Backlight inverter Hello~ I have done the check with the flashlight,I believe I need to replace the backlight inverter. How can I find the part that I need and install it? Thank you
  • 98 Answers
You neet contact authorized service or part supplier.
If can buy it , easy to fix.
open the back cover, & unscrew the inverter's & replace it!
Posted on Feb 06, 2009
I have a proscan PLDED3996A TV that will turn on for about a minute then it loses its picture and has only sound. Then if you turn it off and then back on, you’ll have picture for shorter intervals each...
As far as finding replacement inverter you can do a search via google to see what you find. However, the inverter can be built into the main board of the TV, which would require you to replace that. I found through a quick search that the main board can be had for about $30. http://tvchopshop.com/all-tv-parts/proscan-plded3996a-e-main-board-3393a-zp-vst-3393-a-refurbished/
It could also be a power supply problem too, bad caps, as well as the backlight itself. It looks like you could contact the above site and ask them the typical failures of this TV for the symptoms you are seeing. If you consider yourself experienced with electronics repair, you could repair it yourself. Otherwise consider a new TV or taking it in to a repair shop.
Dec 26, 2017 | Proscan Televison & Video
LG 47LN5750 No picture
If you have backlights its not going to be the tcon for future reference. you have some shorted or open LEDs in the panel. Check the voltage going to the LED sets, should be 100 plus volts
Nov 16, 2017 | LG Televison & Video
Why is my T.V. loosing backlight but not sound?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Feb 28, 2016 | Insignia NS-55E480A13A
What parts do I need to fix my TV?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jan 11, 2016 | LG Televison & Video
HOW DO I FIX MY LG 42LE5300 TV?
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Sep 11, 2015 | LG 42LE5300 42 HDTVReady LCD TV
Proscan led 39" tv no picture
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions
May 21, 2015 | Proscan Televison & Video
Samsung LN46C630K1F No Backlight, Replaced Board, Still Doesn't Work
because you see a picture with a flashlight it means your power supply is fine. you probably need to replace the backlight inverter board if you haven't done so yet.if that doesn't fix it then you have a bad panel, and at that point it will be too expensive to replace. Good luck!
Mar 04, 2014 | Televison & Video
I have a samsung ln-t4053h that had a bad caps. I replaced the caps and the tv turned on fine and i put a flashlight to the screen and the screen turns on but the backlight is on 10 and it looks like its...
Apr 23, 2017 | Samsung LN-T4053H 40 in. LCD Television
Picture went out on p50hdm Vizio Plazma tv after loud POP
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 26, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
My acer laptop screen is dark
If your laptop screen is dark, it could be the backlight,inverter, or bad lcd. You can test the backlight by starting the laptop and give it a few seconds to load and take the laptop in a dark room and shine a flashlight on the lcd and see if you can see any pictures or icons. If you can, you may just need an inverter to correct the issue, If not, you may need to replace the inverter and lcd both.
If you find that you need parts to correct the issue. I would suggest that you begin with replacing the inverter first, as they are usually less expensive.
If you can supply me with the model number of the specific laptop you are having trouble with and I can try to locate more information on replacing the parts.
Thanks
Jul 23, 2008 | Computers & Internet
Televison & Video Logo
177 people viewed this question
Top Televison & Video Experts
