Question about Nintendo Wii Console
It freezes in the middle of the game I have the same problem. Just freezes up when playing a game. Mostly on the NCAA football. One solution was may have a laser problem. How do you fix that?
  • Priya darshan May 11, 2010
    HI,
    If a game freezes while
    playing, usually the power, reset, and eject buttons will not respond.
    Try unplugging the AC Adapter from the back of the console, then check
    the air vents to make sure they're not being blocked – as that could be
    causing overheating. Improper ventilation may lead to locking or other
    severe problems with your Wii. When you unplug the system, please leave
    it unplugged for 60 seconds to insure a proper reset of the Wii.
    Sergeant:
  • 250 Answers
There can be many reasons for your Wii console to freeze. Read this article and if you have a problem similar to one of those mentioned in this article, then solution is at hand! It just pauses. And after some time you realize that it’s not a pause but a STOP!! And it freezes!! You are in the middle of an interesting game on your Wii and it suddenly freezes.
This generally happens because there is a flash RAM in some models and the update is not applied properly.
  • The immediate thing we can do in this kind of problem is that just shut down the system, wait for 20 seconds and reboot it. This should resolve the issue if your system has an interim issue.
  • If you still continue to have the problem we need to reformat it. As per the research regarding wii freezing, majority of the issues get resolved when we reformat it.
Well if you still have the problem again call up the customer support and get your system replaced.
Posted on Jan 30, 2009
    Sergeant:
  • 378 Answers
To fix that you will have to open the unit apart and clean the lens with a tissue paper.and then check out.
    Genius:
  • 1,913 Answers
It is resolution problem set 1024*768 may be your vga card meory low problem .u have to increase your ram to get btter disaply so then u not get frezzeez up.it is beast way to improove disply and decrease meomry load.
  • 6,784 Answers
Most wii games are flawless but, some are shipped with factory flaws not discovered before delivery. Try cleaning the medium then, if the problem persist, its defiantly a manufacturing flaw and it should be sent back for factory repair or exchangment.
  • 679 Answers
There might be an insufficient hardware configuration problem.
check your console with another CD.
and let me know.
  • rockfixya
    rockfixya Feb 01, 2009
    please post back for more assistance.
    Thanks
    Genius:
  • 3,422 Answers
If a game freezes while playing, usually the power, reset, and eject buttons will not respond. Try unplugging the AC Adapter from the back of the console, then check the air vents to make sure they're not being blocked – as that could be causing overheating. Improper ventilation may lead to locking or other severe problems with your Wii. When you unplug the system, please leave it unplugged for 60 seconds to insure a proper reset of the Wii.
  • Priya darshan Jan 30, 2009
    Below are the troubleshooting steps recommended from Nintendo(where you find blue colored links"click here" just click on it to view more info):
    Problems with one specific game
    • Check our list of known Game issues, to see if the game you are playing has any known issues.
    • Check
      the bottom of the Game Disc (the side without any labels or writing)
      for any dirt or damage (such as cracks, scratches, etc.).
      • If the game looks significantly damaged, such as with scratches or cracks,
        it will need to be replaced. Please click here for our Game
        Disc replacement options.
      • If the game looks dirty (fingerprints, smudges), try cleaning the Game
        Disc by clicking
        here
        . If the problem persists, the Game Disc will need to be replaced.
        Please click here for our Game Disc replacement
        options.
      If the above information does not solve your problem, then the Game Disc will need to be replaced. Please click
      here
      options.
      Only have
      one Game Disc
      Game issues
      any known issues.
    • Check the bottom of the Game Disc (the side without any
      labels or writing) for any dirt or damage (such as cracks,
      scratches, etc.).
        scratches or cracks, it will need to be replaced. Please click
        here
        for our Game Disc replacement options.
        cleaning the Game Disc by clicking
        here
        here
    • Can you try the Game Disc in another Wii console? If so, this can
      help narrow down the problem.
      • Yes, tried the Game Disc in another Wii console but the Game Disc still will not play:
        The problem appears to be with the Game Disc. Please click
        here
      • Yes, tried the Game Disc in another Wii console and the Game Disc worked properly:
        The problem appears to be with the Wii console itself,
        and a repair is necessary. Please click
        here
        for repair options.
      • No, you are not able to try the Game Disc in another Wii console:
        At this time it is difficult to determine if the problem is
        with the Wii console or the Game Disc, and we recommend
        a repair for your Wii console and game. Please click
        here
        for repair options.
    • Problems with
      some games (not all)
    • Are you able to play one type of Game Disc but not another (for example,
      you can play Wii Game Discs but not Nintendo GameCube Game Discs)?
      If so, then it is likely there is a problem with the Wii console
      and it will need to be repaired. Please click
      here
      for repair options.
      scratches, etc.).
      • If the games look significantly damaged, such as with
        here
        cleaning the Game Discs by clicking
        here
        . If the problem persists, the Game Discs will
        here
      it appears there is a problem with the Wii console and it
      here
      for repair options.
      Problems with all
      discs
    This indicates the problem is likely with the Wii console
    and it will need to be repaired. Please click here for available
    repair options.
Nintendo Wii Console Logo
13 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
