Question about Dell 926 All-In-One InkJet Printer
Says it's printing but it's not
When I give the command to print, the printer acts like it's going to,,,,, it says printing on the screen,,,,,but then it does nothing. Any ideas?
  • rhonda629 Jan 30, 2009
    I tried that but it's still not working.
    Scholar:
  • 118 Answers
Go to your "start menu" and look for "printers and faxes" then after that it should bring up a screen with your current printers and faxing machines. Make sure your Dell 926 InkJet has a little black check by it. If not then right-click the Dell InkJet and select "set as default printer". If it already is, then right-click it again and make sure it isn't paused. It will give you an option to "resume printing". After that then it should work. Make sure to also delete the old printers that may be on the computer too, the reason is because it may block out your other computer.
Posted on Jan 30, 2009
Try changing your firewall, it helped me. I had no problem until I did a factroy restore on my Inspiron. On a whim I downloaded a freebe, Comondo which was very agressive. Had any communication problem you could inagine, wouldn't delete, print. I remembered that McAfee used to crash and freeze my old Emachine so I reinstalled my Norton and it is happily printing.
Posted on Feb 06, 2009
After giving the print to immage runner 400s copier the print sends to the copier. The data button blinks once. but print out automatically cancels. why?
Windows Server 2003/Thin N Computing thin client L300 Printer Epson FX2175 installed with thin client when dos base print command is given 1st page is printed but when 2nd print command is given printer gets offline either switch off printer before giving comman or print from printer properties. Again third page print command is taken by printer (For alternate pages print command printer gets offline automatically)
Aug 29, 2012 | Canon imageRUNNER 400S Copier
Paper jam p1005 hp printer
Load paper, give print command verify weather pick up roller trying to pick paper?.. >if yes check pick up roller surface feel smooth?, replace it.. >if no remove right,left and back covers, check solenoid jammed? release it.shoot print command check> if solenoid not acting replace it and verify..
Jan 09, 2012 | HP Office Equipment & Supplies
I Have A Epson PLQ-20 passbook Printer and it is connected through USB cable. after successful setup when i give print command to the printer it is not responding and nothing happened.
Sep 20, 2011 | Epson Passbook PLQ-20 Matrix Printer
My samsung clx3160pn all in one color lazer printer copier scanner fax, I wanted to copy a couple things on the internet example a recipe it only prints the heading such as the bold print before the...
When you give the print-command you can look before you print if there is a print-exemple on the screen. Is the text already gone there? Than it is a problem of the website you are printing from. You can try to install google chrome (not internet explorer) and print from there. Maybe that is better.
Sep 06, 2011 | Samsung CLP 300 Laser Printer
How to set fanfold 8.5 x 12 page in Tally 9
when you giving print command choose the printer and go to printer option and choose the paper type then give the print command .
Jan 20, 2010 | Tally T2245 Matrix Printer
Printing is not happening with Outlook 2003
when you give print command from outlook mail just see which printer you selecting if have more then one printer remove it and set the default printer .when you giving print command choose the paper type also correctly.
Sep 15, 2009 | Microsoft Office Outlook 2003 for PC
XP SP3 sends docs to print que but nothing prints
Open up your print queue. Cancel All jobs.
Go to the start menu and either click on, or search for cmd. This will open the command window. You also need to open your task manager.
In the task manager, search for a process called spoolsv.exe, or if that doesn't exist, find a process with "spool" in the name. This is your print spooling process. Right click the process, and end it. You can close the task manager now.
Next, go to the command prompt. Type "net start spooler" without the quotes, and hit enter. This should restart your spooling process. Close the command window, and try to print.
If this doesn't work, you should check to make sure you're printing to the correct printer. If it doesnt solve the problem, uninstall your current printer (you may have to end the spoolsv.exe process again), and reinstall the drivers for your particular model, which you can find at the manufacturers website.
Jun 23, 2009 | HP Remanufactured Compaq Presario SR1130NX...
My printer won't print from the computer command; it will print fax or copy a paper.
MY PRINTER WONT PRINT FROM THE COMPUTER. IT WILL COPY A PAPER, BUT NOTHING FROM THE COMPUTER COMMAND.
Nov 04, 2008 | HP Officejet 5510 All-In-One Thermal...
Lexmark z23 will not print
go to the printer properties---there select printing preferences ---there select lexmaxr solution center-----in that option select printer cartridge replacement option----in that follow the replacement instructions.and select the cartridges.as it is new.and its proper appropriate number.then only it will print properly. selecting the cartridge is very much necessary.
Sep 12, 2008 | Lexmark Color JetPrinter Z23 InkJet
Dell 926 All-In-One InkJet Printer Logo
1,303 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
