Question about Acer Aspire 3000 Notebook
Hi.. I am suffering flickering problem with my Acer Aspire 5920.
  • 38 Answers
This is often a problem with the backlight on the LCD panel. If you gently tap the side of the LCD does it flicker more? If it does, then there is a loose connection in the LCD panel, and you might be able to get a comptuer shop to fix it, but it usually is expensive. If you don't mind using the laptop as a desktop, then get an LCD monitor and a USB keyboard and mouse, and you can use it as a desktop.
Posted on Jan 31, 2009
Monitor flickering
hi tim, get the latest drivers here : http://support.acer-euro.com/drivers/downloads_gd.html
o/s is abbreviated for operating system = windows
kind regards
Jan 17, 2010 | Acer Aspire 5920-6335 Laptop
My screen is flickering.my pc acer aspire 5920. pls advise.thanks
try changing its resolution from display properties, or lowering the refresh rate
Jan 16, 2010 | Acer Aspire 5920-6335 Laptop
Crystal eye web cam not found on aspire 5920
Acer aspire has inbuilt web camera and therefore will work only if the correct drivers are installed. Please uninstall the drivers first from control/panel/add remove programs. Next reboot the system and then go ahead with the installation.
http://www.laptops-drivers.com/acer-notebooks/download-drivers-acer-aspire-5920-notebooks.html
Thank You for using Fixya.com
Jul 26, 2009 | Acer Aspire 5920-6727 Notebook
I have the same problem with my ACER Aspire 5920
check to make sure that your display settings are at the average position, be sure to check the color setting and make sure it is not over 32bit, just to be safe put it to the lowest setting possible. does this solve the problem?
Jul 16, 2009 | Acer Aspire 5920-6727 Notebook
Screen flickers even on battery
Have you updated your system BIOS with the latest download from Aspire?
This upgrade is particularly important if you have updated your Vista with service pack one or two (which may have been done automatically depending on your Windows update setting).
To upgrade your system BIOS download the latest version from the link below-
http://support.acer-euro.com/drivers/notebook/as_5920.html
simply run the file that is provided in the zipped form in order to update your system bios which should resolve this issue unless it is hardware related which is usually not the case on this laptop.
// j
Jun 25, 2009 | Acer Aspire 5920-6727 Notebook
Screen jumping on acer aspire 5920
First boot in safe mode and the display resolution will be minimal if the screen appears ok with big fonts then try and adjust the normal resolution but not high resolution like 640x480 with 256 colors, if it works then you acer laptop screeen is fine but the exactly display drivers to be reloaded else there is a problem with your laptop screen which needs to be replaced
Mar 18, 2009 | Acer Aspire 5920 AS5920 Notebook
Acer Aspire 5920
There might be problem with signal cable of the LCD,Had you tried with external display .If same problem with external disaply then might your graphics card problem ,if not then certain problem in signal cable or the screen itself
Mar 14, 2009 | Acer Aspire 5920-6727 Notebook
How to solve Flickering problem of LCD
I have had the same problem,
I found it was my power supply transformer (part of power lead).
Some transformers may be faulty, or replacement transformer may not provide a voltage stable enough for the LCD.
Also check the wiring in your plug.
Safest option is, buy a genuine Acer supply transformer with plug lead from Acer.
Hope this helps (please rate my advice)
Jan 30, 2009 | Acer Aspire 5920-6727 Notebook
I have an Acer 5920G that's only 3 months old and it's screen started flickering. Updating or rolling back the graphics card driver made no difference. I then updated the Chipset driver from the Acer website. It hasn't flickered since!
The graphics info has to pass through the chipset so I assume the driver wasn't up to the job.
I need DVD System Recover Laptop Acer Aspire 5920-6168
hi techpa
you may find it here http:\\global.acer.com/support/downlowds.htm
Oct 24, 2008 | Acer Computers & Internet
Acer Aspire 3000 Notebook Logo
100 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
