Question about Maytag PYE2300AY Electric Dryer
Dryer Does Not Start
No lights, will not run. Nothing coming on. There is power to the dryer. Could it be a control problem or is there a fuse in the contol circuit. Please answer ASAP. Maytag Dryer Model # PYE4557AYW This is the model #
Thank You
Thermal fuse located on side of heating element
Posted on Feb 17, 2009
New dryer running on high heat. I was doing dishes using hot water & noticed the dryer stopped. Its fuse had tripped. Once I fixed that, I let the dryer complete the cycle without using hot water.
if you start the dryer with nothing else running and it doesn't pop the fuse then it's not the dryer,if it was the dryer the fuse would pop no matter what,i would call an electrician in to check the fuse box,if you start each appliance by themselves and it doesn't trip the fuse then it has nothing to do with any of the appliances or the fuse would trip if there was a problem,somehow the way your box is wired the appliances are somehow connected and the fuse is popping,i would start with an electrician,somehow it's drawing over what the fuse can handle only with the dryer and one of the other appliances running,i have old wiring in my house,i was putting in a new fan light,i took the fuse out and still got popped even though the light and fan wouldn't work,whoever worked on the wiring jumped power from another room and i had to remove both fuses to finally kill the power,you might have the same thing going on,that's an electric dryer so it uses 240 volts,someone might of tapped off of another power source in the house to get the other leg or 120 volts so the hot water tank and dryer could be connected even though they have their own fuse,i guess you could remove the hot water tank fuse and start the dryer and see what happens,it might not start or if it starts you might have no heat in the dryer because like i said it has 240 volts going to it but it sounds like they are somehow wired together.hope this helps.
Dec 28, 2017 | Dryers
Dryer will come on but wont start. Sensing light is on
-There are couple things that cause a dryer no to work:
-Thermal fuse, heater element, door switch, start switch.
Good luck
Mai
Nov 10, 2013 | Whirlpool Cabrio WED6400SW Electric Dryer
Maytag Epic dryer model MED9800TQ0. Dryer was running fine, changed loads, held the start button down, it beeped and attempted to turn the drum, clicked and nothing. All the controls light up, timer...
does the element come on at this point ?
I'm not sure if you tried this already or not, but i would unplug the unit and wait a min and plug it back in and see if it resets and then works again . you could have had a power surge .
Nov 05, 2013 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
Kenmore HE5 dryer won't start
Several different problems could prevent your dryer from running. Make sure that the door is firmly closed and hold down the start button for a couple of seconds to start the dryer. If you hear a click from the control board then the door switch and the control board are likely okay. You could have a blown thermal fuse or a broken belt in the dryer. To check these components,unplug the dryer and remove the bottom front service panel as shown in the first image below. With this panel removed, you can tell whether the drive belt is broken. If the drive belt is okay, I recommend checking the thermal fuse. This fuse is located on the blower housing as shown in the second image below. It will have light blue wires attached. To test the fuse, remove one wire and measure the resistance across the leads of the fuse with a volt/ohm meter. You should measure near zero ohms of resistance (continuity). If you measure infinite resistance, then the fuse is blown and will need to be replaced. You can verify that this is your failure by taping the contacts of the light blue wires together with electrical tape to "bypass" the thermal fuse. Reassemble the dryer and see if the motor runs with this fuse bypassed. If it does, then this verifies that the blown thermal fuse prevented the dryer from running and that this was the only failure. NOTE: Do not continue to run the dryer beyond this brief test with the thermal fuse bypassed. This component must be replaced. It is an important safety feature of the dryer.
You can order a new thermal fuse from the Sears PartsDirect website. The part number is 3392519.
May 01, 2012 | Kenmore HE5 Electric Dryer
Dryer will not start. Start control engages solenoid and holds contacts closed, but nothing else happens. Solenoid disengages when door is opened and light does come on. Wiring contacts all appear tight...
Check for power through the soleniod... if power is going to the motor and it is not running then the motor is shot...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 14, 2011 | Kenmore 63942 Dryer
The dryer won't turn on. The fuses are good, the power is good, the condenser is good and the motor is good. The light on the panel come on but nothing happens. Is it the circuit board?
Dryer Repair - The
Dryer Repair - The
heatman101
Feb 26, 2011 | Bosch Axxis WTA 3510 Electric Dryer
Bosch axiss dryer WTA3510US wont run checked power, fuses. i close the door hit start the drying light comes on but nothing happens no clicks noies's nothing. is it the relay board or somthing else?
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Sep 14, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Dryer wont start,
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Jul 24, 2009 | Bosch WTMC652SUC Gas Dryer
Electric dryer won't start
HI, check the following to address this issue you are experiencing.
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Jun 02, 2009 | Maytag MDE2600 Electric Dryer
Whirlpool dryer LGR7646EQ3. Burner lights before pushing start.
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the ignitor and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot ignitor and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
more here
Dec 15, 2008 | Whirlpool LGR7646E Dryer
Maytag PYE2300AY Electric Dryer Logo
341 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
