-G Broadband Router
Dsl wont pass thru router wired or wireless I have reset the router several times, the computer shows connected ,signal strenght excellent, but will not connect to the internet wired or wireless as long as...
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 28, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Lost my user name and need to add new computer
Are you trying to connect to the wireless network ?
Or your new computer will be connected to router with the cable.
If it is hard wired to the router and the router is working for the other computers then you don't need to change anything on the router.
If you are trying to connect to the wireless network then you should know the wireless settings of the router.
Click Here for step by step solutions
Nov 06, 2009 | D-Link DIR-300 Wireless Router
Lost my key number
Connect your computer to the router via Ethernet cable. In that way, you will see the WEP key assigned in your Router's GUI/page. You will see it in the Wireless section of the Router. Once you get the WEP key, enter it to the new PC to gain access to the Wireless connection.
Oct 15, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
I lost my wpa key number and have now reset the router - help!
You need to connect your computer hardwired to the router and reconfigure it. On your wireless computer, you need to delete all the preferred networks and add a new wireless profile.
Oct 06, 2009 | Apple AirPort Extreme Router
Don't know how to retreive my pass word?
you are going to have to consult your router manufacturer, and have them re-set the password for you.
Aug 06, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Need to retrieve pass word
If you have a new router, try accessing your router configuration page and set a new wireless network name and a new wireless password.
Jan 30, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Wireless router pass word
sakoz,
You have to reset your router. There is a small reset button on the back, which you have to hold in for at least 15 to 20 seconds if I remember correctly.
You should be able to then log back into it with the factory preset it came with.
Please let me know if this helps. Good luck!
Mar 01, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
