Question about Kitchen Ranges
I cannot open my oven door it is a Frigaire Model # RE5O5N-D2. Looks like it is stuck on clean!
  • Anonymous Feb 25, 2009
    Same issue, door will not unlock after self-cleaning. tried resetting breaker and did not work. :(
  • 367 Answers
Turn the breaker off for about ten minutes and see then turn it back on. This should reset the clock and unlock the door. This works most of the time.
Posted on Jan 30, 2009
CFEF372BC2 - Oven Door Locked
I would replace it. IF you unplug it and set it to clean it is a hazard if someone opens it. If the safety feature is working it should not self clean with the motor unplugged anyway.
Aug 29, 2014 | Kitchen Ranges
Self clean - door will not open - no display
Without the model I don't know if unit has one or two open fused which has stopped power to the electronic control this the schematic should be in a plastic packet stuck behind control panel if not then on the back side of the storage drawer if equipped.
Jan 20, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
F9 error code while cleaning oven
F9 = oven door lock failure
Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If that looks good, replace the lock. What is the complete model number? Look in the oven door area.
Feb 14, 2013 | Whirlpool SF315 Dual Fuel (Electric and...
We used the self cleaning option and now we cannot get the oven door open. The lever is stuck in lock mode. Can you give suggestion?
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock.
IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature)
Thank you and thanks for using fixya
Sep 29, 2010 | Jenn-Air JGW8130A Electric Single Oven
Opened oven door before it could lock while I was
try unplugging the unit,
depending on your exact model it may just be lost in the programming becuse it sensed the door open while locking so it shuts down the lock for safety
just unplugging if for a few minutes might clear the error enough for the lock to rotate back to closed
position
Nov 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
E1 F5 Error on Whirlpool Accubake Oven
The lock latch is located directly in the center upper portion of the door. It is a hook shaped latch that lock by turning downward. This lock gets stuck in this position which causes the e1 f5 error code. Locate the latch through the vent holes in the upper front of the oven door. Insert flat headed srew driver into vent hole and gently push latch up to a horizontal position & simply open door. Once unlocked, push cancel on the control panel.This will clear the error code and resolve the issue.
Apr 07, 2009 | Ovens
Oven Lock stuck open before start of self-cleaning cycle
Sounds like you bent the door where the lock is. You might have to replace the door.
Mar 12, 2009 | General Electric Stove/Oven/Range Chrome...
Kenmore oven door stuck closed
if you open the lid on your stove,you will probably be able to reset the switch manually (the latch).with the lid up its located toward the front behind the safety latch.(by no means attempt to force,bypass,or disable this switch)this is a safety feature designed to protect you from the high temps generated by the cleaning cycle.hope this helps.thanx for using fix-ya
Oct 08, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Jenn air oven stuck closed after attempt to activate self-cleaning
The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
Jun 09, 2008 | Jenn-Air JJW8130D Electric Single Oven
Tappan electric range door locked
Check the door lock switch/solenoids. You'll have to unplug the range/stove. Remove the solenoid and check to see if it has continuity or if the solenoids are stuck.
You also might have luck resetting the clean cycle. Even though the lock is engaged, try to open the oven door a little. Start the clean cycle, then cancel it.
Dec 13, 2007 | Kitchen Ranges
Kitchen Ranges Logo
57 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
