Question about Karcher 2500 PSI Pressure Washer
Karcher k7.80 pressure washr
It seems to be leaking from the outlet hose and has lost pressure and keeps turning on and off HELP
  • 2 more comments
  • eiggam Dec 17, 2007
    I have a small karcher water blaster and it seems to be leaking on the inside, which I cant get to because it needs some special kind of screwdriver/allen key type tool. to undo the cage. Any ideas please.
  • Anonymous Feb 09, 2008
    i have a karcher k2.87 i have taken the back off (with the screw drivers readily available at bunnings) once we got the back off the whole unit is sealed for safety. So i guess i am left with no alternative to seek out a licenesed repairer.?????
  • HAL9001 Jul 16, 2008
    I have a Karcher K3.86 M electric PW with a water leak problem that also causes the pressure to surge on and off. It appears that the plastic pump housing might be cracked but the crack is so thin it's hard to know for certain. I read on another site that these plastic pumps will crack if water is left in them and it's allowed to freeze in the winter. I think that might be what happened to mine but I cannot be certain.
  • Anonymous Mar 21, 2014
    the high pressure hose keeps popping off when you start it up
I have a Karcher K 3.86 M electric PW with a similar problem: water leaks from the pump near the outlet and the pressure surges on and off continuously at intervals of 1-2 seconds. The leak appears to be coming from a very thin crack in the plastic pump head in what I think is the "unloader" valve portion. I read elsewhere that if you leave water in these PW's and it freezes it will crack, causing leaks. I don't know how you can empty all the water out so I think we must store these PW's in areas that won't freeze in winter.
Posted on Jul 16, 2008
Throw it in the bin and get a proper make. By the sounds of it karcher is a crap make
Posted on Dec 28, 2007
Karcher Leaking from Back or inside...Help please
Karcher pressure washers are very sensitive to over-winter freezing. The plastic parts break, and you have to replace all of the leaking parts.
You may be missing a locking tab, without seeing the thing apart next to the exploded parts view, it's really hard to tell. Search google for "karcher parts", and put in your model number...
Aug 03, 2015 | Karcher Garden
My winner 11, has developed a bad leak and has lost pressure, i assume I need a set of O rings, where can i purchase spare parts, i live in Adelaide
If there is no Karcher agent near you, most hardware shops and bearing outlets keep a range of o rings in stock. Take samples ot the part with you to get the correct size and thickness of o ring for your needs. Remember to put a bit of lubricant on the o ring when installing it.
Apr 07, 2011 | Karcher K2.26 Electric Power Washer
It's a Karcher presure washer K2.54, one and a half years old. Was working fine last time but when turned on now there is very little pressure through the hose and the water seems to be filling up inside...
this sounds like the seals may have been damaged inside the pump or that the water inlet/outlet could be damaged. If you take off the front cover (use a star bit screw driver) then run the pressure washer you will be able to see were it is leaking from and then you can get the right part to replace it.
Mar 16, 2011 | Karcher Garden
Karcher pressure washer hunts ~ off/on ~ when running. How do I fix?
HI Your machine wil start and stop if you have any external leaks when the machine is running at not pressing the trigger. Please start the machine and not pull the trigger and look form leaks. A common one is around the high pressure hose outlet and also the trigger.
Jun 11, 2010 | Karcher 1750 psi Electric Pressure Washer
Water is leaking from under the chrome piece inside my Karcher 3.68m pressure washer. Hose intake and outlet look good. Any sugeestions.
Plastic Pump Manifold is cracked.
Can be replace at a local Karcher Service Center, or if you are mechanically handy. Replacement Manifold Complete, is available from www.karcher.com.
If it is under 1 year old, and under warranty Karcher will replace if you have a Receipt proof of purchase.
Jun 08, 2010 | Karcher K3.68MR Factory Refurbished 1,800...
I have a Karcher pressure washer that leaks from the pump when operating.
could be little plastic pressure hose outlet,they can be porous and let pin holes of water through,pull plastic casing apart and remove high pressure hose outlet (black 'L' shaped pipe gun pressure hose outlet,ive repaired a couple,and machine works fine after
Oct 18, 2009 | Garden
I have a 3000 psi karcher pressure washer with honda engine, the problem is for a while the pressure would kick in and out, now only water hose pressure, the water supply is fine, what is the problem
sounds like you need a seal and bladder rebuild < if you liver in a cold environmet for winters please dont forget to winterize your washres every year before winter
Sep 15, 2009 | Karcher G3025OH Pressure Washer
I've got a K2.55 Karcher , leaking
The gasket to the head is leaking. It is best to get a new Machine, Folllow the instructions for storage when you get the new one, do not leave water in it whan you put it up.
Sep 04, 2009 | Garden
Karcher KB 499
Hi the pump surges when there is a leak on it find the leak that should sort your prob.
Hope this helps. Sean
Feb 17, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
1,425 people viewed this question
Top Karcher Garden Experts
John Trevino
Ian Summerfield
Ian Summerfield
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
