Question about Samsung SCX 4521F All-In-One Laser Printer
Saying paper jam dcp-135c brother printer
Ive got brother dcp-135 printer it keeps comming up paper jammed theres nothing there and making funny noises wont print can you help me please
    Novelist:
  • 166 Answers
 Hello there,If the paper is lodged too far into the printer and can't be removed: Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for Laser printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
do not forget to rate this solution....good luck
thanks for using FixYa
Posted on Feb 12, 2009
My printer keeps telling me PAPER JAM There is no paper jam. I've Paid $20 on 24 01 11
try this link
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/000400/000095/faq000495_027.html?reg=eu&c=eu_ot&lang=en&prod=dcp135c_eu_as&Cat=113
Jan 26, 2011 | Brother DCP-135C Flatbed Digital MFC...
I have a DCP-135C Printer. It shows Paper Jam. No paper is jammed. Can you help me please?? Michael .. bigead6151@yahoo.com.au
First of all you must read here and try to remove even any tinyest bit as it may cause problems.
this link has full explaination with screenshots.
if this doesn't help problem lies in the roller itself where some little pieces of paper jammed inside the printer therefore causing it to show that error. Another possibility is that the signal detector near the roller is faulty already.
Jan 24, 2011 | Brother Office Equipment & Supplies
I have a brother DCP-135C with a printer jam. I followed the instructions in the user guide and believe I have removed all the paper but still get the paper jam message. When I unplug then plug it back in...
for this model, normally the paper is stuck behind., you can open the rear part of the printer and check if there is any paper stuck there.
lift up the scanner unit and switch on the printer, does the sound come from the print head side, it could be due to the print head getting stuck... the encoder belt might be damaged...
May 20, 2010 | Office Equipment & Supplies
Paper jam
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 15, 2009 | Brother DCP-330C All-In-One InkJet Printer
Printe paper jam problem for brother dcp135c
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | Brother DCP 130C All-In-One InkJet Printer
Paper Jam Light on still
The print head is jamed too...
some wheel are scaled, there might be also a transparent scled band who help the print head.
If one of those was forced, you can replace the printer.
open it and check also if it's clean, this band might be dirty, cleaning with a wet rug (water) good luck.
Jan 03, 2009 | Brother DCP 130C All-In-One InkJet Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
372 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
