Question about Quartet gbc Shredmaster 5550X Confetti-Cut Shredder
Plug in outlet, make a clicking noise but light doesn't come on
It won't shred
No power. worked perfectly last shred. Now no lights illuminate when switch is on,
Does the outlet it's pluged into have power? check with another appliance. If power could be a number of things, plug connection to cord, connection inside, switch. Did the shred actually finish or did it stall and still som inside?
Mar 17, 2015 | Office Equipment & Supplies
Tv won,t come on makes beeping noise
Try unplugging from outlet for fifteen seconds. Press the power button for a few seconds "before" plugging back in. Now plug back into the wall outlet and try turning it on to see if this reset the TV's settings.
Sep 28, 2014 | Emerson Televison & Video
Sharp R-1870F Microwave Won't turn on
Could be just a fuse but probably the diode pack or magnetron.
May 24, 2017 | Sharp R-1870 Convection/Microwave Oven
Hotpoint rvm1625sj01 no power
Hello
Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Oct 04, 2011 | Hotpoint RVM1625 Microwave Oven
Manual test does not work Looks like it does but water does not come on
If the manual test doesn't work, I think the auto function won't work either. If that is true, your timer is running on the battery and there is no power. Remove the battery and see if it appears to be working. If not, check your outlet to ensure that there is 120 volts ac. Plug a light or shaver into the outlet. If the outlet is good and the clock has no power when the transformer is plugged, you probably need a new transformer.
Gary
Sep 26, 2011 | Orbit 57882 9 Station Super Dial...
Machine not turning on
1. Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
2. Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
3. Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
4. Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Hope i could help you.
Have a nice day : )
Sep 04, 2011 | Microwave Ovens
My fridgedaire window unit A/C and heat won't come on. I had replaced an outside light fixture a couple of weeks ago and had turned off the circuit breaker that affected this unit too. Now the unit...
Plug a light into the outlet used for the A/C, if the light does not come on when reset then the circuit breaker that provided the power to the outlet need to be reset or replaced.
May 22, 2011 | Frigidaire FAS257S2A WallWindow Air...
When I turn on my set, light turns green, then after 30 seconds turns red won't come on
Sounds like there is a problem with the power supply. Try unplugging the T.V. and hold the power button for 30 seconds. Plug the T.V. back in and see if that helps. If it doesn't try switching to another outlet, and if that doesn't work then you may need to replace the power supply which would probably cost anywhere from 140 to 200 for one.
May 05, 2011 | Fujitsu PlasmaVision P50XHA40US 50 in....
Will not shred, but makes clicking noise, will run in reverse
Possible that the actuator which feeds paper in has gotten affected. With the unit UNPLUGGED try looking to see if some paper has gotten wedged in there. If you can disassemble it you might be able to see the problem. Good Luck.
Aug 04, 2009 | Fellowes 3011001 Shredder
Quartet gbc Shredmaster 5550X Confetti-Cut Shredder Logo
63 people viewed this question
Top Quartet gbc Office Equipment & Supplies Experts
Pie-man
Level 1 Expert
pantomac nv
pantomac nv
Level 1 Expert
Bill Boyd
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
