Question about Sony Playstation 3 (PS3) Console
Dns error on my ps3 I am using linksys router
  • michelle1022 Jan 30, 2009
    Thanks, unplugged router and reset it and it worked!
  • Paul Homuth
    Paul Homuth May 11, 2010
    is it wireless or wired., and do you have a key put in if its wireless
    Problem Solver:
  • 6 Answers
If this does not happen often, it could be your internet provider. I can sometimes unplug my modem and router and fix this. However, if this continues, you may need to contact your ISP or look into a new router. Believe it or not, your internet company can be pretty handy in getting you re-connected.
Posted on Jan 30, 2009
The DNS error on my PS3 from LINKSYS
your wireless network should be configured to NOT broadcast the SID and a WEP key. Then after entering the address of the router manually in the network setup on the PS3, you will able to obtain an ip address from the router
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
DNS 807101102. An error occurred during
if wireless how much % of signal do you have?, does it do it all the time? what router are you using? some routers have to be set diferently than normal in order for you to be able to play. change your ps3 IP adress one number up exanmple if its 192.168.10.172 change it to 192.168.10.173 or try this link if you have a linksys router it seem common for that router to get that error-http://boardsus.playstation.com/playstation/board/message?board.id=psnetwork&thread.id=116102
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
Connect ps3 to laptop via web and walk
Connecting PS3 to a network I have LinkSys wireless router which is working perfectly for other devices (like laptop, Xbox360, TiVO). My wireless network is configured to NOT broadcast the SID and with a WEP key. After entering this manually in the network setup on my PS3, I was able to obtain an ip address from my router, I was able to open the configureation page on my router, but connecting to the internet would fail with some kind of DNS error. The way this was resolved for me, was to enter the DNS server addresses manually in the PS3 network settings AND use tetertiary DNS server from my ISP as either the primary or the secondary DNS server. ..btw, this also fixed the similar problem I had with my PSP.. Thanks!
Jul 29, 2009 | Sony Computers & Internet
I am trying to hook up my ps3 to the internet ihave wireless-g broadband router every thing gos through but when i try to up datesystem an error occurred during communiction with the server this is an...
hey...
call ur ISP ans ask for their DNS settings the go to the advanced settings on ur PS and fill in the blanks
they should give ur primary and secondary DNS settings
that should do the trick!
Apr 10, 2009 | Linksys Wireless-G WRT54G Router
Not connecting
reset the router and then upgrade the firmwere.
-tg
Jan 08, 2009 | Linksys Wireless-G WRT54G Router
Internet connection failed but IP address obtained.
Check to make sure that your router has gotten an IP Address from your ISP. Because you PS3 is telling you that it has an IP from your router. This means that the Router to PS3 connection has layer 3 connectivity, but what about from your router to your ISP? check that in the router by logging into the router's web page and going to the status page it should have your information from your ISP if it does not make sure that the main page is set to the proper settings either get IP automatically (Cable Modem) or Get PPPOE (DSL) connection (Make sure that your password information is correct to).
Now after checking these items make sure that you set the router up as the DNS for your network buy setting this on the status page then in your PS3 (set the DNS setting to point to your router, and set your router up as a caching DNS server).
Then power cycle the router after saving everything, and power cycle your PS3 after setting everything. This should clear up your problem.
Thank you,
Shuttle83
Oct 24, 2008 | Linksys Wireless-G Broadband Router
Roy lee
Finally the DNS problems I had with connecting my PS3 to my network has been resolved. I have LinkSys wireless router which is working perfectly for other devices (like laptop, Xbox360, TiVO). My wireless network is configured to NOT broadcast the SID and with a WEP key. After entering this manually in the network setup on my PS3, I was able to obtain an ip address from my router, I was able to open the configureation page on my router, but connecting to the internet would fail with some kind of DNS error. The way this was resolved for me (and I know someone else mentioned it in an other post here), was to enter the DNS server addresses manually in the PS3 network settings AND use tetertiary DNS server from my ISP as either the primary or the secondary DNS server. Voila... I am upgrading my PS3 software as I write this.... ..btw, this also fixed the similar problem I had with my PSP.. Thanks!
Aug 26, 2008 | Sony Playstation 3 (PS3) Console
Random DNS Error
You may need to manually configure your PS3 connection on the console. Let's see.. I can suggest to first go to your Settings Menu -> Network Settings -> Choose:"Settings and Connection Status List" this will display a pretty detailed information about your connection to your local gateway (router).. Check specifically for Primary and Secondary DNS. In my experience, using the PS3's auto setup for the connection seems to enter the default gateway's ip (labeled "Default Router" on PS3 Status Screen) in place of the real DNS entries..
Question
: Sooo how do you check your primary/secondary DNS for your network? Answer: On your PC, open a web browser and enter your default gateway ip into the browser.. log into your router (assistance can be found in your router manual or by calling your router manufacture). You should see a status page of sorts that displays your ISP's primary/secondary DNS entries.. Simply transfer those two IPs to your PS3 manually to correct the DNS issue.
Hopefully that should resolve your issue!
Jul 10, 2008 | Sony Playstation 3 (PS3) Console
PS3 says DNS error (80710102) when i try to connect to the internet with a wired connection
for mine i tried other fixes and they didn't work. Turns our my router had enabled security but the PS3 had forgotten the password (WEP key).
I turned off the WEP on my router and the PS3 suddenly found its connection.
To say I was getting stressed is an understatement, Sony should put something on their website, it seems like a really commonm problem to which people have no clear route to solution.
Dec 21, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
22 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
