Cannot login to configure Belkin SMB KVM-over-IP swith
I have a Belkin OmniView SMB KVM-over-IP Switch model F1DP108G.
I have tried using Windows XP SP3, Vista Business x86,
Window Small Business Server 2003, Windows Small Business Server 2008, and Windows Server 2008. I am not able to access the web configuration tool, using the https://"ipaddress"/config. I have a DHCP server and I know the correct IP address. I get to the screen to enter my username and password. I type in the default, admin/SMBremote. The page refreshes and I am returned to the same login screen.
This happened to me until I installed the activeX control. Were you prompted for that, and did it install successfully?
After the activeX installed, did it also prompt you to install the secure certificate to access the site without IE prompting about invalid certificates?
Since you've tried multiple machines, I doubt security settings on IE are causing the problem. But my switch did these two actions before I was able to login successfully.
Posted on Mar 19, 2009
Hard reset code
THE BELKIN KVM switches I have used have micro switches to adjust the inputs, what KVM and which model are you using?
To go back to default on an omniview I would just unplug everything
Jul 03, 2015 | Computers & Internet
I use on my PC (Acer/Compac) My Pictures/Adobe Photoshop for the pictures I have. I have gone into the Properties section to add more information on each individual pictures. I than burned the photos...
  • When you go to the Connect to Server dialog, you may browse the names of computers that are on your local subnet.
  • You can connect to a server via its IP address or DNS name. If it is required or more convenient in your environment, you may also use other valid URL formats, such as:
    smb://ServerName/ShareName smb://DOMAIN;User@ServerName/ShareName
  • The name of the "share" (the shared disk, volume, or directory) must be specified. You will not be prompted for it.
  • You cannot type spaces as part of the share name when connecting. In place of any space in the share name, type: %20 .
  • When troubleshooting a connection issue, you can ping the IP address of the Windows PC using the Mac OS X Network Utility application (in the Utilities folder). A successful ping verifies a TCP/IP connection between the two computers. This is an important first troubleshooting step when there's no response or a timeout for a connection attempt, since SMB connections involving a Mac require TCP/IP. However, a successful ping does not mean the SMB service is also working or available.
  • Check Microsoft support resources for information about setting up file sharing on your Microsoft Windows-based computer. These may include Help files installed on your PC or the Microsoft online Knowledge Base. For example, see this article for Windows XP information: How to use the Simple File Sharing feature to share files in Windows XP.
  • When troubleshooting an SMB connection issue, use Console, which is located in the Utilities folder. These Console logs may help advanced users identify an issue: private/var/log/samba, private/var/log/kernel.log, system.log . Note that some log files only appear when logged into Mac OS X with an administrator acccount.
  • If you are connecting to Windows XP, make sure that the Internet Connection Firewall settings are not interfering with your connection. SMB uses ports 137, 138, 139, and 445. These ports should be open on the Windows XP computer. This may require "Advanced" configuration of the XP firewall.
  • If you are connecting to a Windows SMB resource, check to see if the firewall is blocking TCP ports 137, 138, 139 and 445. After trying the above steps, you may perform advanced troubleshooting by inspecting log entries in the Event Log of the Windows SMB resource (if you have access to it), and/or the Mac OS X computer's relevant logs in the Console application. If those steps do not help identify the issue, or you do not want to perform advanced troubleshooting, than you should contact your network administrator. It may be necessary to contact your network administrator in some situations in order to grant access to your Mac from the SMB resource, or its host network configuration.
  • Mac OS X uses SMB only over the TCP/IP protocol, not the NetBEUI protocol.
Dec 29, 2010 | Compaq Computers & Internet
Hello there, I have a Lite On SK-3211 1U
This product uses none-standard USB host controller and USB devices are not being enumerated properly within KVM. The company that designed this product is no longer in business.
Currently there no support for this specific keyboard/mouse on Belkin Dual User KVM over IP.
Sep 15, 2009 | Lite On Computers & Internet
KVM functionality
This happens on KVMs, some more than others. I have a couple of Avocents that work great with Dell and HP servers, a Belkin OmniView that works great with two Dells and OK with a home built. Bottom line is some switches work better than others just like some PCs seem to behave better than others. If you?re looking for suggestions I would stay away from the cheaper $50 and under switches unless you find a good, used, guaranteed one somewhere. I like the Belkin OmniView and Advocent (really expensive, meant for servers and other medium sized sites). I would stay away from LinkSys, they make good wireless equipment but haven?t heard much good about their KVM switches. The original post was a few months ago so this is really intended to help anyone in the future who is researching a similar problem and winds up here.
Apr 26, 2007 | Linksys ProConnect Compact KVM Switch...
Problem with Belkin OmniView KVM F1DS102P
Is the LED for position 1 and 2 always on? If the switch doesn't detect power on the PS2 keyboard connector it won't let you switch to to that position. If you are using a USB mouse with an adaptor or a wireless mouse try a conventional PS2. I have a MS wireless mouse one of my switches does not like and have to resort to that sometimes. Another issue could be excessive cable length or PS2 extension cables. Let us know if you have any more questions on this topic and please don?t forget to rate the post.
Aug 31, 2006 | Belkin OmniView¿ SOHO Series 2-Port...
Direct Access Buttons
the hotkeys are funcion becouse the ps/2 manual operation, but you have to claim the waranty fortunatily the omniview have 5 years in both parts and services claim it...good luck
Aug 10, 2006 | Belkin OmniView PRO2 8-port KVM Switch
Direct Access buttons
Computers & Internet Logo
2,569 people viewed this question
David Payne
David Payne
