Xerox DC 5o - system error 9-357
I have printed a great volume b/w only, and got the message system error 9-357. Removed housing, vacuumed it all and cleaned as much as possible without tearing the printer apart. Started fine, but very weak on the black, and after 50-100 prints suddenly stopped and a new error 9-357 occured. At least 50 of the prints were full color. Obviously I havent cleaned it all up, but how do I get to the parts needing more cleaning?
leiferik
    Sergeant:
  • 250 Answers
Fault code 9-357, which is something
about a black toner cartridge empty or getting blocked (or delivery system) broken. the carousel which spins the cartridges inside the printer is getting blocked.its very big black colour gear type plastic carousel.
Posted on Jan 30, 2009
  • 679 Answers
9-357.Black toner problem.Probably You have low toner sensor defect.
But try first to vacuum and clean black toner dispenser.You must vacuum whole path wich is used to transport black toner to developer unit.Then if printing B/W print only, you must print 10 full color sheets every 100 copies.
Thanks
    Sergeant:
  • 378 Answers
Any of the cartridge would be empty just remove and check out the cartridge.
    Genius:
  • 1,913 Answers
Oen the all parts then clean al dust use isopropile to clean all bluurr and dust.refix all thigs.
Xerox 560 error code 127-212
Error Codes
If an error caused the printing to end abnormally or a malfunction occurred in the printer, then an error message code (***-***) is displayed.
If an error code not described in the following tables is displayed, or the problem persists even after you have tried the following solutions, contact the Customer Support Center.
Tip
If an error code is displayed, all print data of the printer as well as print data stored in the built-in memory of the machine is discarded.
Error Code: 127-212
Error Category: Print; Other Problems
Cause: Detected an internal print check error by the FreeFlow
Print Services Controller.
Remedy: Remove and reinsert the command/video cable between the FreeFlow Print Services Controller and the printer. Power off and on both the printer and the FreeFlow Print Services Controller. If the problem persists, call the Customer Support Center.
*** extracted from my Fuji Xerox Color 560 Printer - Printing Systems User Guide
*** I assume we have the same printer
Jul 13, 2012 | Lenovo ThickCentre M58p Desktop 7479A3U
024 958 ERROR CODE OF XEROX dc 250 Problem
I have a xerox 3040 printer, but when I printing he report the problem (error)-024-958. I I know that the problem is in the size paper, but how is it possible to be right paper for printing.
Please Help???
Jul 31, 2011 | Office Equipment & Supplies
I have a xerox f116 faxcenter machine that I bought from an online auction. When I set it up and put a document in to fax, it came up with a message that said 'REMOVE DOCUMENT STOP TO CONFIRM'. The...
Go to the link below and see page 116 for your solution. The link below takes you to the users manual for your model unit:
ttp://download.support.xerox.com/pub/docs/FaxCentre_F116/userdocs/any-os/en/userguide.pdf
May 25, 2011 | Xerox FaxCentre F116 Plain Paper Laser Fax
Xerox dc 12 error code 9-357
9-357 Black Toner Dispenser Broken.
Dec 19, 2009 | Xerox DocuColor 12 Color Copier
Xerox Phaser 8560DP shows annoying 'print completion' message
Someone installed the "Printing Scout" on this computer. You may need to uninstall or check all the settings in the printer driver. I'm not really familiar with Macs but I know the 8560 inside out, upside down, and backwards.
Jun 08, 2009 | Xerox Phaser 8560DN Laser Printer
Xerox phaser 8500 error 13,327.42:31555
If you have Warranty Still, CALL XEROX!!!, That error message indicates that you have a failed temprature sensor inside the print-head, 90% chance Xerox will have to replace print-head. Print head is VERY expensive to replace out of pocket ($500-800+)
Jan 23, 2009 | Xerox Phaser 8500/DN Printer
Xerox dc 12 copier system faulit 9-354
Hi ,
Sir I am have dc12 mech
its giving error code 9-354.
send me the solution as soon as posible.
Aug 09, 2008 | Xerox DocuColor 12 Color Copier
System fault 9-363 i tried everything i know, please help
You can try this, try to clean the dev rotary sensor. open the upper right hand cover then there are two assy's to be removed also for you to access the rotary sensor located inboard side. this sensor senses the home position of rotary developer. to removed this sensor, you have to open the rear cover, then rotary pwb. some 9-363 code is due to busted fuse in the rotary pwb. Or could also be a fault with the fuses.
May 13, 2008 | Xerox DocuColor 12 Printer
Xerox copier
J messages on Xerox machines always refer to toner or drum.Is the toner out , you could give it a shake (might be a good idea to go outside!) Sometimes it will run out without displaying a message(Pyramid of dots for out of toner) Drum end of life usually comes up with a crossed circle or similar .If all OK you could have a blocked toner supply auger or lumps caused by storing toner in sunlight, both would require the toner system being vacuumed out.
Nov 26, 2007 | Kyocera RI-3530 Black and White Copier
37 people viewed this question
jasbo
jasbo
