Question about Whirlpool Duet GHW9150P Front Load Washer
Spring band on a Whirlpool Duet Front Load Washer
Holding the drum has become dislodged. How do I fix this?
Go you mean holding the door gasket? if so you should be able to get a pair of pliers and stretch it back on
Posted on Jan 31, 2009
Can't get the spring back on
get some banding they use to band newspapers this will help you to put your spring back on your machine .......
Dec 23, 2013 | Whirlpool Duet GHW9150P Front Load Washer
I have a front loading whirlpool duet washer and the door seal is damaged and water is leaking out at bottom of door. Is this easy to fix/
this is not a hard thing to fix just a little time consuming.there is a spring under the edge of the boot that needs to be removed,
Then you will need to remove the front panel,so that you can remove the other spring that holds it to the drum.
Dec 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Loading Duet Washing Machine Plastic at drum front shredding
i think your talking about the rubber door seal????
you can change this yourself,,,under the seal on the case is a wire spring unhook it and the door seal will fold inside the washer,,,on the inner drum you will find the other wire spring undo this as well and pull the old door seal out through the hole in the door,,,the new seal is fitted to the iner drun first so you need to turn the new seal inside out to fit it,,,push the seal into the washer and fit the inner wire first then unfold the seal and fit it over the outer door so you can fit the wire spring,,,
easy after you have fitted a fuw 100?
Aug 21, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Gasket leaks water down front of machine when in use. Can it be replaced by owner?
It can be relpaced by the owner but it is alot of work. The washer drum needs to be taken out of the machine because of the spring that holds the seal to the drum assembly. Then the washer is reassembled and the seal needs to be reglued to the door area of the machine. Hope this helps.
Mar 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer, inner stainless drum rubs
This sounds like a worn bearing housing or the bearing itself has packed up,either way you would have to strip and check these and replace what is broken
Dec 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Plastic piece stuck between drums
First remove power from the washer. The top panel #2 in the diagram can be removed by removing the two screws in back. The kick panel #16 also has two screws that hold it in place. From there you should be able to find what you lost. Best of luck!
Feb 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loader. did a load of laundry and when i went to get it out the rubber seal is all twisted and the wire spring is off
Is it ripped?If not great all you need is to put the boot back on then reattach the band tighten with i believe eitther a 7 milimeter or 1/4 socket then put the hose slot back on and then the front of the boot following the otther band
Jan 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Seal on fron loader
there is a wire clamp and spring that holds the gasket on, loosen the spring and reset the gasket then refit the gasket and spring.
Dec 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frotnt door seal ghw9150
why ? is it torn and leaking or just mildew? if not torn cleaning best bet with chlorine bleach and water.if you still want to change it remove spring front front edge pull seal back toward drum on back section big clamping band remove band pull seal off and reinstall reverse order can be a dog if not experienced good luck
Apr 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
74 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
