Question about Mowtownusa Heavy Duty Cast Iron Pulleys for Lawn Mowers 5 3/4"
I need to change the pulley on my washer motor
  • 24 Answers
We use an air hammer , put a different bolt in the shaft or nut
vibrate the shaft with the air hammer while pulling up on the pulley
you can not use a puller ,
Posted on Feb 03, 2009
How to install a idler pulley
Hello, Need more information on this in order to help you with getting help installing the idler pulley. What is the device you are changing th pulley too?
Sep 30, 2014 | Gates 36220 Idler Pulley
Replace bearing on washing machine
are you tech saavy..can you do it by yourself.
click here....to learn
Mar 21, 2008 | Washing Machines
I have a Frigidaire Combo Washer/Dryer fex831cs0. There was a clunking noise in the dryer, now it has stopped. Is it the belt? If so is it hard to change?
This can be due to the belt failing and hitting against to produce the noise or even if the main motor had failed.
You will need to check inside the washer to confirm the observations.
the belt can be changed easily once you have taken out the broken one , buy the same size according to the sample . It can be rolled into the main pulley and then after aligning with the motor pulley manually turn the pulley as the belt will be dragged into the slot.
Mar 28, 2011 | Dryers
Start the power switch on and problem and drum is not running
Hi, the washer drum is not spinning, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Dec 22, 2010 | LG WM-2277HW Front Load Washer
The washer won't drain and spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Nov 28, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washer will not spin
Hi, If it doesnt spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Thank you !
May 10, 2010 | Frigidaire ATF6000ES Front Load Washer
Kenmore Series 80 washer doesn't always spin, only 1/3 of time.
First of all check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely,if it's frozen or stiff,replace it. If the pump belt is broken or looks quite worn, replace it but be sure to check the pump pulley before you change the belt.
Sep 05, 2009 | Kenmore 24902 Top Load Washer
Belt amana washer replace mod lw6501w2
I have a similar amana top load washer and just changed the belt. Here are the steps I used to change the belt:
1) Unplug the washer
2) Slide the washer away from the wall about 12"
3) Remove two screws from the bottom of the front panel, slide the front panel down (there are 2 metal tabs that slide into slots on the top of the front panel - observe how they slide into/out of the slots). Set the panel aside.
4) Remove the electrical connector (upper left of motor). Press down on the top of the plastic connector - this will undo the catch hook holding the connection in place). Observe how the belt is routed before proceeding.
5) Remove 4 bolts holding the motor in place. You can remove the motor - even with the water pump and hoses in place - they will flex.
6) Remove the water pump from the motor. There are 3 torx - head screws to remove. Note: You will need a star shaped (torx) head driver (Looks like a screwdriver but with a "star" head on it. The one I used measured just under 3/16 in diameter.
7) carefully remove the water pump. - remove the old belt from main pulley under washer drum and also from the water pump. Insert the new belt - be sure to put the tension pulley on the outside of the belt.
8) Reinstall the water pump to the motor. Reinstall the motor. Route the belt correctly in the water pump body area first - them slide the belt around the left side of the main drum pulley - rotate the pulley counter-clockwise and the pulley will tug the belt onto the pulley. Once in place - check bolts and belt - then reattach the electrical connector (remember to press the plastic lever on top of the plastic connector before sliding it in place). Reattach front panel - slide the top of the panel onto the metal tabs - then attach screws at the bottom.
Feb 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Washer Doesn't Spin!
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
Jul 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Changing belt on washing machine, that broke
to change the belt you need to remove the pump attatched to the motor. the pump is held on by either spring clamps or in older models, torx (star) screws. I believe the size for the torx screws is #20. slip the belt over the motor pulley and around the tension pulley and finally around the transmission. reinstall the pump and you're good to go.
Aug 18, 2007 | Amana ALW540RA Top Load Washer
Mowtownusa Heavy Duty Cast Iron Pulleys for Lawn Mowers 5 3/4" Logo
Top Mowtownusa Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Mowtownusa Garden Expert? Answer questions, earn points and help others
