Question about Acer Aspire One Netbook 8.9" Notebook
I have an acer mini that has an att simcard, when I launch the connection manager, i get a message saying that there is "no available bearer". What does this mean and how do I fix it?
Hi my acer aspire 5315 e button at the top dose not work so do you now who to fix this
Hello reeceman1,
The Acer Launch Manager needs to be running for the 'e' key to work. To run the Acer Launch manager, do these 3 steps:
* Click the windows start button (bottom left-hand corner) * Click All Programs * Click 'Launch Manager'
When the Launch manager window displays on the screen, click OK. Now Press the 'e' button and it will launch the Acer Empowering Technology
If this solution is helpful please click a thumbs-up rating.
Have a great day, martyshaw152
Apr 09, 2011 | Acer Aspire 5315 Notebook
I always get the message "cannot connect to this webcam, close any program that may be using gthe webcam " with msn messenger on Laptop Acer aspire 5742z
*Uninstall your web cam driver and reinstall it..!
*(to uninstall doto device manager)
[ Windows 2000/2003/XP/Vista
  • You can open Device Manager by double-clicking on the System icon in Control Panel, choosing the Hardware tab, and clicking Device Manager.
  • Fortunately, Device Manager can be more easily "Run" by launching devmgmt.msc - just create a shortcut to the file (as described above), and launch it at any time.
  • Run >>devmgmt.msc ]
Jan 15, 2011 | Acer Aspire 5920-6727 Notebook
Att mms setting for lg ku990
This is the configuration of your LG KU990 (Viewty).
Title:
Att
Bearer: GPRS
Auth: PAP
User: WAP@CINGULARGPRS.COM (all caps)
Password: CINGULAR1 (ALL UPPERCASE)
APN: wap.cingular
Browser>Settings>Profiles: (Internet Setting)
Service Name: Media Net
Homepage: http://www.google.com
Connection mode: TCP without proxy
IP: (blank)
proxy: (blank)
Security: (blank)
Access Point: ATT
Messaging>Settings>MMS>MMS center: (MMS setting)
Title: ATT MMS
MMSC URL: http://mmsc.cingular.com/
Connection Mode: TCP with Proxy
Access point: ATT
To get google and all your other java web access make sure that this is the only profile you have in the Access Point. This will default as your java web setting & streaming setting. So you can now stream youtube & use Opera Mini 4.
Best regard:
Henk®Muskita ©2009.
Aug 07, 2009 | LG KU990 Viewty
Mms setting for att
Internet settings for AT&T
Title:
Att
Bearer: GPRS
Auth: PAP
APN: wap.cingular
IP: (blank)
proxy: (blank)
Security: (blank)
Access Point: ATT
Title: ATT MMS
Access point: ATT
Best regard:
Henk®Muskita ©2009.
3g connecton - AT&T service - I keep getting
first, check the 3G led is on, if is on, then open the 3g connection mamager and wait about 1 minute, if doent appear signal, download the lastest drivers of 3G Modem and the updated 3g connection manager here: http://support.acer-euro.com/drivers/notebook/as_one_150.html
Jul 07, 2009 | Acer Aspire One PC Notebook
Nokia 6085 on att won't send or receive mms/multimedia messages
For the normal at&t apn settings, or also called at&t wap settings, these are the values you should use
APN: wap.cingular
Proxy: <Leave in Blank>
Port: <Leave in Blank>
Username: wap@cingulargprs.com
Password: cingular1
Server: <Leave in Blank>
MMSC: http://mmsc.cingular.com
MMS proxy: wireless.cingular.com
MMS port: 80
MCC: 310
MNC: 410
Authentication type: <Leave in Blank>
APN type: default,supl,mms
APN Protocol: Leave it to the Default one
at&t apn settings 4Gdetails: If you have a 4G phone (e.g. iPhone 5, Galaxy S4, HTC one, etc) you should try using these at&t apn settings 4G. They run faster and more stable connections.
APN: phone
Username: <Leave in Blank>
Password: <Leave in Blank>
MMSC: http://mmsc.mobile.att.net
MMS proxy: proxy.mobile.att.net
MMS port: 80
MCC: 310
MNC: 410
APN type: default,supl,mms,hipri
Bearer: leave it to the Default one at apn settings Step by Step Configuration
May 12, 2017 | Samsung BlackJack II Smartphone
In acer 5920, acer arcade installed, can not be started by hotkey
You configure the keys from the Acer Launch Manager. If you go to Start, All Programs,  Acer System you will find the manual telling you exactly how to configure it.
Dec 10, 2008 | Acer Aspire 5920-6727 Notebook
Acer launch not working for acer 5614wlmi
enter in C and program files and find launch menager.exe under launc menager folder. double click the exe files and you will see  it will disspear.
sorry for my english
Nov 15, 2008 | Acer Aspire 5610-4648 Notebook
Need help with my lg shine ke970
Set the homepage to: http://device.home
Set the Bearer: GPRS
GPRS settings:
APN: wap.cingular
User ID: WAP@CINGULARGPRS.COM
Password: CINGULAR1
1. Scroll to and select Proxy Settings and press OK.
* IP Address: 66.209.11.32
* Port Number: 80
2. Press the End call key to return to the standby screen
I found this on the web, its a little different then how I did mine, so here it is in case mine doesn't work for you:
here you go...it works !!!
Phone Setting>Connectivity>Access Point: (Data Setting)
Title: Att
Bearer: GPRS
Auth: PAP
APN: wap.cingular
IP: (blank)
proxy: (blank)
Security: (blank)
Access Point: ATT
Title: ATT MMS
Access point: ATT
Oct 16, 2008 | LG Shine KE970 Cellular Phone
ACER RECOVERY HELP!!!
It comes as part of the package when you bought it.
It's already on the hard drive. Acer recommend you make a recovery disk before you start using the machine.
This is from Acer's Website.
How can I launch Acer eRecovery Management to back up or restore my system?
0.31de?openelement&fieldelemformat=gif
Problem:
Solution:
You can press <Alt+F10> or the Empowering Key to launch in a Windows environment, or press <Alt+F10> during boot up. For the Veriton desktop series, you can also press the hardware reset button at any time. For the Aspire or AcerPower desktop series, an Acer eRecovery Management icon can be found on the desktop screen.
Hope it helps.
Mar 08, 2008 | Computers & Internet
Acer Aspire One Netbook 8.9" Notebook Logo
255 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
