Question about Emerson MW8107WA Microwave Oven
It just died
The microwave is a little over five years old. It just simply died. I once fixed my moms by resetting it but I honestly have no idea where to begin with this one. I have pulled up the owners manual and unless you want to know how to plug it in or cook something in it, the manual is usless. Please give me some kind of help. My grandmother has an eleven year old microwave... I know this isn't all I'm getting out of this one... Or is it?
  • 3 Answers
Check the AC line fuse. This will require you to remove cover.
Posted on Aug 02, 2007
SOURCE:
Everything runs on my microwave but it will not get hot. what can i do to fix this problem?
The magnetron will more than likely need replacement, one of the most expensive parts in the microwave oven. If the item is more than five years old consider a new microwave oven
Mar 05, 2012 | GE JE2160 Microwave Oven
MY 5 YEAR OLD BOSCH INNOWAVE BUILT IN MICROWAVE HMT 8656 HAS JUST DIED. WHAT IS THE LATEST MICROWAVE TO REPLACE IT
Here`s a little fact about microwave`s, they are not healthy - http://rense.com/general70/microwaved.htm
We threw ours out, food taste much better cooked on the stove, oven or grill.
Apr 15, 2011 | Bosch HMT8625GB Microwave Oven
The switch button is not working..
Hi, kindly unplug the unit for five minutes. this will drain all power, and reset the main board. Once the five minutes have passed, simply plug the unit back into the power outlet. If the problem continues, the touch pad should be replaced asap.
Mar 27, 2011 | Amana RFS18MPS Microwave Oven
The microwave stops after a few seconds. It starts, but stops before the set time is completed. The oven is five years old.
Does the oven's key pad seem to reset like a breaker flipped inside? And after, you have to reset the clock? If so, check the temperature cutoff switches inside. Jumper across them and see if your microwave starts working correctly. I had this problem and the Bottom TCO was defective.
Feb 18, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Our GE countertop microwave key pad does not work. The start and clear button does not work. owners mamual jes1651 . unit is 2 years old.
HI. Kindly, unplug the unit for five minutes. this will drain all power, and reset the main board. Once the five minutes have passed, simply plug the unit back into the power outlet. If the error continues, the touch pad should be replaced asap.
Oct 19, 2009 | GE Microwave Ovens
Turns on but not heating food sounds a bit louder
Hi, this is common in most microwaves. this abnormal noise is coming from a faulty Magnetron. this device is responsible for the heating process and, it is damaged and not heating at all at this point.Simply replace the Magnetron and, this unit will start to heat once more.
May 31, 2009 | GE Profile Spacemaker Over-the-Range...
Was using it last night to heat something up. When almost done, microwave made a zizt type of sound and went off. I turned it back on and it continued cooking, but I started smelling burned plastic or
More common then you think, i have gone through a couple microwaves in the last ten years, they both failed very similar to what you describe. One popped the breaker one day, reset the breaker and it worked again but had an odd smell to it. I took it apart and couldn't find anything burnt or melted so i tossed it and got a new one, i didn't want a microwave burning the house down! I would suggest unless your really tied to that microwave that you just replace it for safety sake. Four years or forty years old don't matter anymore, i had one microwave, LG brand, that died two months after the warranty expired and it would cost more to repair it then replace the thing!
Jan 11, 2018 | Panasonic NN-H964 1200 Watts Microwave...
GE microwv-doesn't heat, strong electrical smell, all else ok
The most common problem would be your magnetron. Check your purchase date, magnetron's usually have a five year warranty. Not a part I recomend trying to fix yourself (high voltage ).
Mar 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
Emerson MW8107WA Microwave Oven Logo
102 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
