We have had our Keurig for 18 months, and this problem just recently started. When I push the "ready to brew" button, a loud vibrating noise starts. If I remove the chrome plate on which you rest the cup, the noise goes away, but then the mug doesn't fit correctly in the black plastic basin. It still works but is very annoying.
-   I have the same problem, although with mine it started pretty early on; I was just too lazy to do anything about it.
I just called Keurig to ask them about it, and their answer was unfortunately the earlier models had noisy pumps, but they have since redesigned the brewers.
In the mean time, they suggested descaling the brewer, as that can have an effect on the noise if it has not been done in a while. I imagine it was just to get me off the phone, but I am willing to give it a try.-   Guest
Apr 17, 2009
-   My Keurig does the same thing. It vibrates so loud that the cups need to be held or they will fall off the basin. I hate using it because the entire kitchen sounds like its taking off for outer space.
-   Guest
If you slide out the drip catcher tray and just remove it, the brewer works just fine. Granted, your mug is sitting a little further away from the spout, but it does take care of the metallic rattle.
only a week old. for the last couple of days will not brew a cup of any size. shows brewing on lcd,...
(More)
only a week old. for the last couple of days will not brew a cup of any size. shows brewing on lcd, nothing comes out. I have noticed, the LCD has lines through it and also, no matter what size i choose, i get nothing but small size... however now it won't brew anything or maybe an inch worth
The Not Ready indicator will not go off and the coffee will not brew. I have unplugged and replugged...
(More)
The Not Ready indicator will not go off and the coffee will not brew. I have unplugged and replugged numerous times.
Lost the part the coffee pod sits in and cant find a replacement anywhere on the net or and any...
(More)
Lost the part the coffee pod sits in and cant find a replacement anywhere on the net or and any local store in the Milwaukeee area. The coffee maker is useless without it. Where can I purcase this part? GR
