ITEM CODE: SI637BB My name is Pamella Bennet and I own 2 Ionic Breezes. Both of them are malfuctioning. Whenever we turn them on they hiss. We have cleaned them thoughly, blown them out wth air, turn them upside down as the manual suggests. We have tried everything yet they still hiss. We have not been able to use them for over a month. We received these in April or May 2006 (order #P-2205990) and usually when they start hissing, we clean them and most of the time the hissing goes away after awhile. But now they won't quit. Please tell me what my options are. Thank you, Pam Bennett 827 -A Stewart Ave Lewiston, Id 83501
-   I have 2 ionic breeze quadras about the same age 2006. 1 is hissing which I can see is the result of arcing at the top of the unit. Mine will turn itself off after 20-30 seconds. blades, wires squeaky clean... removed front and back grid, cleaned. blew out top.... still not working..... other one working fine. -   mdcitrus
I have the same problem. The one thing that I DID notice is that it seems to occur more often in winter. Thus, I attributed it to dryer air conditions--too much static electricity being the culprit. With the unit off, I sprayed a fine mist of water into the housing and that cured it for a (albeit-short) time. Best solution would be to increase the humidity via a humidifier...
have an old airconditioner that no longer works attached to bedroom wall unit under house pipes and...
(More)
have an old airconditioner that no longer works attached to bedroom wall unit under house pipes and lead go through hole in wall along wall in next room need to know how to remove whole unit thanks
Cleaned the filers. Reset the filter so the light would go off and now the unit doesn't work. Tried...
(More)
Cleaned the filers. Reset the filter so the light would go off and now the unit doesn't work. Tried unplugging, plugging in and nothing. All the lights work on the unit but nothing happens.
I re[laced the lamp and charge on my Fresh Air purifier and the display still says replace lamp. Whi...
(More)
I re[laced the lamp and charge on my Fresh Air purifier and the display still says replace lamp. Whi is that?
