Question about Epson Stylus Photo R220 InkJet Printer
Black ink will not print
HP deskjet 990 cxi, I have cleaned and primed 2 times.  Ink level is 90% but no black ink is printing.  Cartridge is loaded correctly and cover removed.  Any ideas?   I worked great a week ago.
  • 353 Answers
You have submitted this problem in the Epson R220 area - it is unlikely to produce a response here. Try again putting it in the HP 990 area.
Posted on Jan 31, 2009
I used machine's ink jet cleaning program, without luck. Cyan and Yellow still don't print. What next?
My HP printer has a cleaning programme and a cartridge priming programme. I had trouble with my colour cartridge, in particular the cyan. The cleaning cycle never worked but the priming programme worked a couple of times but whenever the printer was left idle for a while the colour would not print.
I took the cartridge to a refill shop and the guy emptied the ink and steamed out the cartridge and print head and refilled it and then it did work for a time.
A new cartridge is expensive and so these days I just use it for printing black...
I think there must be something strange or different about the cyan ink. Sometime in the future I am going to try steaming again only this time with a deal more pressure than the guy at the refill shop used.
I am sure it will be kill or cure...
Deleting the printer and reinstalling it should be the next step to try. Sometimes my printer goes a bit eccentric or gets in a bad mood if I try and pause or cancel printing from the printer menu. I have learned not to do that with any HP printer. Once it gets in a bad mood the only cure is to disconnect it from the mains and leave it for half an hour before plugging in again.
My printer, incidentally, is a Deskjet 96 Cxi professional machine. I like it because it prints both sides of the paper and it cost me nothing.
Mar 06, 2016 | HP Officejet Pro L7580 All-In-One InkJet...
Tip
How to clean ink cartridges HP deskjet printers
You need the following items to clean the print cartridges:
• Distilled water (tap water can contain contaminants that
can damage the print cartridge)
• Cotton swabs or other soft, lint-free material that will not stick
to the print cartridge
Be careful not to get ink on your hands or clothing as you clean.
To prepare to clean
1. Open the HP Deskjet cover.
2. Wait until the print cartridge cradle moves to the
center of the HP Deskjet and is idle and quiet.
3. Remove the print cartridges and place them on a piece
of paper, with the copper strips facing up.
CAUTION: Do not leave the print cartridges outside the HP Deskjet for more than 30 minutes.
To manually clean print cartridge contacts
1. Lightly moisten a cotton swab with distilled water and
squeeze any excess water from the swab.
2. Gently wipe the print cartridge copper contacts with the cotton swab.
CAUTION: Do not touch the print cartridge ink nozzles. Touching the ink nozzles will result in clogs, ink failure, and bad electrical connections.
1 Ink nozzles (do not touch) 2 Copper contacts
3. Repeat this process until no ink residue or dust appears on the swab.
4. Insert the print cartridges in the HP Deskjet, and then close the cover.
on Mar 16, 2008 | HP DeskJet F380 All-In-One Printer
HP Deskjet 5150 poor print quality
For poor printing problems I suggest you run the Tap 10 diagnostic print test (see link to video below).
If the new (or refilled/reman/compatible) HP 56, 57 or 58 ink cartridge refuses to print black/color and/or function at all (i.e. blinking ink light on Deskjet 5000 series printer) or fails to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), the rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance. It is suggested you perform the TAP 43 (and TAP 10) DIAGNOSTIC PRINTER TEST to evaluate the ink cartridges electrical performance. Visit Inkjet411 support site to see instructional video: http://inkjet411.com/?page_id=2358
NOTE: For the HP Deskjet 5000 series printer models, when you get an HP 56, 57 or 58 integrated ink cartridge refilled (i.e. currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels are not initially reset. However, continuing to use an ink cartridge which displays LOW INK alerts is permitted by the printer, simply select OK, CONTINUE or DISMISS when these alerts are observed. Now, it is possible to reset the ink levels by performing the procedure outlined on Inkjet411's site: http://inkjet411.com/?page_id=1915
To clean the HP 56, 57 or 58 ink cartridges please visit the Inkjet411 site which provides recommendations on how to clean the electrical contacts, flex driver cables and how to perform a hot water flush of the nozzle plate (refer to video): http://inkjet411.com/?page_id=1519
Jan 17, 2013 | HP DeskJet 5150 InkJet Printer
Print only red and black
First, use the HP Printing Assistant software to check the ink-level in the tri-colour ink-cartridge.
If empty, refill or replace the ink-cartridge.
Then, use the same software to run a few "print-head-cleaning" cycles,
just in case that some of the "colour" ink-jets are clogged.
Jan 05, 2011 | HP Deskjet 1120c InkJet Printer
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    My printer is not printing out any black ink onto paper. Only the color is printing out onto paper. I put two brand new cartridges in for the black ink and color ink, and it says that the ink levels are...
    You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It’s best to do this each time you install a new cartridge. for more information….... http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
    Sep 03, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
    HP 970 Cxi. Problems with colour printing. Ink cartridge is new
    I have the same problem. I suspect the ink cartridge part # 78 that you and I bought has problem. I plan to return it today to the vendor.
    Nov 15, 2009 | HP DeskJet 970cxi InkJet Printer
    I have a HP Deskjet 882C printer and for the past month we are having problems printing text (B&W). We have removed the black ink cartridge and it still has a lot of ink in the cartridge. When we put a...
    To clean the HP Inkjet print cartridges from the HP Toolbox, using a Windows operating system, perform these steps:
    1. Double-click the HP Toolbox icon on the computer screen.
    2. Click the Printer Services tab.
    3. Click Clean the print cartridges and follow the directions on the screen.
    If the print quality improves after completing this sequence once, but the quality is still not quite good enough, repeat procedure. Start at Step 1, or click the Clean Again button on the final cleaning window. If this process does not improve the print quality, the HP Inkjet print cartridges might be low on ink. See the document that is provided with the black HP Inkjet print cartridge for instructions about how to use the ink level sensor to determine if the cartridge is low on ink. Replace the HP Inkjet print cartridges, if appropriate.
    Jun 25, 2009 | HP DeskJet 882c InkJet Printer
    Red will only print on test page.
    So what you need to do is clean the cartridge from the printer toolbox..do all the three steps cleaning..(clean cartridge,prime cleaning,intermediate cleaning)..
    once the cleaning is done..try to make a copy..if its still the same..change both the ink cartridge and then try to make a copy..if it resolves the issue then cartridge is defective..if it does not resolve the issue then printer is defective..
    Mar 09, 2009 | HP DeskJet F380 All-In-One Printer
    Epson Stylus Photo R220 InkJet Printer Logo
    133 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
