Question about Microwave Ovens
Won't turn on
So what happen was, there was tinfoil and there was a small fire cooked within the microwave...anyway. it wouldn't turn on after that.
  • 2 more comments
  • Anonymous Jan 30, 2009
    It was a GE househould microwave oven
    model number is
    JVM1750DM1WW
    serial number is
    DM 905367 B
    model number is
    JVM1750DM1WW
    serial number is
    DM 905367 B\
  • William Miller
    William Miller May 11, 2010
    The oven cavity TCO (flame sensor) probably got tripped by the heat of the fire.
    Please reply back with your brand and model number so we can help you.
  • William Miller
  • Microwave Ovens Master
  • 8,865 Answers
I'll proceed on the assumption that the model number posted by "Guest" is being posted by "clearlymaybe".
Yes, I'd say the oven cavity TCO (flame sensor) probably got tripped by the heat of the fire.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Accessing some components (such as the oven cavity TCO) for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on Jan 31, 2009
Sharp R-1510 1000 watts microwave, not heating
Sounds like the inverter (power supply for cooking) or the magnatron which does the work----neither are cheap parts.
Oct 16, 2012 | Sharp R-1510 Microwave Oven
Oven turns itself on
THE DOOR HAS A SAFETY SWITCH THAT SHUTS THE UNIT OFF WHEN THE DOOR IS OPENED KEEPING YOU FROM GETTING "ZAPPED WITH RADIATION" ACTUALLY ITS JUST RADIO WAVES, ANYWAY THE JIGGLING OF THE HANDLE TO START IT IS WHATS HAPPENING THERE. IT COMING ON IS JUST A SHORT IN THE SWITCH THAT MAY BE FROM AN ALREADY SET TIME, OR ITS JUST MAKING CONTACT WHERE ITS NOT SUPPOSED TO. ANYWAY YOU NEED A NEW DOOR SWITCH.
Dec 03, 2007 | Samsung SMH7174BC Microwave Oven
My emerson microwave turns on but it won't cook or
Check to see if it has a DEFROST SETTING if Defrost setting is on it will not reach an adequate temperature
Jun 07, 2012 | Emerson Microwave Ovens
It stopped working with a sign in the LED that says ( se )
-SE- error means you have a shorted membrane keypad.
You can buy the part for about 20 dollars off kenmore website. I wouldn't recommend leaving it plugged in. If you're able to still microwave things I wouldn't go far while something is cooking.
Sep 14, 2011 | Kenmore Microwave Ovens
Microwave is arcing and making a popping noise as if something metal was in there while cooking.
I will assume that you do not have any metal items or bits of tinfoil lying around inside the oven.
If the sparks are happening on the inside of the microwave's cooking area while you are cooking, then make sure you clean the inner surfaces really well. Be sure to remove any cooked on food particles that may have splashed up during cooking.
Most likely you have some corrosion or dried food debris inside the cooking area, or perhaps even some food particles stuck to your WAVEGUIDE COVER PLATE. A dirty waveguide cover plate can certainly cause the arcing and sparking you describe.
If the thorough cleaning does not work, you may need to replace the waveguide cover. Here is a link to a short video that shows you exactly how to replace the wave guide cover yourself:
http://www.youtube.com/watch?v=M0xsXjhefy4
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the video at the website indicated.
If the sparks are coming from somewhere other that the cooking area, then your unit may need more significant electrical repairs or service.
Here is a link to another expert's excellent Microwave Troubleshooting Guide:
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
If you choose to rate Heatman 101's tip using the Thumbs Up scale provided, I thank you very much for your time and consideration.
I hope that was helpful to you, good luck and take care.
Joe.
Jun 21, 2011 | Samsung SMH9187ST Microwave Oven
Whirlpool microwave fan spontaneously came on
some of these unit detect heat from the stove while cooking.there are designed to turn the exhaust fan on until the temprature gets cooler to prevent any interior damage.
there also could be a problem with your microwave circuit board.
check with whirlpool and see if there is any recalled notices for you microwave
Jan 30, 2010 | Whirlpool MH7130XE Microwave Oven
Hinari microwave doesn't cook
hello mam
i am having the solution for this problem check the lock terminals for loose connection and if its working and check the magnetron which produses the heat inside the microwave.
Sep 25, 2009 | Microwave Ovens
Potato caught fire during cooking. Microwave has
Hello, inside most microwaves, there is a thermal fuse, that if something in the cooking cavity is on fire, it will melt the thermal fuse, if it gets hot enough, thus breaking the power to the unit shutting it off. This sounds like what has happened to yours, simply replacing it will correct the problem. It is usually located near a cavity exhaust point. If you aren't comfortable doing this, as it requires removing the outer cover, while unplugged, and locating/replacing it, take it to a appliance service co. This will of course cost more, if you do it yourself, make sure you provide all of your make/model/serial/anything else, that will identify your unit, and call/go online to a parts retailer, and you should be able to get it done fairly cheap.
Hope this helps, and thank you.
Mar 01, 2009 | Microwave Ovens
Kenmore 721.80524500 makes a buzzing, grinding noise
Your problem is due to the "magnetron" arcing to the wave guide within the microwave. Picture someone arc-welding stuff together inside the microwave casing, that's essentially what's happening. It is a fire hazard and you should stop using the microwave immediately. As far as I know, there isn't a recall on that particular model (though there was on another similar Kenmore/Whirlpool model) so if it's out of warranty, you're out of luck.
Sep 08, 2008 | Kenmore 63662 / 63664 / 63669 Microwave...
Oven turns off
You are running the risk of damaging the Magnatron by doing this.
Check the packets you are using, you will have to reduce your power output.
This is because microwaves act by being absorbed by water. There is very little in popcorn and in fat. Once this has been evaporated, the microwave energy builds up (as it is still being produced - but not absorbed), and ends up cooking the magnatron itself.
I have seen countless posts on here after cooking popcorn!
More fun on the hob anyway - and cheaper to buy in bulk!
Jun 21, 2008 | Magic Chef MCD1311ST Microwave Oven
Microwave Ovens Logo
184 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
