Question about Apple iMac 24" Desktop
Booting up computer
When I first turn my computer on, I get just a screen with apple showing, and the computer is not booting up. After several tries it does eventually boot up. Why is the computer doing this? What can I do to solve problem?
  • Apple Master
  • 1,800 Answers
Try to upgrade ram modules.
or make back up and format then install a new mac os!!
Posted on Jan 30, 2009
Which part is failed on my iMac with white screen?
Did you read the Apple support page on this problem? they are really good in helping: Troubleshooting My computer won turn on
Nov 25, 2014 | Apple Imac Alum. 20" 2.4ghz Intel Core 2...
Apple MacBookPro 2010 is in a white screen
If the start up sound plays and the hard drive sounds normal try connecting the computer to an external monitor. If the external monitor shows the desktop just fine then the cable connecting the laptop to its screen is probably going bad.
If the computer will not boot at all try zapping the PRAM by
  1. Pressing the power button and then command-option-p-r before the gray screen comes up.
  2. Hold those keys down until you hear the startup chime.
  3. Let go of the keys and let the Mac reboot.
If that doesn't work try booting from an install disk and run a repair utility.
Jan 28, 2014 | Apple 13" MacBook Notebook Computer ...
When I turn on iphone 3G it only show apple logo, after that it is turned off and shows nothing, Further when I connect it to itunes or computer it does not show iphone. I have tried to restart the set by...
Hello.
You'll need to reset the iPhone.
From About:
To do that, hold both the sleep/wake and Home buttons together for at least 10 seconds.
The red shut down slider will show up at the top of the screen and then disappear. Keep holding the buttons. The screen may even go black, but don't let go of the buttons until the Apple logo shows up. When it appears, let the buttons go and the phone will start up normally.
Hope this resolves your problem.
Jan 15, 2011 | Apple iPhone 3G
My 21" mid 2007 imac periodically freezes, the
Try booting it into single-user mode holding down Command(Apple) and S buttons when powering up. Then in terminal console, use chkdsk -fy. Use it and use it again until comes back with something like "Volume appears to be OK". Then use command: mount -uw / and then type reboot and try booting normally.
If it does not fix your problem, it's most likely a hardware issue (logic board / graphics card), and you should take it to an Apple Authorized Service Provider.
-juuko
Nov 08, 2010 | Apple 24" iMac Desktop
I got this imac desktop computer model # m6498 from my aunt. when i turn it on it shows a spinning loading wheel and i cant get pass that page...How do I fix this?
Luck you, hopefully we can get this fixed! Ok, there are a few things that might be causing this, and several ways of dealing with them.
Firstly, if you're not fussed about saving the data already on the computer, try the following:
  1. Turn the Mac on and insert the restoration disk that came with it (If you don't have one then you'll need to get one, try ebay or amazon, or an Apple store).
  2. Turn the Mac off with the disk still in
  3. Re-boot it, holding down the C key. This will boot up from the CD, and hopefully you'll be able to re-install Mac OS X, which will give you a working, clean machine.
If that doesn't work for any reason, I'll need some more information. Try this:
  1. Turn the Mac off, after ejecting any CDs.
  2. Boot up your Mac, and as soon as you press the power switch, hold down Command and V. This boots up in verbose mode, giving you more information about what's happening in the computer.
  3. Watch the instructions on the screen, and see if there are any obvious error codes, or if there are any instructions that the computer gets 'stuck' on.
If there are any error codes or sticky instructions, please post them back up here and I'll see if I can help some more.
Hope that was helpful, good luck!
Nov 05, 2010 | Computers & Internet
My Itouch is locked with the Apple showing and a bar that is only partially filled. I tried rebooting, several ways but still get the same results (the apple with a bar below it that is locked) Any...
It sounds like you may have disconnected during a restore
Try getting the iPhone into recovery mode.
  1. Turn the device completely off and disconnect it from cable/dock.
  2. Hold down the home button.
  3. While holding down the home button connect to a computer with a cable (easiest) or dock.
  4. Keep holding down the home button until you see a connect-to-itunes screen You are now in recovery mode.
If this fails try holding the power in home button at the same time A LONG TIME about 2 mins the phone will boot and reboot until you see a USB cable and a disk on the screen. Just keep holding.
The connect to iTunes and restore.
IF YOU LIKE WHAT I WROTE PLEASE VOTE 4 THUMBS UP!
(any less screws up our average)
Thank You and Good Luck!
Jan 19, 2010 | Apple iPod touch
Computer comes on, shows a blue screen, and restarts on it's own.
Try to boot into Safe Mode.
If you're able to, let me know and we'll go from there.
Jun 17, 2009 | HP Compaq Presario 2223US Notebook
Download not complete Leopard not working
Try to boot your computer with the Recovery disc, by turning on your computer and slot in the disc, and pressing the C key. If it succefully boot in, try to restore the Mac software.
Feb 06, 2009 | Apple MacBook Pro Notebook
Apple G5 Locked up
Sounds like you have a permissions issue, first boot in single-user mode and repair permissions.
Resolve startup issues and perform disk maintenance with Disk Utility and fsck
Mac OS X: How to start up in single-user or verbose mode
If that doesn't help, try booting into Safe Mode and see what happens, if it comes up hopefully another restart may solve, if not, you can at least use this as a starting point to try and resolve. Safe Mode will allow you to get around, surf, etc...
What is Safe Boot, Safe Mode?
Mac OS X: Starting up in Safe Mode
If Safe Mode comes up alright, I would install AppleJack, excellent troubleshooting article can be found here... Troubleshooting Tools: AppleJack
Jan 22, 2009 | Apple Power Mac G5 Desktop
Apple iMac 24" Desktop Logo
90 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
