Question about ViewSonic NextVision N3760W 37 in. LCD Television
Tv goes off and then comes back on when changing the channel
Same with adjusting the volume
  • patrick66_18 Jan 30, 2009
    how expensive is it to fix? I cant get the tv repair shop to even look at it. I'm hearing that its hard to get the part from viewsonic.
    Sergeant:
    Champion:
  • 267 Answers
YOU MAY HAVE A PROBLEM WITH THE POWER SUPPLY BOARD.
Posted on Jan 30, 2009
SOURCE: sanyo vizon dp42746 problem
me too i bought mine like 11/2 years ago
Posted on Jul 20, 2008
salsaurbana
  • 56 Answers
SOURCE: mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Posted on Nov 20, 2008
MNfisherman
  • 11896 Answers
SOURCE: TV won't change channels or adjust volume
Do you have a universal remote? If the batteries are taken out for a little period of time, the remote will loose the codes and they will have to be reset. You can find the codes by google universal remote codes.
If you have a factory remote that came with the television, than it may be faulty or the sensor on remote or tv may need to be cleaned.
Posted on Mar 11, 2009
SOURCE: can't turn tv on with remote, only manually, when on volume is at 100 and cannot be adjusted with remote or manually. channels cannot be changed with remote or manually. Changed batteries in remote,
replace with new batteries and it works --- so simple
Posted on Sep 22, 2009
  • 139 Answers
SOURCE: How do I change the power supply for my Viewsonic N3760W TV?
YOU HAVE A VOLTAGE/CURRENT LIMITER PROBLEM THAT IS PROBABLY CAUSED BY A LEAKY CAPACITOR IN THE FEEDBACK CIRCUIT IN THE POWER SUPPLY. THIS CAN BE FIXED. I CAN GUIDE YOU IF YOU CAN SOLDER AND FIND THE PARTS- RADIO SHACK OR MABYE AN OLD TV AROUND?
Posted on Dec 27, 2009
Testimonial: "Awesome help."
Black box in middle of screen/picture
Closed Caption function to that channel you select is ON. Make it OFF, when you are in that channel which displays this black box. It will be best to reset the TV to its factory settings first, and then re-tune it. for more details, refer its user manual.
Jul 10, 2012 | RCA L32WD26D HDTV/DVD Combo
Dec 27, 2009 | ViewSonic NextVision N3760W 37 in. LCD...
I have a volume problem. When I adjust the volume at a listening level, a high pitch sound can be heard then the volume turns low and goes back to the set level. It happens in every channel (Direct TV)....
No ,replacing speakers will not fix the problem these sets are very well know for Poor Solder and connection ,resolder signal,Audio,& power supply boards this should correct the problem and alot of future ones too.
Sep 16, 2009 | Mitsubishi WS-65711 65" Rear Projection...
Lg lcd tv keeps changing chanels
Come on, lets try to solve this. Take the batteries out of the remote so it can't interfere and try changing the channels and volume with the buttons on the tv. If this works then someone has spillled something onto the remote and gummed it all out. You simply need to take the remote apart and clean it out. If the buttons on the tv do th same as the remote did then yes, take it back.
Aug 08, 2009 | Televison & Video
Low volume on some channels
Well, some TV stations do broadcast at different volume levels. This is very noticeable when watching a TV show and the volume seems normal and then when a commercial comes on, the volume is very loud. They do this to get you to pay attention to the commercial. Another problem might be that you are adjusting volume from both your TV and your cable box. What you should do is make sure your cable box is set to "FIXED VOLUME" and then just adjust your TV volume. Fixed volume will have the cable box output only one volume level, letting the TV do the adjustment. Just go through your cable box setting and look in the audio settings. Hope This helps...
Mar 14, 2009 | Element Electronics FLX3711B 37 in. LCD TV
Samsum PLH403W service menu
Here is how you get to the service menu. Just be sure to write down anything you change in case you want to change it back.
1. TV turned off
2. Press 'Mute' then '182' then 'Power' buttons on the remote.
You are now in the Adjustment mode
4. Use the 'Channel up'or"Channel dwn' to select the category.
5. Use the 'Volume up or dwn' to enter the category.
note:Some models may not have Category Selection.
6. Use the 'Channel up or dwn' buttons to select item to be adjusted.
7. Write down the old value of the item before changing.
8. Use Volume up and down adjust the value.
9. When you have made all the adjustments you want turn the set off to exit.
Feb 01, 2008 | Samsung PLH403W 40" Rear Projection...
CHANNEL INDICATOR WON'T CLEAR
This is a setting in the menu set-up somewhere or simply press the display button on the remote control unit.
Jan 21, 2008 | Televison & Video
Sound with no picture
the problem is in the backlight try to measure the supply.and replace the inverter.
Dec 05, 2007 | Toshiba LCDTV/DVD Player 19HLV87
TV turns on and changes channels on its own
Keeps changing channel
Check voltage on D12 if below 4.8V then change
Changes channel or volume adjusts by itself
Check S900/1/2 on pcb H1, alternatively this could be due to failure of IC005 (CD4052BCM-FL63) on pcb A
Oct 17, 2007 | GE 31GT740 31" TV
ViewSonic NextVision N3760W 37 in. LCD Television Logo
111 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
