Question about Maytag Atlantis MDE7400AY Electric Dryer
3 to 4 plug dryer
On my maytag the top wire for dryer plug is black then next down is white but the third down is green or blue no red? help
    Sergeant:
  • 311 Answers
On your cords their are three or four wires.1 black 1red 1 white and 1 green.the red and black go on the furthest out side bolts of the machine,[term block]the white goes on the middle[of the term block] and the green if you have one goes to ground ,the body of the washer.most offten theres a screw[its green] near by for the ground near the cord term block.red or black dose not matter if top or bottom.they are both the same voltage.this is the same if you cord term block is horizontal or vertical .if the other color happened to be blue,which i have never seen one .it would be in the place of the red.all connections must be tight,or some day will burn at that loose connection. God bless ,tom
Posted on Jan 30, 2009
  • Thomas Malailua
    Thomas Malailua Feb 03, 2009
    or if its a all gray cord the two out side wires go on the out side of the cord term block.the middle wire from the cord goes in the middle.the two out side cord wires make no difference which one on top/or bottom.they are the same voltage ither way
  • 367 Answers
Not really sure what you are asking. But if you trying to hook the cord up... Green and white go to the middle terminal Then black or red to either side it doesnt matter which.
How to connect a plug electric dryer to a 4 plug outlet
for short, just dont mind the color.. the black wire from the new plug goes to right in/on the appliance terminal block, the white from the new plug goes to both white in the middle of the same terminal block and the red wire from the new plug goes to left terminal block of the appliance therminal block and of coarse the green from the new plug goes to the appliance frame.. no need nor sense in trying to figure the wire color of the appliance as it does not mean anything really and it does not follow any rules nor standards..
Nov 08, 2014 | Dryers
Maytag neptune dryer
Hey white to white, black to black red to the multi colored pole, and the green one is the ground wire,, . I done that before,, lol,, good luck ,, thanks
Oct 05, 2008 | Maytag Neptune MDE6700A Electric Dryer
I am changing out the wiring from a 3 wire to a four wire. The terminal block has (top to bottom) black, whiteandblue wires. The new 4 prong wiring has a white black green and red wire... what goes where...
The black,red & blue wires are your hot (120 volt) wires. Two of them get conn. to the two brass colored screws. The white is the neutral wire which conn. to the siver screw. The green wire is the ground wire conn. to the green screw which is the grounding screw.
Oct 06, 2009 | Dryers
What colors on electrical cord go with what screw on dryer?
black on first screw/white on middle screw/red on third screw/green to the screw on case that says grnd.
Jun 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Converting from 3 prong to 4 prong
red and black go to the outer sides. white always goes in the middle and green just screws into the cabinet. so I would connect black to black white toi white and the blue to red and green to the cabinet
Jan 04, 2009 | Estate TEDX640JQ Electric Dryer
I am converting a 3 prong dryer to a 4 prong plug. The wires inside the dryer are black/yellow, white and blue. The wires on the plug are white, black, red and green. I am assuming the green is the ground...
on plug white is neutral, black is power , red is power, green is ground. black/yellow and blue are power and white is always neutral ie. (white to white) black to black/yellow, blue to red. green to grounding screw on machine
How to change a 3 prong to a four prong on a mde4000 Maytag Neptu
the red wire to red black wire to black white wire to white and disconect the ground wire to the white lug and conect the green wire to the screw that is on the other end of the ground strap you disconected from the white lug
Dec 24, 2008 | Maytag Neptune MDE4000 Electric Dryer
Changing plug
your cord has 4 prongs , assuming your outlet also has 4 prongs.red to red, white to white, black to blue, and the "teal" gets hooked to the green ground ******** the rear of the unit
Oct 30, 2008 | Maytag Neptune MDE4000 Electric Dryer
Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Oct 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
97 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
