I have a Minolta x60. The camara does not start up anymore. Normaly it makes a start up sound but now it starts the sound and then breaks off. I removed the battery and put in in again without any difference. I also tried another battery but without result. I changed the memory card also no change. It looks as if some software does break off immediately after starting. Does anybody know what the reason can be and if it can be solved?
My x50 does not startup. The red light above the screen just flashes for 3-4 seconds and goes off. I charged the battery and removed the SD memory. Still does not startup. Any ideas-   Guest
The strap holder on the camera came off. How do I remove the plate so I can screw the strap holder...
(More)
The strap holder on the camera came off. How do I remove the plate so I can screw the strap holder back on?
My camera turns on when the shutter is opened. No image appears through the viewer. All normal...
(More)
My camera turns on when the shutter is opened. No image appears through the viewer. All normal information appears on the viewer (ex. picture number, Auto, picture size). I can retrieve and view all pictures previously taken, but I cannot take new pictures. I have recharged the battery 3 times. Is it possible that the battery is not taking a complete charge? What else may be wrong and what is my next step?
I have konic miolta dimage x60 camers in which lens cover works as main switch. by sliding lense...
(More)
I have konic miolta dimage x60 camers in which lens cover works as main switch. by sliding lense cover open camera turn on & by sliding cover in apposite direction camera turns off. But now the lense cover is not working as on/off switch. I have reset the default setting, removed and replaced battary & memory card but of no use the camera remains always on once the battary puts in
i have konica minolta dimage x60 digital camers, my problem is that, my camers remains on always...
(More)
i have konica minolta dimage x60 digital camers, my problem is that, my camers remains on always because main switch is lens cover which is not working at all.
Lost installation CD for DImage X60. Is there a website where I can install the startup program for...
(More)
Lost installation CD for DImage X60. Is there a website where I can install the startup program for my new laptop?
