Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Coloring is off and there is a ghosting effect
There are blue tinted vertical lines running across the screen. They increase in width from left to right, start at about 1" wide on left and get up to 4" wide as they approach midscreen, then disappear. Also there is an offset ghosting to the images on the screen. In general the color is off due to all of these issues.
I thought maybe a bulb replacement would suffice but am not sure if there is a deeper issue that will still affect performance after a new bulb is put in.
    Scholar:
  • 87 Answers
You have a convergence problem.You can replace this module cheaper than it can be repaired.It is so easy to do and electronics skill level is not required.If you can unplug the TV and remove the rear cover,then you can do this repair yourself.1 screw and 5 connections(plug in) is all it takes.The part number you need to order is BP95-00142E convergence amp. I would google search it and find it at the lowest cost to you.Good luck and please rate my information.
Posted on Jan 30, 2009
  • Albert Vasquez
    Albert Vasquez Jan 30, 2009
    This is the info for this part#
    Part number AA95-02002A has been substituted with the following:
    Manufacturer
    Samsung
    Part Number
    BP95-00142E
    Description
    ASSY SUB PCB-CG AMP
Blue Lines streaking in from left side of 70 inch Sony HD TV
okay my friend your tv vertical circuit is begining to get faulty you could be having some bad caps or the vertical ic is defected have a tech check your tv for repairs.if you are not a tech you cannot repair the set by your self.good luck.
Jun 25, 2007 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
KP-57WV600 Sony Wide Screen tv blue arcs across entire screen
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
I hope this will help in solving the problem...
Sep 09, 2011 | Televison & Video
I have a sanyo DS35580 and there is a blue line across the middle of the screen
You haven't stated whether there is screen or picture. If you see only a blue line across the screen with high brightness, vertical output Ic of your TV has burned out. Don't switch on the set further or increase its brightness, till the fault is retified. Otherwise there will a phosphur burn occur where the blue line is now, and it is internal, whcih cannot be retified anymore.
Oct 16, 2010 | Sanyo DS31520 31" TV
Blue tint across screen and black shadow of sort
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 02, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
RCA r56wh78 scrolling vertical bands
it is going to need to be tested to find the component that is causing the problem
Oct 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Blue tint and lines on screen.
Those lines sound like "retrace lines" and several things can cause them. The most common are shorts inside the picture tube and shorted semiconductors in the video driver circuits. They can also be seen if the blue screen voltage is too high or if someone has tampered with the screen voltage control.
Jan 20, 2007 | Philips 28PW9536 28" TV
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
122 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
