Question about Whirlpool GEW9250 Electric Dryer
Dryer makes clunking noise
It dries ok however it is making the noise as it rotates
  • 2 more comments
  • tommcconathy Feb 25, 2009
    Different dryer, same problem. It turned out to be the wheels that the drum rolls on whilst drying the clothes. Somtimes the only way to determint=e what the problem is is to take some panels off and and look. Sometimes you might have to run it to here/see what's wrong. My duet will safely (in my opinion) run without the top and back on, at least temporarily. Consider your skills, and try stuff if you feel comfortable. Look at the power plug connections, and make sure that before plugging it into the wall that nothing looks as if it could make a connection between the wire terminals and the dryer frame.
  • ASBIT Mar 08, 2009
    I have a Whirlpool electric dryer and it is clunking when rotating the drum as well...the clunking sound is louder with heavier loads...I took the unit as part as much as I could and did not visually see any defects, but isolated the sound to the intake fan in the lower left corner...any other ideas as to what is going on?
  • James Chandler May 11, 2010
    need brand name and model #
  • DRRXR May 11, 2010
    How old is this unit?
  • 686 Answers
Change your drum rollers
Posted on Mar 12, 2009
Ler3624eq1 whirlpool makes clunking noise
May have a bad bearing go to Repairclinic.com and watch their video on dryers
Dec 13, 2013 | Dryers
Frigedaire dryer front loader makes clunking noise
Hi kirst_alers2 - From what you have described it sounds like you either have a problem with the belt, front (and/or rear) bearing, or a loose connection with the motor or drum. Lint or something else clogging the vent could be causing the dryer to take a longer time to dry the clothing. If the dryer is taking too long to dry then the issue may lie with a faulty sensor. I recommend contacting a professional to accurately diagnose the issue, the part(s) may have to be replaced depending if they are worn, damaged or loose. You can often locate a qualified tech through the manufacturer website.
Apr 08, 2013 | Frigidaire Electric Dryer
When the dryer is on it makes a loud clunking sound during each rotation
Check to see if something was left in a pocket when dried and fell out. like a coin, a magnet, a wrench. Often, things fall out of pockets and make a loud clunking sound when the drier is turned on.
Feb 05, 2011 | Dryers
My stackable dryer (417.94702300) makes a clunking noise. We just got it (craigslist) and it happened the 1st time we turned it on. Sounds like we're trying to dry a shoe in there - it clunks in rhythm...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 16, 2011 | Kenmore Washing Machines
Dryer makes a clunking noise while drying. Is it possible that the drum is "Out of balance"?
Most likely if it is a thump thump noise a drum roller has a flat spot and is causing the noise.
The dryer will operate ok but it will be loud.
A service call may be needed to replace all 4 drum rollers.
Jan 06, 2010 | LG DLE2532W Electric Dryer
Dryer making a louder than normal noise when drying
Possibly the roller, I would have to hear it to be sure, but if it sounds like a clunking noise, it is probably a roller, if it is more of a high pitched whine, or a sound like a penny in a vaccum you probably have something stuck in your blower.
Dec 18, 2009 | LG DLE5932S Electric Dryer
Maytag Dryer clunking noise
Sounds like you need a blower wheel.you will need to remove the front panel and the houseing under the front panel.It is located on the bottom front laft side. if you need help on assembly or disassembly let me know hope i fixya :)
May 20, 2009 | Dryers
Dryer makes rumbling noise intermittently
It sounds like a faulty roller under the drum. Need to pop the top of the dryer, then remove the front -- you'll probably easily spot the faulty part.
May 06, 2009 | Maytag Dryers
LG DRYER MAKING CLUNKING NOISE
Look inside the drum at the seam, front and back side. The weld on the stainless steel drum may have cracked. You would need to replace part number 3045EL1002F. It is moderatly difficult to replace.
Oct 16, 2008 | LG DLE5977 Electric Dryer
Clunking noise
The clunking noise may be a broken weld on the drum.  Every time it turns and passes through the guide wheel supports, it makes a thunk thunk noise.  You will need to have a qualified LG technician diagnose the problem correctly but that's what it sounds like.
Jun 07, 2008 | LG DLG5988 Stainless Steel Gas Dryer
Whirlpool GEW9250 Electric Dryer Logo
843 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
