Question about HP Deskjet 2460 InkJet Printer
Not printing!!!! My hp cannot print!!! it's a deskjet246...i tried troubleshooting it from it's help pages....did not work...i deleted it and re-installed it back,still the button is blinking......it has a-lot of ink...and the last time before it had this problem, it just paused i waited for about 30min but no progress... could someone tell what to do!? and please also include prevention...thanks!!
  • amir8485 Apr 14, 2009
    my printer HP Deskjet D2460 does not work,the cartridge carriage does not move normally..when it move it stuck in the middle..can everyone solve my problem..i need cold reset for this printer to reset the board..someone please help me..as soon as possible cause i need use it..
    Scholar:
  • 118 Answers
What you need to do is go to your start menu and look for printers and faxes. Click on that and it will show your printers. Make sure your printer is the default printer, how to do this is by right-clicking the name of your printer, and then selecting "set as default" or something like that text. after you do that your printers name will have a check on it. Make sure to delete any old printers that aren't yours because they'll block it out. If still nothing, also make sure it isn't on pause. If it is you should be able to right-click it and select "resume printing" and it should now work.
Posted on Jan 30, 2009
Memory low message on hp laserjet pro 200
see HP LaserJet Pro Printers Memory is Low message displayed on the control...
HP LaserJet Pro Printers - 'Memory is Low' message displayed on the control panel HP LaserJet Pro - Troubleshoot 20.xx (memory failure) and 21.xx (print failure) error messages (ID: emr_na-c05049204)
HP Customer Support page and ensure the printer is running the latest available firmware. Print a Configuration Report from the control panel of the printer to check the installed firmware version.
  • If the printer supports expandable memory, you can install additional memory in the form of a DIMM. Check the printer's User Guide to see if it supports additional memory.
  • Break complex print jobs into smaller jobs that contain fewer pages.
  • If the printer is an MFP, delete stored faxes to increase available memory. Go to this document for instructions: HP LaserJet Pro MFP - Delete faxes from memory (ID: emr_na-c03264743)
  • Power cycle the printer to delete stored fonts or macros. It is possible to download fonts or macros in a way that power cycling the printer will not delete them; see Appendix A - Memory Allocation.
  • Changing some software and/or print driver settings might result in a less complex print job.
  • Use a different print driver. For example, a PostScript print driver will typically result in a more complex print file. If possible, try sending the file with a PCL6 or UPD printer driver.
  • Adobe PDF files can sometimes be very complex. Go to this document if printing PDF files is slow or resulting in memory out messages: HP LaserJet - Print job is slow or hangs in the print queue when printing Adobe PDF files (ID: emr_na-c04071740)
  • If the printer is connected via a network, try sending the file connected by USB cable only. This will eliminate possible network issues that are taking printer memory.
  • Appendix A
    Memory Allocation Utilities or jobs that you download to the product sometimes include resources (for example, fonts, macros, or patterns). Resources that are internally marked as permanent remain in the product memory until you turn the product off.
    Use the following guidelines if you use the page description language (PDL) ability to mark resources as permanent. For technical details, see an appropriate PDL reference for PCL or PS.
    • Mark resources as permanent only when it is absolutely necessary that they remain in memory while the product is turned on.
    • Send permanent resources to the product only at the beginning of a print job and not while the product is printing.
    NOTE: Overusing permanent resources or downloading them while the product is printing might affect product performance or the ability to print complex pages.
    Sep 08, 2016 | HP LaserJet Office Equipment & Supplies
    HP CP4025 produces no yellow image
    Use the built-in print-quality-troubleshooting pages to help diagnose and solve print-quality problems. 1. Press the Home button. 2. Press the down arrow to highlight DIAGNOSTICS, and then press the OK button. 3. Press the down arrow to highlight PQ TROUBLESHOOTING, and then press the OK button to print the pages. The product returns to the Ready state after printing the print-quality-troubleshooting pages. Follow the instructions on the pages that print out.
    This should get you started Isn't this printer still under warranty?
    Aug 01, 2011 | HP Color LaserJet Enterprise CP4025dn ...
    Color printing, not so colorful. Even with new cartridges
    Your model has some print quality pages built in to help diagnose and solve print problems.
    1) Press <Menu>
    2) Press <Down> button to highlight "Diagnostics"
    3) Press the <checkmark>
    4) Press <Down> button to highlight "PQ Troubleshooting"
    5) Press <checkmark> to print the pages
    If you see print-quality defects on the print-quality-troubleshooting pages, calibrate the printer. To calibrate the printer (optimize print quality):
    1) Press <Menu>
    2) Press <Down> button to highlight "Configure Device"
    3) Press <checkmark>
    4) Press <Down> button to highlight "Print Quality"
    6) Press <Down> to highlight "Full Calibrate Now"
    7) Press <Checkmark>
    I hope this helps!
    Dec 21, 2009 | HP LaserJet CP3505dn Printer
    I have an HP 1310 - I can't delete my print job. It was only 4 pages. I hit ''delete'' at 4:15 pm and now it's 10:25pm and it's still there. I've tried canceling, deleting, etc. I have to print some other...
    Try This :
    Click on the "Printer and faxes folder" from control panel
    Right click on the printer ICon and click on "Pause Printing"
    For XP
    Click on start
    Click on RUN
    Type in CMD
    Press enter
    Type in "NET STOP SPOOLER"
    Click on the "Printer and faxes folder" from control panel ; Right click on the page and Click on Refresh
    Get Back to CMD
    Type in "Net Start Spooler"
    Come Back to Printer and faxes folder ; Right click on the page and Click on Refresh
    And then Click on cancel
    Still if it doesn't work
    Restart the PC it will get deleted
    Don't try to print after that
    Uninstall and reinstall the software first
    This should resolve your issue
    Regards Soumajit
    Sep 22, 2009 | HP Office Equipment & Supplies
    Priter job not deleted without pc rebooting in hp 1007
    1st u try to off ur printer off then delete printing job
    hope this is help full to u
    Jun 28, 2009 | HP LaserJet 1020 Printer
    PAGES WON'T PRINT, [TRIED TO PRINT BOTH SIDES BUT NOT SET UP FOR IT], THEN TRIED DELETING DOCUMENT, NOT WORKING, STUCK ON DELETING NOW AND WONT DO ANYTHING NO MATTER WHAT I DO. TRIED PRINTING OTHER PAGES -...
    you can't print another document until there's a document on queue on the printer...you need to delete it first..
    i experience it before I just delete the printer icon on the printer and faxes area and unplug the printer and plug it again ..wait a such time when a wizard appears on your screen just follow it..to find your printer driver..and to start a new session with the printer..
    i hope it help..
    and don't forget to rate...^_^
    May 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
    HP photosmart C5280 document stuck in print que
    Delete document manually from the path mentioned below:
    1) Press windows + R an then type spool
    2) Go to PRINTERS folder.
    3) Delete the files present in there.
    If not able to delete then
    1) Open command prompt.
    2) type "net stop spooler" and then delete the files
    3)Again type "net start spooler"
    Your stuck document is now cleaned. You can start printing your document again.
    Mar 30, 2009 | HP Office Equipment & Supplies
    Prints extra blank page for every one page of printed material
    Ok, I too have HP Photosmart 7280 and it was spit'g out a blank page after each print page.
    I went into the Control Panel/Printers - Right click on the HP Photosmart 7200 series icon and choose delete. Don't worry...just delete it.
    Right above (Vista) click on Add a Printer - it's going to ask you if you want to add a local printer which is connected via USB connection or if you are set up wireless then choose Network
    It will find your printer click on the printer hit next - then this is the most important step
    It will ask you to find the manufacturer it shows Hewlett-Packard and underneath it shows HP - Do not click on HP - you'll have the same problem with that driver - choose Hewlett-Packard and find this driver HP Photosmart C7200 series Version 61.71.244.0 [3/23/07]
    Hopefully they are all digitally signed with this information.
    Click on that driver and click next - then click on replace the current driver and click next.
    Print a test page and problem should be solved. Hope it helped!
    Aug 01, 2008 | HP Photosmart C7280 Laser Printer
    Hp 670c deskjet will not print
    Dear Sir,
    As soon as you Plugin the Ink Cartridges an alignment page should print. When you install a printer to a computer the Test page should come out. If nothing is happening then printer is faulty. If Printer is fit and fine then try using another computer. If nothing works out please let me know.
    Best Regards.
    Rafique
    Feb 09, 2008 | HP DeskJet 670c InkJet Printer
    Hp printer 5420 photosmart
    sadone:
    I assume all hardware connections are fine, and any lose cable connections are already checked then......
    1)Send a test page to the printer Open up the print jobs, and try deleting all jobs (click on the printer from printer and faxes under control panel, delete all print jobs, Still in this window click printer and uncheck the print offline, does this help?) if not then
    2)Try uninstalling and reinstalling the printer driver and then try printing a test page.
    3)Try uninstalling and reinstalling the printer software and driver and then try printing a test page.
    If nothing works then:
    -Uninstall all printer software, driver unplug and reseat an original hp cartridge and go this link install software and driver and follow instructions on how to install the drivers, at the end click the check button to see if driver is fine. Now you should be able to print.
    Dec 24, 2007 | Office Equipment & Supplies
    HP Deskjet 2460 InkJet Printer Logo
    123 people viewed this question
    Seeker5211
    Seeker5211
