Question about Canon Normal EF 50mm f/1.4 USM Autofocus Lens
Canon ef 50mm 1.4 can't focus <1m
I recently dropped my eos3 with canon 50mm 1.4 attached.
Since then the close focussing stops at about 1 m. Any less than that is impossible via auto or manual focus.
Any ideas for a do it yourself fix? Or should this be cheap to fix if I take it to a camera repair expert?
  • cosminandrei Feb 16, 2009
    i dropped mine and the autofocus doesen't work under 1m and works quite poorly above . however when it happens to work it works very fast and accurate.
    Scholar:
  • 83 Answers
If the AF motor is still alive + spinning, this should be fixable without any replacement parts.
Following URLs might be useful:
http://www.flickr.com/groups/canon_50mm/discuss/72157603775874649/
And this one - detailed instructions how to dismantle this lens and fix the issue similar to yours.
http://www.fotomozaic.ro/artikel.php?idstory=225&s=1
Hope this helps - good luck!
Raf
Posted on Feb 01, 2010
  • 115 Answers
Sorry, your autofocus engine might be broken or damaged. ou will have to take your lens to a repairman
Posted on Feb 04, 2009
Canon EF 100-400 not auto focusing
It is probably a broken ribbon cable in the lens. It will need to be replaced.
Dec 18, 2012 | Canon EF 100-400mm f/4.5-5.6 IS USM Lens
Canon 50mm f/1.8 lens is not focusing.
I had the same problem with my ef 50mm 1.8. I used it on a cold day and broke off one of the internal gears. I used it for almost a year before I got the guts to take it apart and fix it. There are instructions online on how to take it apart, scary at first but not that hard overall. I used a small drop of crazy glue on the gear, put it all back together and just like new.
Jan 27, 2010 | Canon EF 50mm f/1.8 II Lens
My 50 mm 1.4 won't focus on closer objects only far away now after my mom dropped my camera. What can be done? Is it most likely broken?
yes thats a fair bet,,, it could only be the lens that took the brunt of the smack it had and its now jamming when you try to focus up on close ups,,,
try a difrent 50mm lens on it and find out if im right
Oct 17, 2009 | Canon Normal EF 50mm f/1.4 USM Autofocus...
Ef 50mm f/1.8 II not auto focusing
You need to send it in for service. The more you use it with the "noise", the more you are potentially damaging the auto-focus drive mechanism of the lens. The sound you are hearing is most likely the gears and whatnot grinding away at each other because they were knocked out of place by the impact of the fall. I don't know how much this will cost, but I would say somewhere in the $200 range would not be unbelievable. Sorry I don't have any good news, but I have "bounced" a lens or two in my time.
Oct 25, 2008 | Canon EOS 40D Digital Camera
The Auto focus just stop working
Hey Sammymalone,
This lens should have a 1 year manufacturers warranty on it, and if my guess that the USM motor is burned out is true I would have it serviced by an authorized service technician. Before you do this though I would try cleaning the lens contacts to make sure it is communicating with the camera body. I of course am going on the assumption that you have tried other lenses on the camera body to make sure the problem is the lens and not the body. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 29, 2008 | Canon Normal EF 50mm f/1.4 USM Autofocus...
Canon Normal EF 50mm f/1.4 USM Autofocus Lens Logo
3,254 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
