Question about HP PSC 2210 All-In-One InkJet Printer
How change default print quality setting?
How do I change the DEFAULT print quality and gray scale setting on my PSC 2210 printer?
  • 1 more comment
  • doug1673 Jan 31, 2009
    This allows me to change the settings, but I want to know how to make "fast draft" and "gray scale" the PERMANENT DEFAULT settings. Whenever I try to alter the Default Print Setting, the changes cannot be saved. Solution?
    Yes, I tried "apply", but I cannot save the updated Default setting. Must I change the print quality and color selection for EACH PRINT JOB?
  • Anonymous Mar 14, 2014
    I do not know how to set my (new to me) cm1017 printer to gray scale only
    Genius:
  • 2,120 Answers
In printer properties.
Posted on Jan 31, 2009
  • Leroy Elliott
    Leroy Elliott Jan 31, 2009
    Did you click APPLY?
  • Leroy Elliott
    I would say yes, after all, HP needs to sell ink to stay in business.
How to reset samsung ML1210?
  1. Turn the printer off by pushing the power button in until the LED light turns off. Make sure the printer is off before proceeding.
  2. Remove the power cord from the back of the printer. Leave the printer unplugged for at least five to 10 minutes.
  3. Plug the printer back in. Press and hold the stop button for two to three seconds until the demo page begins to print.
Hope it works...
Feb 26, 2011 | Samsung ML 1210 Laser Printer
Is there a way to turn off scanning in color?
When the printer is setup on each PC, the default option should be set to black and white (click on the quality tab). When wanting to print in color, click print in the program you are in, then click on printer properties, click on quality tab, then set to color. It will only print the current print job in color.
Dec 29, 2010 | Panasonic DP-C322 Copier
I can't get my printer to print in colour. I
Printing Properties
Advanced
Printing Default
Gray scale printing
Jul 11, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
How do I set default on my printer to save ink, print grayscale? Every time I try to change permission is goes back to color
Change the Settings under Start>>Control Panel>>>Printers>>>Printing preferences>Color Tab.
And at the same time under HP Solution Center>>>Settings>>printer Settings>>>Color Tab>>>Print in Gray Scale.
Jun 01, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Set printer to greyscale as the default
hi..that you can set the colour of the print to black
and white both in the printer and the computer.
check it out..
thank u..
rate me..
Apr 08, 2009 | HP PSC 2210 All-In-One InkJet Printer
How can I permanently alter the Default Print Settings?
In the control panel, you can select your printer and set defaults. You can also set them in your printer's setup & maintenance program.
Jan 31, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hi I have HP PSC1610 printer-copier-scanner. 90% of all my printing I do in "FastDraft" Paper Quality. The default is in "Normal" Paper Quality and I have to change the settings each time I print. I would...
When you print from the Microsoft Word and while printing you change the Printer Properties and Print Quality to FastDraft
Everytime you close the window the setting gets reset and again when you start, you have to do the settings.
The Solution you are looking out is
Go to Start >> Control Panel >> Printer and Faxes
There you choose the your Default Printer HP 1610 >> Right Click
and Click Properties
Then you choose Printing Preferences and Make Choose FastDraft
This setting will remain as your default setting now
So whne you have to Print Normal Mode
You need to change the Properties from Microsoft Word.
and it will reset everytime you close MS Word.
Cause your Default setting then is "FastDraft"
I hope this solves your problem
all the best
Jan 02, 2009 | HP PSC 1610 All-In-One InkJet Printer
Hp psc 2110 all in one
Try to clear out all old print jobs and then go to your printer,
Right click on printer Icon and check to make sure it is set as Default.
Nov 03, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP psc 2210 all-in-one -- will not print on-line documents -- message: printer not activated, error code 30
Check if you printer you are wanting to print from is the default printer to your system.
You can make the printer your default printer by clicking 'Start', and then click 'Printers and Faxes' to open the 'Printers' folder, if the desired printer does not have a check mark next to it, right-click the printer icon and then click 'Set as Default Printer'. You can right-click on the printer icon, and then click on the 'Print Test Page' to print a Windows self-test page.
http://www.fixya.com/support/t3506228-hp_printer_not_printing_activated_error
Jul 08, 2008 | HP Office Equipment & Supplies
Kindlly assist hp 2210 problem narrow paper
you have to go to the menu and change the settings , try the DEFAULT setting . also do you have the printer connected to the PC ?
Apr 16, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
558 people viewed this question
Ben Johnson
