SOURCE: WHAT IS THE SOLUTION ON ERROR MESSAGE PE IN MY FUZZY LOGIC WFT601
There is a round clean out door accessed from the front of your unit. Some models you have to take the lower panel off entirely to clean it out. It unscrews and probably there is anything and everything you can imagine clogging the pump inlet....thus the error message "PUMP ERROR" THe unit's error code may manually have to be deactivated in the control panel to reset the unit to normal operation.
SOURCE: What is the problem if
Pressure Switch faulty.
Replace with P/N: 6501EN1001A
Reply if you need directions for removal & installation.
Good Luck!
* If you found this solution helpfull, please rate with 4 thumbs up & a testimonial.
