Question about AOpen F55PS (Black, Silver) 15 in. Flat Panel LCD Monitor
Screen not appearing straight away
When I turn the computer on in the morning, the screen doesn't power-up straight away. It started taking 3-5 minutes before anything appeared on the screen and over about a months time, it is taking up to a couple of hours. The LED on the power switch turns green when the rest of the computer is turned on, yet, there isn't even so much as a flicker from the screen. Once the screen comes up, you can turn it off, then back on again and it powers up straight away. Have swapped monitors and even used this one on a different computer, with the same result.
  • 624 Answers
It could be your LCD backlight giving you problems till it warms up. Turn you computer on and while the monitor is displaying black and the power LED is green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. A 15" LCD monitor is probably not an economically repairable problem unless you have access to really cheap parts and have the skills and tools to do the repair yourself.
Posted on Jul 29, 2007
SOURCE:
Screen on samsung computer
try with a other monitor,it can be brooken,or the videocard is brooken.
May 18, 2013 | Computers & Internet
Neo Notebook model no. LC89-black screen only.
  1. All Operating Systems
    • 1 Remove any discs in the computer.
    • 2 Hold the power button down until the computer turns off.
    • 3 Press the power button to turn the computer on. If this doesn't work, proceed to step four.
    • 4 Remove the battery and unplug the netbook. Wait 30 seconds.
    • 5 Reinstall the battery and plug in the netbook.
    • 6 Press the power button for ten seconds. If this doesn't work, proceed to step 7.
    • 7 Insert the end of a paperclip into the reset button to reset the netbook. The reset button is a small hole that usually appears next to the USB and other ports.
    Windows 7
    • 1 Create a new Notepad file.
    • 2 Type this code:
      taskkill /F /IM dwm.exe
    • 3 Save the file as displayfix.bat in the following location: C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Startup
    • 4 Restart your computer.
Sep 20, 2011 | Computers & Internet
One of my computers lost power this morning due to blown fuse. When I turned everything back on the monitor screen has power and no screen.. it is all black
If the power light is on, but the screen never appears to light up, either the backlight or the power inverter have failed.
May 05, 2011 | Dell UltraSharp 1905FP 19" LCD Monitor
Horizontal lines across whole screen
Bad inverter, or a dirty one. Remove the power cable and battery, then take apart the screen bezel, or casing. Remove the LCD by unhooking it. Disconnect the inverter. Clean it. Reconnect it. Fixed.
Feb 01, 2010 | ASUS Eee 1000H Notebook
I cannot acces my computer stays at intel screen
Open the computer, and you will see near the bottom right corner a blue jumper on 2 of 3 pins. The pins are J9J4 and the jumper should be on pins 1 and 2.
Turn off the computer and the power supply, remove the little round battery from the motherboard, move the blue jumper to pins 2 and 3 and wait 40 seconds. Reinstall the battery, and then move the blue jumper back to pins 1 and 2.
Turn on the power supply, restart the computer and the BIOS settup utility should appear
Apr 16, 2009 | Intel D865GLC Motherboard
Screen won't appear upon start up and I get 3 beeps but no screen
3 beeps POST code (power on self test) means RAM problem.
Reseat the RAM module/s and boot up your computer.
If you have two RAM modules, remove them both and insert one at a time to test them, to determine which module is faulty.
If it still doesn't work then replace the RAM module/s
Apr 02, 2009 | Everex StepNote NC1500 Notebook
I JUST purchased a laptop (toshiba sattelite L300D) I put the battery in, I pluged the AC...and I start it up for its first time....but nothing appears on the screen.....not even a bios or whatever...the...
I would not even touch it, if you JUST purchased it take it right back.......if your having problems with it straight out of the box its prob. not a good sign........
If you dont want to take it back , take out the battery and put it back in...plug it in and start it up again....take notice if there are any power lights on the laptop that turn on , or if there is no response from the laptop at all.....
If there are no lights it may be a problem with the ac adaptor or the power supply inside the computer.....
If there are lights and nothing on the screen then the LCD is faulty.
Oct 04, 2008 | Toshiba Computers & Internet
Leapster doesn,t respond when the pen touch screen
for leaster 2 -
turn off unit, take out cartridge.
hold the hint button, turn unit on.
press A button, touch the stylus on all the cross hairs that appear.
power unit off when done.
power back up.
(got these from the leapfrog site and it worked for me!)
Sep 29, 2008 | LeapFrog Leapster Electronic Book:...
Is my lamp out on my LG?
Most likely you can have 1 or 2 problems.
1! the light is busted and you will have to replace that. You might also need to check your cooler fan bearing as you indicate it makes noise.
Please open following link( you need acrobat reader)
this is the service manual for your TV
ru-44sz61d
Apr 30, 2008 | LG RU-44SZ61D 44" TV
Philps LCD Monitor Won't turn on Straight away
That is definitely a problem with the monitor...if its under warranty have it replaced...if not...start looking for a replacement it hardly ever is worth it to have them repaired (shipping, parts, labor is usually a little less than a new monitor). Sorry
Aug 28, 2007 | Gateway FPD2275W LCD Monitor
AOpen F55PS (Black, Silver) 15 in. Flat Panel LCD Monitor Logo
196 people viewed this question
Top AOpen Computers & Internet Experts
Alun Cox
Joaquim Martins
Thomas F. Schneider
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
