2001 Kia Sportage Logo
Posted on Jan 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oil leaking out of valve cover gasket
I have 2001 kia sportage 2.0 L its leaking oil out of the back of the valve cover someone said that that model has a spark plug o-ring kit and i called the dealership and they said that model does not have that system that its just a valve cover gasket leaking..........and it only leaks oil when i start the engine .....
  • 3 more comments
  • terryj1001 Apr 09, 2009
    i have the same problem with my 2002 kia sportage and the way i found out about it was when i was changing out the spark plugs and all i saw in my socket and on the spark plug was oil
  • Anonymous Apr 17, 2009
    I came across same situation yesterday rear plug soaked in oil.
    Is it fairly easy to repair?
  • Anonymous Mar 12, 2014
    Oil filter was checked in dealership but still see few drops of oil leak on the ground.
  • Anonymous Mar 15, 2014
    oil from valve cover gasket is leaking on wires
  • Anonymous Mar 23, 2014
    I think the valve cover gasket is leaking
Anonymous
Level 3:
President:
  • Master 1,990 Answers
  • Posted on Jan 30, 2009
Anonymous
Master
Level 3:
President:
Answers
1990
Questions
Helped
909842
Points
6127
It is a Valve Cover Gasket. You can get a new one at any Auto Parts Store. To make this repair last longer, Do not get the Cheap one, Get a Felpro Gasket and it will Quadrupel the Gasket Life. Please Rate My Response! Thanks!
Doug Warne
Level 2:
Scholar:
  • Expert 58 Answers
  • Posted on Jan 13, 2014
 Doug Warne
Expert
Level 2:
Scholar:
Answers
58
Questions
Helped
30980
Points
143
BMW 750Li Valve Cover Leaks Gasket Seal Replacement.
Note: Remove The center engine cover and Looking at your Plastic valve covers pop off the right and left side Valve cover facial covers, now on the drivers side Valve cover left side rear move your fingers slowly where the valve cover sits on the head...Can you feel the gasket ..?? The Gasket is a Rubber seal TAKE NOTE: These plastic Valve Covers Warp...there are 4 spark plugs tubes between the covers and the heads and the covers sitting on these tubes help cause the Warping ..
Take Note: Looking at the valve covers Bolts"..2 center by vanos piston and the 2 bolts with half moon notch on the heads These Bolts have to return back to where they removed from because the stops on them are different sizes to keep from cracking valve cover and insure the lower side of the valve covers will seal tight against the heads.
Caution - tighten valve covers bolts in Multiple steps torque sequence
Up on replacement with new valve cover I set the new valve cover on head then from the top center of valve cover installed the new bolts and Lock seals just getting them started then the long front bolts then the 1 rear bolt that hides back at the cam sensors.
Now take one of the old top bolts with the half moon and get the bolt started center of lower side of the cover...began to tighten the bolts Keeping in mind the Spark Plug tubes are holding the valve cover up and will set and seal as you tighten bolts in sequence starting from the center then out toward the ends.. Began to install new lower Valve cover bolts, when the valve cover spark plug tubes are seats into valve cover enough to allow lower bolts to reach and grab the studs threading...Remember to Remove and replace the old half moon bolt you install on lower side of valve cover we use for valve cover with spark plug tube seating ..replace with new bolt and seal with shorter stop shank.
Take Note": This is not a fun job to do so I would Purchase new Valve Covers and New Spark Plug Tubes and when installation I used see through coat of lithium grease on the seals of the spark plug tubes and made sure there sitting completely in the head on reassembly. Also wiggle each spark plug tube when setting the new valve covers back on head to insure the tubes are aligning with new valve covers..
Disconnect Battery neg. terminal
Remove the Engine covers
Remove the Cabin Air Filters Covers
There is a metal Flex Lock on top of the inlet ducks use crow foot and release ducks from firewall.
Remove the rear center cross over 2 - 10 mm bolts left and right side
Remove the plastic locking seat 1 - 10 mm bolt from right passenger side Cabin air filter lock tab ...this is sitting over main wire harness box.
Remove the main wire harness box cover
Pull up on the main wire harness allowing you to move the wires to firewall
Remove the 2 torex bolts from center engine cover mounts, this will allow more travel for main wire harness to firewall use a bungee cord to hold out of way of valve cover ..
Remove the 2 cam sensor Male torxe screws and wiggle sensors our of cover
Remove 2 Screws holding plate on eccentric sensor remove the plate.
Stop--------------------------------Vanos Piston Removal-------------------
Mark the vanos piston and mount with marker or paint for reassembly 2 half's
Loosen 4 Allen bolts slowly there is pressure on piston
Hold down on piston when removing last Allen bolt then slowly lift then it will click releasing tension
There is a seal ring for Piston to mount seating I apply lithium grease reassembly
Remove the 4 toreax screws from Vanos piston mount and lift mount off valve cover up out of seal.
Remove the right / left engine air filters and 2 screws from the Ducking now remove Ducking.
Remove 2 Screws from the Antifreeze overfill bottle lift up to release from wheel well
Remove the large Vacuum line off Air pump right front of head going to Power Brake Booster Diaphragm .
Got to Left side back at power brake booster there is a cover 2 torex screws holding this cover keeping this vacuum line in channel support Remove.
Unlock this Vacuum line from power steering reservoir bottle and remove this vacuum line from car
Remove the Vacuum line from the Throttle body that travel to secondary air up over the power steering reservoir ..
Remove the 2 - 10 mm bolts holding the power steering Reservoir freeing the Bottle from mount.
Right side passenger unplug the coil packs and using flat edge unlock the harness and move harness over the engine
Loosen the ABS Pump
Remove 4 coil packs from cover there tight so take your time may need to move Abs Pump
Now Take your time....The essentric Sensor stick up out of Valve cover back at cam sensors.
Remove the Valve cover bolts Keep in mind you have the 10 mm bolt that is back at the cam sensor
All bolts Removed wiggle and lift and wiggle valve covers up off spark plug tubes
-------------------Stop-------------------------------------------------
These Valve covers have to come up over the Esentric Sensor in rear of valve cover first and when reassembly has to go over first......
-----------------------------------------------------Take your time ---------
Remember of reassembly wipe the oil from spark plugs tube seats because this will cause misfire of engine ...
U can use light see through lithium grease on new spark plug tube seal for reassembly
The Left valve cover is the same TAKE NOTE:----------
On Removal of left valve cover there is 2 coolant hoses heater that will need to pushed under valve cover once free from spark plug tubes or you will have to disconnect the upper hose...but makes mess with coolant.
Remember the cover lifts up over the Rear Esentric Sensor mount first and goes back over first on Reassembly.
That is about it...Just take your time, force the valve cover off spark plug tubes, keep in mind of the 1 - 10 mm bolt back at cam sensor
Im finding oil under my car its not my oil pan
it could be a valve cover gasket leaking and running down. a head gasket leaking, or a seal that is to keep oil in the engine and not leak out. you will have to take a close look for oil leaks on the engine, maybe even have the engine shampooed then drive and check for leaks.
2answers
Kia sportage 2000 no acceleration
It is important too identify the following:
1) The source of the exhaust leak
2) The source of the oil leak.
The exhaust leak could turn out to be a bad exhaust gasket, a cracked or loose exhaust manifold, a cracked cylinder head or bad gasket, or related parts. The oil leak could turn out to be the valve cover gasket. A dried out valve cover gasket can cause oil to sit on the spark plugs and have oil leaks. Be sure not to over-fill the oil. A machine shop can find cracks in cylinder heads. If these problems turn out to be ok (and one of those stethoscopes may be helpful) then you could procede to check fuel delivery. (there will be pressure in the lines) A lot of times connectors get corroded. I noticed on this model the sensor for the engine cooling mounted near the thermostat is very sensitive to variation. Same for the air sensors if left loose.
How to change gasket on oil cooler 2001 Kia Sportage?
An "O" ring can be purchased at your local auto parts along with your oil filter. Your oil filter screws on top of your oil cooler. Mine leaked as well. A new "O" ring and filter screwed on tightly solved my problem.
Oil leaking into the mass air flow hose
High crankcase pressure due to worn rings or a plugged crank case ventilation valve (PCV). This can also be caused by an overfilled oil level
Why is there oil leaking on my 2001 kia sportage?
One of your many engine gaskets has failed and started leaking. If it is leaking more than a very small amount, you"ll have to replace the gasket. Very small leaks can sometimes be cured with some aftermarket stop-leak stuff. Make sure it's for an oil leak.
I have a 2001 kia sportage. There is oil leaking into where the spark plugs are and shorting them out. Where could the leak be coming from?
You have a broken seal that is seated around the tube where SPARK PLUGS go thru. Fixing it is easy for a novice mechanic, just remove the VALVE COVER and u will see the SEAL around the tube, clean the area around the tube so that it will be oil free, replace all 4 seals, and put in a new one w/ a light coat of silicone sealant,clean also the valve cover gasket put some sealant. Put back the cover and ur done! Hope that makes ur day! taaah!
5helpful
3answers
Oil in spark plug holes
HAD THE SAME PROBLEM WITH MY DAUGHTERS CAR---CHANGED THE SPARK PLUGS AND OIL IN THE HOLES OF THE SPARK PLUGS WIRE TOPS--- CHANGED THE VALVE COVER GASKET AND ITS BEEN CLOSE TO 4 MONTHS AND NO OIL AT ALL IN HOLES---IF YOU LOOK AT THE GASKET YOU CAN TELL IT LET THE OIL OUT---THE GASKET SITS INSIDE THE VALVE COVER VERY SNUGLY--THE OLD ONE WAS VERY LOOSE---AS FAR AS OIL GOING INTO THE SPARK PLUG CYLINDER IT WILL BLOW WHITE SMOLE FOR ALITTLE WHILE BUT EVENTUALLY BURN OFF---HOPE THIS HELPS---DENNIS
2helpful
Oil in the back 2 cylinders on a 2000 kia sportage. is the motor shot?
vavle cover gasket is leaking.and thats why oil is in with the plugs.change the gasket and solve youre problem
Top Kia Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Kia Expert? Answer questions, earn points and help others
