Question about Canon i 550 InkJet Printer
Wow to change the cartrighes?
How do you put the cartrighes rightly in and in what coulor line? i put them fastly out and now i can not put the rightly in please help me. Thanks can you sent a picture how it must look like?
The case in which they belong was hidden in the right side. after restart it was easy
Posted on Feb 02, 2009
My 206CC is spluttering and holding back I have changed spark plugs and coil pack what should I try next?
Hi,some times the simplest things are over looked,you might have already done this,have you changed the air filter as if it is dirty it will run badly,and after running the car after 15mins take 1 of the sparkplugs out and have a look at the coluor as this can also give some indication fuel mixture,it should be a biskety coulor if its running right.all the best.
Jun 18, 2015 | Cars & Trucks
When putting car in reverse car dies
no year, wow.!
sounds like gross loss of engine power
or
you started car and didnt notice RPM was 400 rpm.
the engine has almost no power at that rpm.
the normal cold start (winter) is about 1500 RPM.
if not at fast idle fix bad fast idle (Bad IAC)
when i say bad IAC that means the system IAC is bad,not just a part.
the IAC /ISC controls idle at all times, via ECU commands.
Nov 13, 2013 | Jeep Wrangler Cars & Trucks
Can I Trust Ads In Game And Buy Wow Gold When I Play Wow?
So Surprice to see your questions in here,
but I want to say that I am a wow fans for many years,
I often accounter the wow gold seller in game,
To me, I often get wow gold from wowwowgold.com.
with fast delivery,safe trade and chep price, it can meet all of my needs very well.
You can also have a trial...
Jul 12, 2011 | Blizzard Entertainment World of Warcraft...
Front brakes are locking & seizing up. Put New brake pads, new rotors, new calipers, new hoses, new wheel right master cylinder.
Hello, wow sounds like you have done it all. But there is a spliter block that is right below the master cylinder that the two lines from the master cylinder goes into and then four other lines come out of it going to each wheel. Not often but sometimes these will cause that problem. Good luck
Jan 18, 2011 | 1998 Plymouth Voyager
My car over heat and I put some water coolant but there was steam coming from out. The water coolant just keep mon emptying the container.
You have either blown the head gasket or have a burst hose. Check the oil dip stick to see the coulor of the oil< if it is a Grey creamy coulor you are going to have to get the gasket attended to.
If not, give us a little more info to work with.
Jul 06, 2010 | 2004 Pontiac Grand Am
The bulbs have gone on the heater settings in my toyota corolla 2000 1.3i se an i would like to change all bulb colors in the interior,is this possible? thank you
yes you can change these by removing the facier trim very gently and removing the push in type bulbs availible from you local toyota service department. as for the different coulors you are limited by whatever coulor cover for the globes you can find i know there are green , blue, yellow and red
Dec 09, 2009 | 2005 Toyota Corolla
Sumsung reprojection stop working as we were watching it to coulor change and a small line came up on the srceen then it just turned it self off.It is 4 years old and has 3 colour round tubes behind the...
what kind of line came up did it come up in the middle of the screen or was it a solid colored screen with arched lines through it....need more info on what its doing
May 10, 2008 | Televison & Video
The video & sound problem!!
have you tryed using a coulor converter into scart if so try another scart in it or maybe your coulor ports are broke hope this helps
Jan 22, 2008 | Microsoft Xbox 360 Console
Printing is very slow
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
WOW
LPT_Timeout
WARNING: Using REGEDT32 can cause serious damage to your operating system. Make sure to follow these steps exactly.
  1. On the Windows 2000 or Windows XP machine where the printer is connected, click Start -> Run and type REGEDT32
  2. Bring up HKEY_LOCAL_MACHINE on Local Machine
  3. In the header, click View and make sure to check "Tree and data"
  4. In the left hand pane, expand System -> CurrentControlSet -> Control -> WOW
  5. In the right pane should be a key "LPT_timeout". Double click this key
  6. A prompt for a string with a default of "15" (seconds) will appear. Change this to 3 and click OK.
Then restart Pc
Nov 06, 2007 | HP Photosmart 3310 Printer
Canon i 550 InkJet Printer Logo
old marine
old marine
