Question about Dell Dimension 4550 P4 Socket 478B Motherboard (2U819)
Primary hard drive not found
Dell Dimension 4550
I swapped a hard drive that I knew was working and got the same message. Did all combinations of Dell hard drive and working hard drive as single/double/master/slave. Same messages.
Replaced IDE cable. Same message.
Ran diagnostics disk. Could not recognize hard drive. Tried to run chkdsk but would not.
  • Geo Topia Mar 30, 2009
    Pretty much the same problem. Seems that once the OEM drive fails and I reinstall Windows (Windows SUCKS!) on a new drive I have nothing but problems.
  • Dell Master
  • 1,183 Answers
since you already tried removing and reseating the hdds . The problem could be the motherbaord slot. To troubleshoot the same
1. First Disconnect all hardrives and optical drives from the system
2. Go to the system setup or BIOS
  1. Turn on (or restart) your computer.
  2. When the blue DELL™ logo appears, press <F2> immediately.
If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft® Windows® desktop. Then shut down your computer and try again.
3. Hold down the ALT key and press "F"
4. Hit ESC , save changes and exit .
5. SHutdown the system
6. Reconnect the HDD IDE cable to the optical drive connector on the motherboard.
You can refer to the following motherboard diagram
http://support.dell.com/support/edocs/systems/dim4550/techov.htm#1101668
7. Check if the hdd , is getting detected in the system setup
You can refer to the following link on how to read system setup screen
http://support.dell.com/support/edocs/systems/dim4550/syssetup.htm
Thanks
Proton
Posted on Jan 30, 2009
Dell dimension 4550 Bootmgr missing error message
you would have to removed the hard drive and possibly buy the external adaptor for your hard drive then plug it in to another computer via USB and reformat the hard drive..
Jul 09, 2012 | Dell Computers & Internet
Dell dimension 1100 how do I enter bios
simple boy only press (f 2) when show dell logo & used ps2 keyboard because ps2 is detect when pc power up
Feb 09, 2012 | Computers & Internet
After I turn on my computer I get a message that says; Primary drive 0 not found, primary drive 1 not found, secondary drive 1 not found, strike f1 key to continue, f2 to run the setup utility.
If you have a spare working hard drive to test in this computer, swap it out with the existing one. All you have to do is verify that a drive is found during the post. If you get the same message, I would suspect the IDE controller on the motherboard has failed. With the age of the computer (5 years), I would suggest getting a new or used computer to replace it. You may be able to find a replacement motherboard for it, but then to keep it legal with a Windows operating system, you have to locate a motherboard of the same make/model.
Aug 26, 2010 | Dell Dimension 3000 PC Desktop
My computer cannot find he primary hard drive
Hi friend,
this is not your system problem. it is your wire problem. You need to change your hard drive cable then try.
Dec 17, 2009 | Dell Dimension 3000 PC Desktop
I am installing a new WD3200AAJB HD in a Dell Dimension 4550. This is the only HD in the system. There are also 2 CD drives and a floppy drive. I used the jumper settings the drive came with which pins...
Reinstall your old hard drive as master and install the new hard drive as slave.
Here is the link to jumper settings from Westrn Digital;
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1540&p_created=#jumper
If you've got your jumper settings wrong and installed your os on the 127 GB section of the 320 GB Hard drive and you change jumper settings and then you have problems you may need to reinstall the old hard drive as master and the new hard drive as slave. Reformat the new hard drive as 320 GB, and as a bootable drive. You can either do a disk copy from old to new or reinstall your os on the 320 GB drive. Please let me know how this goes. You can get to me @ johnkariotisjr91741@yahoo.com
Oct 25, 2009 | Dell Dimension 4550 PC Desktop
My Dell Dimension 4550 won't recognize my CPU.
your problem is the same as trying to put a AMD3 into a AMD2 socket, yes it fits and yes i physically should be able to run it it but in reality it won't
Sep 26, 2009 | Dell Dimension 4550 P4 Socket 478B...
Error loading operating system on a dimension 4550
Need new hard drive. If that fails then the controller on the motherboard is shot and its time to buy a new computer.
Jun 05, 2009 | Dell Computers & Internet
Dell Dimension 8250
Yes you need a new hard drive
Dec 09, 2008 | Dell Dimension 8200 PC Desktop
Computers & Internet Logo
953 people viewed this question
Alun Cox
