Question about O2 Xda II mini
Screen insensitive and vibrate mode not working
The right side of my screen "3mm of it" is insensitive and hence causes problems for scrolling. and my device does not respond to the vibrate mode..
Hi, I had this problem, and fixed it. That's the good news. The bad news is that it involved taking the unit to pieces, and thoroughly cleaning the edges of the screen, and the inside of the case where it sits. Something had got trapped, which was throwing the tap out at the right hand side.
Posted on Oct 03, 2007
The whole right side of my screen is insensitive it will not allow me to input the letter p if it isn't in landscape view which is annoying Cuz I can't use my phone upright only to the side if I want to...
Did you drop your phone? If you didn't, the wiring could be damaged on the right side, and you could have to repair it. I don't know any other explanation to this problem.
Jul 30, 2014 | Cell Phones
Why is the area of the screen along the length of the tablet where the power and voume controls are insensitive??
The pressure sensitive screen reacts like this if it operating in too much heat, or if your fingers are cold and it cannot sense them.
Jun 14, 2014 | Dell Venue 8 Pro Tablet Computer
My toyota nze 2002 model has a problem with ref adjustment, sometimes when on D mode the ref counter drops below .9 hence the vehicle will vibrate but when on N its ok. what could be the problem?
revs will drop when put in drive ,does vibrating stop when you take foot of brake a slowly accelerate away? if so vibration could be coming from worn eng/transmission mountings
Apr 01, 2014 | 2002 Toyota Corolla
I could not switch on the mobile as my touch screen is not workin
Use the scroll wheel on the side of the phone to highlight "power on" then press the wheel in, just like a button..... this will select that option, and your phone should now turn on.... you can use the scroll wheel like this in normal operation, instead of the touch screen.... hope this helps..
Sep 22, 2009 | Sony Ericsson W960i Cellular Phone
Vibration of camera
This is a problem with the lens gyro we can keep it from shaking it requires the camera to be taken apart and amodification done to the lens repair cost 65.00 in most cases.
May 14, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Ringer or speaker problem
hold the phone in your hand while it is open. press the silver button on the right side of the phone. with the dircetion keys on your keypad scroll down to profiles. press button in the middle of the direction keys to select. Then you can select outdoors, normal etc. if it is in meeting mode you will vibrate. If you are in outdoors or some other profile you may need to go into the profile to do this use your options button and select edit then you will see your setting and can adjust the volume of the ring etc .
Mar 17, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Scroll down not working
Ya , even i have the same problem. when u r keeping ur laptop on several days and close the lid also, your keypad and mousepad gets heated up. the sensors below the touchpad is very sensitive. hence , it may automatically switch off sometimes to prevent getting overheated.here is one advice,if u r using the laptop for long hours,just take off the battery out from the laptop and run it on ac supply,because a battery can last for 1500-1600 cycles of charging. After that u have to buy a new one.So, make sure u are using ur battery only when u r doing some important projects only.that is why , most companies don't give warranty on ur laptop battery.
Jun 09, 2008 | Acer Aspire 3100-1405 Notebook
Screen corner insensitivity
Screen drift is a common problem on Palms and there are many forums about it. First, make sure it is not your screen protector. This is a common culprit. Also, make sure ther is no dirt between the screen edges and the case. Running a folded piece of paper in between can clean it. I worked on a friends Palm with this problem and the solution was third party software called PowerDigi. Here is the link:
http://www.palmpowerups.com/readarticle.php?article_id=5
Unfortunately, this software is not free.
Apr 05, 2008 | Palm TX Handheld
Changing the ringtone
actually jkhnetx i can help you address those problems
if you want it to ring and vibrate at the same time, do the following:
1. open phone, and push the side key under the memory card slot.
2. scroll over to the 'PROFILE' setting
3. highlight the 'NORMAL' setting, and push the 'OPTIONS' key.
4. go to 'EDIT'. push 'CALL ALERT' and you get a wealth of options. you can also edit the MESSAGE and PHONE SOUNDS options.
cheers!
Oct 11, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Ringing problem
try via using another profile in settings...option is there...else restore ur handset.....if that silent mode does not remove then do flash upgration....speaker is fine if u r able to hear the incmoing call.
Aug 05, 2007 | Nokia 6610i Cellular Phone
Computers & Internet Logo
327 people viewed this question
Top O2 Computers & Internet Experts
xxxxxx xxx
Hjalmer Lamminen
Hjalmer Lamminen
moha150583
Level 1 Expert
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
