Question about Samsung SGH-J600 Cellular Phone
Can we see videos in wide screen ?
I want to know if we can see videos in full screen. i cannot find option to see videos in full screen.
  • Anonymous Jan 31, 2009
    when i see video song then i cannot find the option for full screen
    Problem Solver:
  • 10 Answers
NNNNNNNOOOOOOOOOOOOOO!!!! it cant support ur phone.....
Posted on Feb 19, 2009
Picture screen
This is a general explanation but they are all set basically the same way. Hit the menu button on the remote. Toggle to video then to display options. Most likely format will be an option to select. Hit that and then toggle to which layout you want.
Nov 17, 2013 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I just turned on my ps3 and it was zoomed in really far and no matter what i did, display settings or video setting nothing fixed it.
it must be your tv settings. as far as i know, the ps3 wont do that. if it did i wouldn't think there is an easy fix. on your tv remote is there a button that you can change the display setting? say, from full screen to zoom? usually named "wide" "view" "theater" if so then you need to make sure its set to full screen mode. keep changing the display option and you should see a better picture. if there isn't a button, go into the menu settings, the picture or display settings and change it there.
hope that helps
Apr 17, 2011 | Video Game Consoles & Games
The image is too wide
It would be helpful if I knew what else you had in the setup. Mostly I just need to know if you have a cable box, I will assume this is the case.
I had this problem with my Tv, if it running through a Bose system the problem is most likely with the Bose system, you need to go into the options and go to picture and select Full Screen instead of widescreen.
If you are not using a Bose system then the problem is still fairly simple.
  • Look at your remote for the Tv, locate the menu button and press it. A menu should come up.
  • There should be a video or screen option in the menu select it.
  • There should now be a wide variety of options to choose. Choose the normal option.
  • Then close the menu the video should now fit the screen.
If this doesn't work then it be your cable box, to fix that you follow the same steps just using your cable box remote instead of the Tv remote.
If this doesn't work comment and I will see if I can figure out another problem.
Hope this helps.
Chengeaj
Mar 07, 2011 | Toshiba Regza 42RV535U 42 in. LCD HDTV
Does not show full width of screen.
Under the settings, there's typically an option for the video width.
Under settings, go to Screen settings, then change the wide mode options to FULL.
This will make the picture fill the entire screen.
If that doesn't work, you may not be viewing an HD source. Change to an HD channel and you should have a full screen picture.
Mar 05, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
40 in LCD Proscan TV, Horizontal pic too wide, adj?
just look at the owners manual of how to adjust the picture
Jul 23, 2010 | Proscan 42LA45H 42 in. LCD TV
Hi, I was recently given a Samsung Syncmasster 2333sw flat screen monitor that I hooked up to my old Dell Dimension 8200 desktop.The monitor says the optimum resolution is 1920x1080 pixels. The maximum the...
hi bob you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only) Note When TV signal is input in AV mode ,select “Screen Fit “to adjust vertical position in 0-6 levels. Image Size Note Supplied for the wide models only such as 16:9 or 16:10. You can change the size of the screen displayed on your monitor. PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals. Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed. AV signals • 4 : 3 - Sets the picture to 4:3 normal mode. • 16 : 9- Sets the picture to 16:9 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • 4 : 3 - Sets the picture to 4:3 normal mode. • Wide-Sets the picture to 16:10 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note • It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • When the panel is of 16:10,the screen size options include “4:3”,”wide “,”Screen fit“.hope this helps
Jun 22, 2010 | Dell Dimension 8200 PC Desktop
My 62 '' JVC tv has gone from wide screen to smaller and I don't know how to change back to wide screen
You can go into your menu options for screen set up and switch it to full screen. Heres a website that will be helpful to you resources.jvc.com/resources/00/00/93/YA300ien.pdf I hope this information was helpful Enjoy............. : )
May 14, 2009 | JVC Televison & Video
Picture not filling up the screen
The Vizio HDTV sets are all software driven. With the remote control select the menu option.
Then under the picture tab. look for the picture format full screen, wide screen. select the wide screen option. This setting should fill the screen.
Hope this helps
Bruce
Mar 27, 2009 | Vizio P42HD Television
Changing picture to wide screen full screen on Samsung HPS4253
I just had my digital cable installed yesterday. He had to jack with it for about 20 minutes until he got it to work. He accessed some sort of internal menu on the cable box by pushing power and menu at the same time. He had to select some sort of 4:3 overide option and that finnaly did it.
Aug 31, 2008 | Samsung HP-S4253 Television
Wide Screen vs Full Screen
look for screen format in video mode menu or if you have original remote you have that option in your remote
Jan 17, 2008 | Hitachi 43FDX01B TV
Samsung SGH-J600 Cellular Phone Logo
91 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
